Question about Miele Dishwashers
F 84fault on a miele dishwasher is a slide shutter fault what does this look like will cleaning fix it?
4 Suggested Answers
ngfam1
  • 639 Answers
SOURCE: we have a miele dishwasher
Peace friend,
ngfam1 at your service
Unfortunately I am not there hands on for you !
You will need a good service tech.TO DIAGNOSE THIS ELECTRONIC PROBLEM!
How old is the appliance?
If it is 9 years old or more it may be putting god money into bad!
The new ones pay for them selves in a few years on the savings of energy, and water because they clean better with less water!!!!!!!
A much better n you electric bill!
If you need a good repair Here is who I recommend nation wide.
A&E Factory service open 24/7 for appointments!
1-800-905-9505
Ngafm1
PLEASE GIVE ME THE BEST RATING BEFORE YOU SIGN OFF! BLESS YOU
Posted on Aug 31, 2008
ginko
  • 19396 Answers
SOURCE: on my miele dishwasher G1220
Hi.
The slide shutter is part of the circulation pump assembly. Disconnect pump and check for blockage at pump hose. If that does not help replace the circulation pump.
Regards.
Ginko.
Posted on Feb 19, 2011
  • 251 Answers
SOURCE: Miele LaPerla Dishwasher showed fault
Hi - I have not come across a fault code F147 on a miele dishwasher, the highest being F112, are you sure its not F47 instead, this relates to a faulty electronic controller unit.
From what I know of LaPerla the model G2830 series and even the faults does not have a F147 amongst the chart.
Posted on Jun 15, 2011
Miele Fault Code F84
Slide Shutter Positioning Fault
Miele Fault Codes
If a F84 is displayed (Slide shutter positioning fault)
The electronic board is unable to read the position of the slide shutter through the position switch. This fault is displayed when attempts to position the slide shutter have failed. See F63 (Slide shutter fault) for troubleshooting steps.
Miele G1000 Technical Information Page 219
Occasionally our Miele Dishwasher pops up with a F84 error mid-cycle and stops. I've checked filters, discharge pipes, etc.
An post in the Whirlpool archives had links which suggested the fault was to due to an internal "slide shutter valve".
http://appliancehelponline.com/miele.html
So you can read your self a link to the post; whrl.pl/RbrkDJ
I finally found a small object lodged in the ball-check-valve on the discharge of the water pump. Once removed all has been ok.
To access the check valve, remove the screen at the bottom of the unit. under the screen to the left of the water well is the cover of the pump. It has two small plastic "leaves". grasp, squeeze together, and push to the right, towards the centre of the water well. You will have removed the pump discharge and within it are rubber seals and a stainless steel ball. You can peel out the black rubber seal remove gunk and refit. Take care not to damage the seal and to replace it fully.
http://forums.whirlpool.net.au/archive/2140916
Dec 06, 2017 | Dishwashers
How do I fix a Miele G2470 SCVi with an intake/drain fault
Look for item(s) blocking the drain, inside bottom, and remove them.
May 24, 2014 | Miele Dishwashers
Miele LaPerla Dishwasher showed fault code F174 at 27 hours operation. How can I get a copy of the Miele fault codes? I pay for Remote Monitor and did not receive an alert. What is fault code F174?
Jun 08, 2011 | Miele Premier-Plus Built-in Dishwasher
F84 error on miele dishwasher G2534SCI
Hi
On that model to save water and energy water is sent to bottom and middle spray arms alternately. This is done via a shutter in the circulation motor. F84 mean this shutter is jammed,Most likely with debris,But is possible motor is faulty
The motor will have to be removed be sure
Jan 14, 2011 | Miele Premier-Plus Built-in Dishwasher
My dishwasher stops and flashes up F85 can you tell me what this means please?
Fault code F85: Slide shutter signal change fault.
Defective shutter system, inside circulation pump. Circulation pump needs to be replaced.
Oct 05, 2010 | Miele Premier-Plus Built-in Dishwasher
Miele dishwasher had F85 on the screen
Hi
On that model to save water and energy water is sent to bottom and middle spray arms alternately. This is done via a shutter in the circulation motor. F85 mean this shutter is jammed,Most likely with debris,But is possible motor is faulty
Apr 28, 2010 | Miele Premier-Plus Built-in Dishwasher
My miele dishwasher is not draining completely after i rum the "normal" cycle. what can i do to fix?
It is probably a drain fault. Try checking the drain spigot at the sink end where the drain hose connects as these are usually the cause of most dishwasher faults.Or else try checking the airgap at the top of your sink, if nothing there then check the end of the drain line usually connected to the garbage disposal if you have one. I would reccomend disconnecting the end of the drain line and putting it into a bucket. Let the dishwasher run for 30 seconds and if it drains then its a problem with your garbage disposal. If not contact Miele technical support nearby to troubleshoot the fault code
Apr 06, 2010 | Miele G892SC SS Dishwasher
F84 Error code Miele
This problem arises because the water inside the washer cannot get out.
Firstly......Make sure the salt cover if screwed on tightly (if you have one).
Then remove the filter(s) from bottom of the washer and clean.
Remove the drain pump cover and remove the one way valve (a ball bearing in a housing) and clean. Take note of rubber cover direction before pulling it out to clean.
Make sure the impeller (visible after you remove drain pump cover) is clean and spins ok. It will have a little resistance as you spin with your finger.
Make sure all is cleaned properly and it will all work fine again after replacing it all back in.
Jul 27, 2008 | Miele Premier-Plus Built-in Dishwasher
Dishwashers Logo
157 people viewed this question
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
