Question about Hampton Bay Dryers
What remote goes with ceiling fan model YG-241?
Moved into a house with no remote for the ceiling fan. Vender: 445993 Modle: YG-241 (ceiling fan with light) No. E763414
    Top Expert:
  • Hampton Bay Master
  • 34,217 Answers
This is some kind of generic ceiling fan that used some kind of remote. Finding a replacement remote will be difficult to impossible. A more practical approach would be to replace the fan.
Posted on May 16, 2014
SOURCE: Ceiling fan does not reverse with remote
Just reporting that I called Hampton Bay about the remote not working to reverse the fan. I was told that I needed to have the fan running on low and then press reverse on the remote control. If that doesn't work, customer service told me to press reverse while running the fan on medium. (Some fans are set to reverse on low and others on medium.) Nowhere in the manual is this addressed. I had been pressing reverse with the fan turned off, which seemed to me a logical thing to do. Live and learn.
Posted on Sep 05, 2007
johnny5846
  • 379 Answers
SOURCE: ceiling fan remote will not turn on light
common problem , i went to home depot and bought a new remote for my hunter fan , and it worked again , salesman was very knowledgeable and helpful . thanks. explain the problem to him , he can help .
Posted on Dec 30, 2008
  • 234 Answers
SOURCE: installing a ceiling fan with light. extra red wire
The red wire is the power for the fan
Posted on Mar 14, 2009
jmgldsmth
  • 1869 Answers
SOURCE: remote controlled ceiling fan
unplug the fan then remove the batteries from the remote then plug the fan back in and, reinstall the batteries; this resets the fan control
Posted on Apr 22, 2009
  • 10865 Answers
SOURCE: How do you set the switch for 3 adjacent ceiling fans
Each remote/fan unit has to be set to a different code otherwise you will always have this problem. Open up one of the remotes and you will see the area where the numbers can be selected, usually one thru five. Then remove the cover on the fan at the ceiling and you will see the same set up. Just go from unit to unit and do not use the same code on any two fan/remote sets and your problem is solved.
Posted on Jul 31, 2009
Our remote to the fan is not working
Try changing the batteries int he remote.
If anyone opened the battery box for the remote recently, the "DIP" switches may have been moved. These switches make the communication between fan and remote match - (in case you have several fans in the house, you only want one remote controlling one fan). You will have to pull the besel off of the fan (where the pole comes to the ceiling). You should be able to see a set of 4, 6 or 8 little slider switches on a small electric board. Make sure the switches are set the same on both the fan and remote. If they are set differently, they will not communicate.
If that doesn't work, there are many options of what can be wrong (bad remote, bad radio receiver on the fan, interference from other radios, ...).
Good luck,
-Mark
May 21, 2011 | Hampton Bay 24750 Huntington III Ceiling...
I moved into a house with 2 hunter ceiling fans with remote control. Both are set to the same frequency. Where is the transmitter located on the fan to change remote frequency setting?
Typically it is directly under the very top cover. it is slide under the hanger on the ceiling. Just remove the 4 screws and drop the cover and it should be there.
Apr 27, 2011 | Hunter Heating & Cooling
I need a diagram for the wiring that goes from the fan to remote speed settings and then to electrical wires in ceiling
all of the white wires connect together and to the white house wiring (neutral from ceiling) ..also the neutral or return wire for the controller (may also be white) .. then the black house wiring(or red if you have an external wall switch) is connected to the controller wire marked AC or AC input .. the output marked "lamp" on the controller connects to the blue wire that goes to the light bulb (or bulbs) ... the output called fan goes to the black wire of the fan motor .. the green house wire goes to either a bare wire, green wire or a green bolt that is screwed to the metal of the fan.. thats the safety ground ...
Jun 05, 2010 | Hunter 52" Ceiling Fan With Light And...
I have a Hampton Bay Fan: Model# 104-478 Vendor# 445993 Can use a plastic UL rated ceiling outlet box for this fan?
You can use a plastic box provided it's listed for fan support. That is, the box can't provide the sole means of supporting the weight of the fan. There are a variety of suitable fan boxes and braces in both plastic and metal available, as well as information on properly installing a ceiling fan, at the big home improvement places. There are also many how-to sites with instructions and video on installing a fan so it meets the latest NEC requirements.
Mar 20, 2010 | Dryers
Heritage Ceiling Fan
You can try a univeral remote and that should work. You can buy one online at: http://www.ceiling-fans-n-more.com/ceiling-fan-remote-controls.php
Jul 10, 2009 | Dryers
Fan works, light doesn't on Hunter ceiling fan
I would begin by testing each bulb in a different socket somewhere in the house.
Apr 06, 2009 | Hunter 27187 Remote Control
Hampton bay ceiling fans
in order to help you, i need to find out the model first. you can find it out at the top of the circulating fan which has a sticker, from there we can find out the model and the appropiate serial number , remote are available on line depends on the model number
Dec 21, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Hampton Bay ceiling fan - will not reverse
It sounds like the direction switch has a broken connection on the "reverse" side.  Should be an easy fix (but you might need a soldering iron).
Dec 07, 2008 | Kitchen Appliances - Others
Dryers Logo
307 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
