Question about Dishwashers
What doese E25 MEAN FOR A KENMOORE DISHWASHER
What does e25 on my dishwasher mean
The most common in my view is the impeller jamming on the pump normally something small like a piece of chipped china or bit of broken glass, this can be removed with tweezers or pin nose pliers. After removing it should rotate easily by hand... then you should replace the pump cover and the filter above it must be locked by aligning the blue arrows so that large bits of rubbish cannot get into the impeller again.
There are two types of pump covers one is held on with a screw and the other clips into place.
In a lot of people's houses they have the dishwasher plumed into a sink unit and the fittings can get clogged and also blocked with fat, some have a cross inside the spigot and this gets blocked with all kinds of stuff.
When you push the dishwasher into place the pipes can get trapped and kinked so make sure that this does not happen. Sometimes the waste pipe has kinked when it was fitted and over time the dishwasher is getting worse at emptying and this is when the E25 fault starts occurring.
The last fault is the pump has failed or it is only working intermittently. The new type of modern pump has the armature inside the pump housing and is prone to the seal failing and water can get inside and reduce the inefficiency of the pump.
Mar 21, 2017 | Dishwashers
Error E:25 on bosch dishwasher smv53A00gb/24 what does this mean
E25
Drain pump blocked or pump cover missing
This can be caused by the above or by, as the fault code indicates, a blocked drain pump.
Dado
Feb 21, 2015 | Bosch Dishwashers
Kenmoore dishwasher elite model 66516462300 has no power
There is a thermal fuse inside the door, attached to the controller. But if that part is good, then you may have a fried controller.
Mar 09, 2012 | Kenmore Dishwashers
KENMORE DISHWASHER CODE E25
what is E 25 mean?
Mar 04, 2012 | Dishwashers
Neff dishwasher error code e25
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/PUMP MOTOR/DRAIN to work when it is commanded .If this does not happen then the voltage at these points must be checked or the fault relates to no voltage/drive from the controller. This means the controller is a suspect.
Oct 13, 2011 | Neff 24 in. S5453X1 Built-in Dishwasher
E25 comes on my dishwasher
E25 means Not Draining
I suggest to clean your pump, filter, etc.
Keep us updated.
Apr 20, 2011 | Bosch Dishwashers
What is E25 on my Bosch super silence dishwasher?
I quote same wrong from other user:
Question: Model dishwasher is Bosch Exxcell SMS50E02
It stopped before the end of a cycle with the error code E:25 and the "check water" light came on
I mopped out all the residual water out of the bottom and then ran a rinse cycle, which after several trials I got to work and then it stopped at the end again with the same error code and water in the bottom as before.
Answer:
I assume by in the bottom you mean inside the dishwasher and not in the base.As long as there is no debris in the sump area and the hoses are clear it appears you have a bad drain pump.
Hope helps.
Apr 03, 2011 | Dishwashers
The control panel on my dishwasher is showing a tap and E15
Mine's a bosch, same problem but started with E25 due to broken glass in the pump impeller, after struggling to remove it and then testing, it eventually moved to E15 as rightly so, no water was entering the machine due to the E25 code. The advice above is good, but take the device out first and tip the machine. This cured my faults without the need for a service call or spare parts.
Mar 27, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
207 people viewed this question
Top Dishwashers Experts
Owen Barnes
