Question about Motorola Mobility RAZR V3
Every time I open my phone it starts calling someone and the keys dont work.
  • 157 Answers
do you also hear a key kept pressed tone ?
if yes ! a key is a kept pressed and contact assiagned to the same key is getting called immediately ?
Solution : see a Tech !
Best Regards
Posted on Jun 23, 2009
I got my samsung propel about a year ago. And now the internet buttons and the 2 side buttons dont work, neither does the call button. I cant do alot of stuff on my phone now, and sometimes i call people...
Could be moisture or dust that has accumulated over time under the key pad. Unless you're comfortable removing the cover/shell then you'd want to have someone with the requisite skills to do this for you... but.. you can clean the keypad membrane once you take it apart. There are occasionally some small parts inside, so be careful. (remove the battery first!)
Lay out a clean white towel so you won't lose anything as you work. Use a mild soap solution or diluted alcohol solution to clean the keypad and let dry thoroughly before reassembling. Lightly clean the phone surface (not the plastic or glass screen) if you see anything dirty, sticky, discolored.
Normally I'd advise being careful with this as opening it up will void most warranties, but given that the longest warranty I know of is a year, you're past that point now.
You don't have to have dropped it in water, or had it out in the rain for moisture to be able to get inside of the case. It happens over time to the best of devices.
Dec 18, 2010 | Samsung Propel A767 Cell Phone
Katana II: my keypad doesn't work.
there is a possibility that teh contacts ar dirty or the circuit itself for the keypad is damage.
let me check for parts you may check on to.
Aug 12, 2008 | Sanyo Katana SCP-6600 Cellular Phone
N73: difficault to open message ,dont ring when called,vol adj.
restore your factory setting or hard format your fone,,, to hard format, pres and hold *3 and the send key for 2 mins and ask someone to help switch it on while you still hold the three keys together,,thanks
Dec 30, 2008 | Nokia N73 Cellular Phone
Keys dont work samsung u700
for this u have to replace key pad pcb which is available in any cellular parts shop price app.10$
Nov 20, 2008 | Samsung SGH-E900 Cellular Phone
How to key pad lock sony ericsson z550i?
Dear Freinds,
I have Z550i by mistake it droped in water for 10 minutes. I make it ON after soaking for 4 -5 hours. Now it is goiving humming sound only when we recieve calls (during active network link with other person) from other side or when we dial someone. In simple on condition there is no humming sound. Also it is discharging soon. MP3 songs and radio is working fine. When I put it in charging it shows that your USB port is active and reday to data transfer. I am unable to understand what is the problem.
Please advise a best solution .....
Thanks
Prakash
Oct 05, 2008 | Sony Ericsson Z550i Cellular Phone
System error
it generally hangs when u install new new softwares in it, which is sometimes not compatable with ur mobile platform.
now what u have to do is u have to format ur phone to factory settings that is the only way which is to be done in regard to make ue phone run smooth
sometime when u talk for long hours on ur cell fone , it gets heat up and ur call get automatically disconnected.
u have to reset it which is sometimes dangerous to ur cell phone, it might cause some harm to it.
There r two ways to format ur Cell Phone
1. Soft Core Format
2. Hard Core Format
1. In Soft Core Format u have to dial *#7370#    or   dial  *#7780#     this will format ur phone memory and u have to manually format ur memory card
2. In Hard Core Format ur mobile gets formatted as a tough format,     u have to keep on pressing the three buttons simultaneously(at the same time) for a long period unless u get a screen on ur phone when it asks for the region(ur country).
what u have to do:
1. switch OFF ur mobile
2. u have to press three keys at a time
    Call Button (green key) + * key + 3  at the same time
3. now dont get ur fingers off those buttons , ask someone to switch ur mobile ON (if possible make       ur cell phone placed on some table for stability) (please dont move ur fingers off those three keys       unless u get the screen where u r asked for ur region)
once u got that screen ur cell phone is formatted
NOTE: Formatting the phone with HARD CORE FORMAT METHOD may be harmful if not done in the correct way
Pls Vote for me if this solution works for u
Thank You
Vinay Ramani
India
Sep 02, 2008 | Nokia N73 Cellular Phone
Keys wont work
send it back under warrantee. I had the same problem and let them fix it. They'll have a new phone to you in 2 days and they'll save your contacts and put them on your new phone. Let me know how it works out.
Cindy
Jan 30, 2008 | Motorola Mobility RAZR V3
Seems to be a key mapping problem
I have a pretty good guess.... someone may have intercomed her phone from another station and then pressed the MSG key. This would leave an intercom message and should light up the message waiting light. Then when you press the MSG button you are returning the intercom call. If nobody ever answers the intercom call the return message will not be completed and it will continue to try and return the call whenever you press the button. SO... if this is the case you just need to have someone answer the other phone that is being called and it should start working the way you are used to again.
Oct 23, 2007 | Inter-Tel Axxess Corded Phone
Keys not working
i had the same problem once. I forgot my handy e61 was at the back pocket of my pants while i drove home from work. the keys would work, some of the keys got so pressed that they were stuck, it did took me time to unstock these keys by opening my phone. Just be carefull on opening the phone. pls.
Aug 19, 2007 | Nokia E61 Smartphone
Motorola Mobility RAZR V3 Logo
65 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
