Question about Kawasaki Engines NEW 19 HP KAWASAKI ENGINE FH580V-DS29-S REPLACE KOHLER BRIGGS ZERO TUR
What is causing my kawsaki 580v to smoke
When I start my toro z turn w\ a Kawasaki 19hp 580v it blows white smoke from the exhaust. is it the rings or something else?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
You check the oil with the dipstick resting on the tube, not screwed in
then check your fuel supply as it might have water in it
then remove valve covers and see if you have a valve guide seal that has moved
Posted on May 17, 2014
Lawn mower blowing smoke
You are burning oil. This usually is from a leaky gasket. Go to ebay and find kiddie boutiques. They sell the best quality cheapest new tecumseh gaskets
Sep 27, 2014 | Garden
Blueish white smoke comeing from exhaust
Hello There
White smoke when first started is normal. If white smoke continues you have an internal coolant leak, i.e., cracked head/blown head gasket.
Black smoke is caused by a rich fuel condition.
Blue smoke is caused by oil consumption.
You need to check your oil cap for yellow/white gunk on the cap if you have this then this is a sign your head gasket is cracked. Check to see if your radiator coolant level is down this is also another sign.
Hope this helps. Please don't forget to rate me.
Many Thanks
May 20, 2009 | 2004 Chrysler PT Cruiser
Have oil spitting out of carb and dip stick fill tube just started doing that on 19 hp kohler courage
if engine is not overfull you have bad rings on piston have to take in to have it done may end up short blocking it witch is cheaper to do replace rings cheaper by far 200.00 per cylinder
Sep 14, 2014 | Garden
My toro fh 580v smokes when i start it what is causing it to smoke?
hi.. your inlet valve stem seals are worn out, so oil will be drawn into the inlet with vacuum , as well as fuel...this is why it smokes on start up...quick fix , do an oil change but use a car oil like 15W40 weight oil
im sure you would be using a 10w30 oil now ,using a thicker oil might stop the smoke on start up, or it just wont smoke as much, regardless of using a thicker oil...the valve stems will still need to be replace.....good luck
May 16, 2014 | Toro Zero Turn Rider 74833 Lawn Mower...
White smoke coming out of my yamaha 2008 r6 whenever i start the bike. why is the white smoke coming out ?
Hi, Anonymous your instrument gauges and lights can alert you to most electrical and engine issues they can not warn you about failed engine gaskets or seals so your engine has to resort to old fashion alert methods of colored "SMOKE SIGNALS" here is a breakdown of their meaning:
1. WHITE SMOKE on start-up can is usually caused by a blown head gasket allowing coolant to enter the combustion chamber and may start dripping out of the exhaust pipes or mufflers.
2. BLUE SMOKE on start-up is usually caused by failed valve seals. Smoke that is constant while riding is usually caused by valve to guide and piston ring clearances that have exceeded service wear limits.
3. BLACK SMOKE on start-up is usually caused by too much fuel in the combustion chamber this can be due to air/fuel mixture adjustment too rich, accelerator pump improperly adjusted, faulty choke/enrichner or not in the off position, faulty carburetor float needle and seat, pilot jet too large, fuel injectors leaking, smoke while riding is usually caused by the main jet being too large.
It should be noted that aggressive or abnormal throttle operation will cause these conditions to manifest themselves exponentially.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.r6-forum.com/forums/57-garage-mechanical-help/205697-white-smoke-exhaust.html
White Smoke Coming Out My Exhaust Please Help
2008 2009 Yamaha YZF R6 Service Manual R6 Moto Data Project
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 28, 2012 | 2008 Yamaha YZF-R6
Have a toro self propelled. The engine cuts off as soon as it starts and prior to that it was blowing white smoke. It looks like there may be oil leaking under the exhaust, but can't tell where i
It could be that gas is filling the carb because the needle is stuck open. The excess can drain into the engine oil. If you check the oil and it's overfilled and runny, then you need to overhaul the carb and change the oil.
Oct 10, 2017 | Garden
I have a 05 Toro 44in ZTR with a 19HP Kawasaki engine with under 300 hours the main 30amp fuse keeps blowing when I turn on the ignition switch on. I noticed when I disconect the PTO switch the fuse dousnt...
sounds like your electric clutch is prob bad check to make sure wires are not bare touching something, the clutches do go bad eventually like any other electrical part, disc the pigtail and try fuse, if it blows then I would consider a clutch
Jul 27, 2011 | Toro Zero Turn Rider 74833 Lawn Mower...
Have a toroZ5035 mower 90 turn) with kawasaki engine. **** smoke appears on start up, but goes away when warmed up. choke must be kept on at least halfway or motor dies. changed plugs and cleaned air...
**** smoke sounds bad, If what you meant was white smoke then I know what is going on with the mower. The white smoke is from the extra oil in the cylinder head. There are tow causes for this. #1 the engine rings are worn and will not prevent the oil from running into the combustion chamber as the engine sits. #2 the carburetor is leaking fuel into the oil and thinning it out. This thin oil bypasses the rings easier and drives the oil level up too. I would recommend a carburetor rebuild. You can get parts from a local dealer like www.arcolawn,com Good luck barterjoe_64.png
Mar 23, 2011 | Toro 52" 27hp Z Master Zero Turn Lawn...
I have a Toro Zmaster mower The engine is a FH580V KAI19. It was running fine. Parked the mower last night, tried to start it today and oil is coming out of the OHV cover and blowing by through the...
you could have a broken piston ring. check the oil level. if it is ok or low and still smokes or hard to start then you may have to overhaul the engine. let me know what you find.
Mar 13, 2011 | kawasaki Garden
I have a toro z380 zero turn. when you start it it will run fine for a minute then bog down real bad and blow out smoke really bad then it will run fine for a few seconds and do it again. it appears to be...
You may need to look at your rings as the oil ring on the piston may need replace your rings could be done how old is the engine if you ring me on 07849461942
Sep 23, 2017 | Briggs & Stratton Garden
Kawasaki Engines NEW 19 HP KAWASAKI ENGINE FH580V-DS29-S REPLACE KOHLER BRIGGS ZERO TUR Logo
532 people viewed this question
Top Kawasaki Engines Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Kawasaki Engines Garden Expert? Answer questions, earn points and help others
