Question about Acer AL2016W 20" LCD Monitor
Will an acer al2002 w monitor work with a mac mini 2008?
3 Suggested Answers
  • 87 Answers
SOURCE: MY ACER MONITOR , DOES
It maybe looking for a signal from a port other than the one you are plugged into.
Try to select a different input on the monitor .
check the PC to monitor cable connections at both ends.
if you have no luck there.
your video card might be cooked (broken) or the driver corrupt.
or on-board video chip driver might be corrupt (likely not cooked)
Let me know it this helped you or not.
Post your answers as a comment or reply and I'll be notified
Posted on Feb 05, 2011
shadowqat
  • 72 Answers
SOURCE: I am using a MacBook
This is a very simple solution, fortunately. The default behavior of an external monitor connected to a portable Mac is to act as extra space, effectively extra screen "real estate," where you can move windows or do whatever else you need to.
Verify this by moving your mouse to the right-hand side of your screen, and then keep going - you'll see your mouse appear on the external monitor.
If you want to have the external monitor reflect exactly what you are doing on the primary monitor, simply go to Apple menu > system preferences > displays > arrangement and check 'mirror displays.'
And that's all there is to it!
Posted on Jul 01, 2011
How to planar touch screen to mac mini
Try downloading and installing the latest drivers for your particular model.
Drivers and Software
Oct 15, 2014 | Computers & Internet
Acer s211hl picture unstable
Can you try a different monitor? A friend's?
Or connect the monitor to another computer?
If this Maverick then you may need an updated driver.
Apr 02, 2014 | Acer S211HL Monitor
Acer display drivers for mac-mini ?
hi, may I know how are you connecting the mac-mini to the display? if it is VGA, that is the highest resolution it can go. But if you're connecting it via HDMI or DVI-D, it can reach its highest resolution for the monitor. did have similar problem last time, but solved by using HDMI-DVI cable.
Jan 01, 2014 | Acer AL1917W LCD Monitor
How to put the monitor cable in to the mac mini
You need the correct monitor or adapter that works with your mini.
Feb 16, 2013 | Apple MAC MINI 266GHz Intel Core 2 Duo 8...
I am using a MacBook with an Acer Monitor with a mini connection. The monitor shows the start up screen of the MAC but known of the icons nor does it reflect what is on the MacBook while I am working.
May 21, 2011 | Acer AL1913 19" LCD Monitor
MY ACER MONITOR , DOES NOT COME IN, WHEN I TURN ON MY COMPUTOR , IT TURNS ON FOR ONLY ABOUT ONE SECOND AND THEN OFF , MODEL # AL2002 W SD
Feb 05, 2011 | Acer Computers & Internet
The monitor is black with a error message :input signal out of range We are connected to a Mac Mini This problem seemed to happen after the monitor was accidently disconnected and then when it was...
Can you please get me the make and model of the monitor? Also did you check to see if the refresh rate of the monitor matches with that of the mac mini?
Nov 21, 2010 | Hannspree Computers & Internet
Everytime i conect my monitor into my mac mini the screen shows up for a brief second and disapeers. How can i fix this
You need to lower down the screen resolution. Check the setting of your mac mini then adjust the screen resolution to the lowest.
Jun 09, 2010 | Acer V193w LCD Monitor
Everytime i conect my monitor into my mac mini the screen shows up for a brief second and disapeers. how can i fix this
Hello sir, hi, you need to try another good working monitor, and confirm if the problem is your monitor or your Mac mini, or test your monitor on another mac, and see if the same symptoms appear. you now have an idea of where is the problem. let me know your progress
Apr 26, 2010 | Acer V193w LCD Monitor
Mac mini will not produce video
Hi, Sorry you are having problems,
Well, that sounds pretty bad. Does the Mac make the start-up sound when you turn it on?
Does the little light in front turn on ?
Do you hear the hard drive spinning up and working to boot the mac ?
So, if all these questions are answered Yes.... sounds like the video connection has blown.
If you say the Mac is almost new, Apple should cover this with the one year warranty.
Good luck.
Oct 31, 2008 | Computers & Internet
Acer AL2016W 20" LCD Monitor Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
