Kenny longenette2112 went to sine in
Generator burning my electronics up
take you generator in and have the output tested for correct voltage and sine wave configuration
electronics rely on a perfect sine wave ac current as a manufactured sine wave affects electronic components such as capacitors, transistors and diodes
generator sets that run an alternator ( not an inverter ) have a pure sine wave and have less affect on electronics.
go google and type in search headings like ---sine wave, inverter sine wave, sine wave affects on electronics, alternator operation and inverter operations and then you may get a pointer as to why your inverter gen set is affecting your electronics
Jul 23, 2016 | Honda EU3000iS Inverter Generator
Looking for Kenny Chesney "I
Kenny Chesney - I will stand
http://tabs.ultimate-guitar.com/k/kenny_chesney/i_will_stand_crd.htm
Kenny Chesney - When I'm Gone
http://tabs.ultimate-guitar.com/k/kenny_chesney/you_had_me_from_hello_crd.htm
Albert Hamond - When I'm Gone
http://tabs.ultimate-guitar.com/a/albert_hammond/when_im_gone_crd.htm
May 10, 2011 | Computers & Internet
I'm trying to do inverse sine and cosine equations but I'm receiving a message that there is a domain error. Is there anything I can do or press like a reset button?
The inverse sine and cosine equations mean "angle who's sine/cosine is:" The bounds of the arguments for these functions must be between 1 and -1, the maximum and minimum values of the sine and cosine functions, because no angle can have a sine or cosine that is greater than 1 or smaller than -1. Also it should be noted that the inverse sine/cosine function is not the same as 1/sine or 1/cosine, although the symbol makes it look like that.
Mar 08, 2011 | Texas Instruments TI-84 Plus Calculator
When sining in i went and tolde my frend and she was on but i went on and my frend said i was offline'';
Go to the oovoo tab and change your status from offline to online.
Feb 01, 2011 | ooVoo
Hello is this ups a sine wave output or modified sine wave output. Thanks
The manual states when running on AC, it is the same sine wave ouptput that comes in. When running on DC, it is a modified sine wave.
Nov 30, 2010 | Opti -UPS BackUp-Time 525BT (UPS-525BT)...
I bought a new Black and Decker 200 watt power invertor to plug into our car cigarette lighter to power a laptop. We did this and our car blew a fuse. We went to Saturn to fix it and they could not...
Most power inverters supply a modified sine wave output. This is different from the true sine wave you get at home. It's close enough for many applications, but not close enough for many transformers, which is what your laptop power supply is. So the problem is that your laptop's power supply does not work with a modified sine wave input. Some will, some won't. Very common problem.
Aug 23, 2010 | Black & Decker Electronics - Others
BMW 325i 2001. Hi the flashing indicators work on both sides but no noise or light from the dashboard regards Kenny
Yes prob solved. When the battery went low the transient generated when I tried to start it caused a glitch in the computor management system and I reset it by removing and reconnecting the battery. All now working.
cheers
Kenny
Nov 12, 2009 | 2001 BMW 325
Monitor 2400 heater will shut down when I run My generator
A UPS unit might work. Electronics need steady clean power.
Dec 18, 2008 | Intel CASE 350W PWRS ALLIED W/ 24PIN +...
Is true sine wave better than modified sine wave.
I'm not sure what the application is but I will offer the following. As a retired electronics engineer i can say for sure that a true sine wave does not have any harmonics in it. A modified sine wave will have some harmonics and other what I would call " trash content" depending on how it is modified.
Loringh
Nov 16, 2008 | Xantrex Technology RS400 Sine Wave...
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
