Question about SVA-USA VR-20 20" Flat Panel LCD Monitor
TV isn't acting as a computer monitor - doesn't recognize computer connection
  • 258 Answers
You need to use the right cable that plugs into your pc serial port in tv to the video card of your computer or same looking connection as your tv one but on the back of the computer ok
Posted on Jun 23, 2009
Why will my computer not work through tv
Heidi we need a little more information but I'll give a little background here for you so we know what you're trying to do with your TV.
First TVs don't run computer programs so running a computer game on your TV only works if you have a device like a Play Station system to "run" the software. Many TVs these days can be used as Computer monitors but the TV has to be compatible for his usage and have the right ports for instance to connect your laptop/computer to the monitor.
In either case, the TV only acts like a monitor so your computer programs won't run on a TV.
If you have an older TV, there may an interface you can buy that will let your older TV act like a monitor for your computer. You'd have to look up your model TV and see if there is such an interface for it.
Hope that helps.
Nov 29, 2015 | Televison & Video
Connect toshiba satellite l305-s5919 to tv with vga to rca cable
that particular model of computer l305-s5919 has RGB component out while the tv seems to be rca input.
does the tv have component in.
you may find an adapter like this might work
http://www.ebay.com/itm/Ypbpr-component-to-Composite-AV-RCA-audio-video-converter-with-power-supply/272260592065?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D2%26asc%3D44770%26meid%3D75516a845eb841a3bec53062c7dfac66%26pid%3D100005%26rk%3D5%26rkt%3D6%26sd%3D230912528485
Jul 13, 2017 | Lifetime Computers & Internet
Connect toshiba nb500 netbook to RCA tv win 7 stater with VGA cable and s video no displaying in the monitor tv didn't recognize
Does you notebook shows any connection information after connect to tv. If not you need to install. If this didn't work you have to change VGA cable. If not your notebook doesnot supports the tv
Jan 21, 2013 | Computers & Internet
Monitor will not boot up is reading no input signal
So either the computer isn't generating a video signal, the cable isn't carrying the signal to the monitor, or else the monitor isn't capable of receiving a video signal.To test this, first try a video cable that you know is good, in case your cable is bad, If it works with the other cable, the problem was your original video cable. If it still doesn't work, put your original cable back, and hook another computer up to the monitor. If the monitor makes the same message, the problem is with the monitor. If the other computer works when connected to this monitor, your problem was that the original computer isn't booting (which could be due to several reasons I will list below), or the video adapter is broken.Possible reasons for the computer not booting: bad power supply, bad power button, bad hard drive, bad memory, bad motherboard component. If you determine that it isn't booting, unplug everything except the keyboard mouse monitor and power cord, to see if that makes a difference. If it boots after that, something you unplugged was causing the problem, plug them each back in one by one, rebooting in between, and when it stops booting properly, the last thing you plugged in is causing the problem.
Mar 02, 2012 | Acer Computers & Internet
I have a Jensen (JE1909ACB) 19 LCD TV Can't get it to hook up as a monitor on my desktop. It reply's unsupported mode.
Are you using the VGA port on the Jensen TV? What is your computer's OS?
The usual reason for the unsupported mode message is that the the computer did not recognize the TV as a monitor on boot up or that the previous settings were incompatible with the TV. (For example, if you previously had a CRT connected to the computer and used a refresh rate of 75 Hz, the TV can't handle the refresh rate. It needs to be set at 60 Hz.)
First turn off both the TV and the computer. Then turn on the TV and set it for the PC input (assuming you are using the VGA port). Next turn on the computer. If you have Windows XP or later, it should find the TV and set the resolution without any input. (If it doesn't, use a different monitor and set the resolution to 1366 x 768 and 60 Hz. Then try again.) If you used the HDMI port, try the VGA port. This TV doesn't understand a computer signal over the HDMI port (only set top boxes).
I hope this helps.
Dec 08, 2011 | Car Audio & Video
Iphone not recognized when attached with usb connnection
Try using different usb ports on your computer. If it doesn't work then try hooking up your iphone to another computer. If it still isn't being recognized then try a different IPHONE USB cable.
If your Iphone still can't be recognized after all of this then read the article at the link below.
http://support.apple.com/kb/TS1538
Also try restoring your iphone to factory defaults if necessary. This is a last resort. If your iphone still won't get recognized by the computer then it could be the connection on the Iphone is defective and in that case replacing the phone is the only option.
Nov 03, 2011 | Sony VAIO VGN-N325E Notebook
Where is connection for hp pavilion p6110f to tv
Unless you have a dedicated video card (which is NOT included on the stock model of this PC, you'd have had to have added it after buying) there isn't one. Check your TV for a VGA connection (a blue connector, like your monitor) and if it doesn't have one, you're out of luck.
Sep 02, 2011 | HP DT PAVILION P6110f DESKTOP PC
I am attempting to connect my HP pavilion dv9000 to a HP 2310e monitor, but it doesn't recognize the monitor via the HDMI cable
You must make sure it's configured correctly: make sure the monitor is up and running (not in Sleep) , that the HDMI cable is firmly plugged in (use a new one to be sure), then right click on the desktop, click NVidia Control Panel, under Select a Task expand Display and click Run multiple display wizard . If the monitor isn't picked up then go to Set up multiple displays options and see if the monitor appears in the second setting (Select the displays...) - if it doesn't then click the MY Monitor is not shown in the list option and follow the procedure to force its detection.
If even that fails then the video driver is corrupted, you will have to uninstall it, download the latest one and reinstall it.
Use this one
http://www.nvidia.com/object/geforce_notebook_winxp_179.48_beta.html
Aug 12, 2011 | Computers & Internet
Insignia LCD TV won't recognize computer input...
Heres the dealyo.
Click start button
Click control panel
Click display
Click settings
adjust screen resolution (probably have to go down) until the tv displays your computer
if this did not work, you will have to adjust bit rate from 32 to 16. Fiddle with the settings until the magic happens.
You will not get any sound unless you use an audio jack plugged into t.v.
Im here all week
May 20, 2008 | Televison & Video
Visco LCD TV VSC-32V3 32
Did you check the cabling correctly
SVA-USA VR-20 20" Flat Panel LCD Monitor Logo
75 people viewed this question
Top SVA-USA Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a SVA-USA Computer and Internet Expert? Answer questions, earn points and help others
