Why does my samsung WA476DSHAWR/A1 Washer keep displaying an 8E error code?
Maanita
  • 1142 Answers
SOURCE: Spin cycle wont work and
It doesn't pump or spinIf it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • Posted on Aug 05, 2008
    • 3 Answers
    SOURCE: Samsung P801DWNXRC Frontload washer displays E6 error code
    I had the same problem. I ended up paying $300 ($100 part $200 labour) for an authorized technician to replace the control board and that fixed the problem.
    Posted on Sep 22, 2010
    TheMobilian
    • 8220 Answers
    SOURCE: My washer keeps displaying "Sd" error and also
    That sud error could be caused by the use of the wrong detergent or too much soap or items between tubs or clogged pump filter can also cause it. Check this video out
    Posted on Apr 29, 2011
    • 6277 Answers
    SOURCE: Samsung WD8602R8U Washer Dryer
    (no promises but it's worth carrying this out anyway!)
    I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
    Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
    REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
    If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
    It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
    Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
    At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
    If this has assisted you please consider a 4 thumbs up for the rating.
    Thanks and good luck!
    John C
    Posted on Sep 10, 2011
    • 6277 Answers
    SOURCE: Samsung WD8602R8U Washer Dryer give
    Hopefully answered on your other posting ;-0) John C
    I have a Samsung top load washer model number wa476dshawria1 and it goes almost through entire cycle and then starts flashing dc, I have already replaced pump and it seemed to work fine, how to I...
    do not believe there is a recalibration but here is a link to the manual Samsung WA476DSHAWR A1 Trouble Shooting Guide User Manual Ver 1 0 English...
    Mar 02, 2015 | Samsung Washing Machines
    8E error code on samsung top load direct drive washer
    Samsung has us replace Mems sensor, main harness and user interface board. They do not have away to test the mems sensor in the field.
    Dec 09, 2013 | Samsung WA5451ANW 4.7 cu. ft. Top-Load...
    Samsung refrigerator error code 8E
    8E = OVER CURRENT ERROR
    IPM fault signal (this is caused by the overload of the MICOM INTO during motor action).
    IPM: Integrated power module. The IPM controls the motor.
    If the fault (low signal) happens to be sensed even once during the washing/rinsing stage, the motor stops immediately. However, during the dehydrating stage the signal is to be sensed, when the number of signals reads more than 6 per 500ms during the Washing or Rinsing cycle action.
    If the motor stops working, in one direction ten times, "8E" Error is displayed.
    During dehydrating, when the overload is sensed, the motor stops working at once and then feeds back to the initial stage of the dehydration unbalance sensing. When the feed back has occcurred twice, Error "8E" is displayed during the dehydrating unbalance sensing, No error happens by overload sensing. When it happens at more than 800rpm, the process is stopped compulsorily. Power Switch OFF can clear the overload error.
    Nov 23, 2012 | Samsung RS265TDRS Side by Side...
    E8 front loader washing machines
    OVER CURRENT ERROR - Display shows 8E.IPM fault signal (this is caused by the overload of the MICOM INTO during motor action).
    HOWEVER, the UK White goods website says:
    E8
    Temp too high on low temp washesNormally this will be the wash temperature thermistor or NTC that's faulty, please contact us if you need the thermistor with the model and serial number.
    You can find more about your Samsung Washing Machine error codes at:
    http://www.keepingupappliances.com/repair-help/appliance-repair/washing-machine-help/samsung-washing-machine-error-codes/
    or
    http://www.ukwhitegoods.co.uk/help/fix-it-yourself/fault-codes/laundry-fault-codes/3069-samsung-washing-machine-fault-codes.html
    Jun 21, 2011 | Samsung Washing Machines
    Telewest Codes 07 April 2009 5A 01
    TELEWEST
    01 ... 8e 80 d7 ef 44 93 02 2b its only this one u have to change it worked for me anyway back on and going
    Apr 07, 2009 | StarTech.com StarView SV211K 2-port KVM...
    Does anyone know todays codes
    Codes for telewest as of 7/5/09
    00> AA B7 D1 D9 CE 8E 83 AF
    01> 8E 80 D7 EF 44 93 02 2B
    Mar 14, 2009 | StarTech.com StarView SV211K 2-port KVM...
    Telewest Codes for 26 February 2009
    hi here are codes at 25/2/09
    00= aa b7 d1 d9 ce 8e 83 af
    01= a1 38 06 29 24 29 8d 2b
    hope u get and running.
    Feb 26, 2009 | StarTech.com StarView SV211K 2-port KVM...
    Telewest codes for today please?
    00 keys = AA B7 D1 D9 CE 8E 83 AF
    01 keys = A1 38 06 29 24 29 8D 2B
    Feb 25, 2009 | StarTech.com StarView SV211K 2-port KVM...
    Need new codes for eurovox telewest
    hey try this code
    5A 01
    it works on mine
    goodluck
    Jan 18, 2009 | StarTech.com StarView SV211K 2-port KVM...
    Washing Machines Logo
    187 people viewed this question
    Top Washing Machines Experts
