Question about Dell Dimension 2400 PC Desktop
Clean a fan on dell 2400 inspiron desktop computer
How do I open the computer and clean the fan?
  • f_west_lt Jun 06, 2014
    this is for anonymous from May 16, 2014
    Problem Solver:
  • 4 Answers
Okk, ann,may 16 2014. face back of ur pc, on the right hand side of pc U will see a knob like 4in up. it looks like a (L) written backward. just move it down (make pressure) at the same time the panel on that side has two indents pull the panel back using them .
don't rush it , take ur time ,piece of cake and happy clanning.
Posted on Jun 06, 2014
    ohh, and to clean the fan . go radio shack or best buy or simillar store get a can off compress air .let them know the porpuse .
SOURCE: Dell Dimension 2400 PC Desktop CPU Fan Suppose To Blow?
Blows air into the case away from the cpu.RICHARDM69...This is a solution please vote as such.
Posted on Dec 20, 2008
the_fire
  • 432 Answers
SOURCE: Dell Inspiron 2400 Add RAM and Vid card?
If you go to http://www.crucial.com it will detail exactly what type of memory you can have and in what configurations and how many memory slots and you can purchase your memory there as well.
Posted on Apr 10, 2009
  • 53 Answers
SOURCE: Dell Dimension 2400 desktop
http://support.dell.com/support/edocs/systems/dim2400/en/sm_en/rmvcvr.htm
The above link will show you step by step :)
Posted on Jun 15, 2009
RonPark
  • 855 Answers
SOURCE: Green LED on Dell Inspiron Desktop 530 - all OK?
Yes, on most desk top the green light in the back tells you that you have power to the cpu. Even though the unit is off it is telling you that the current supply is still there. This is a good feature if you move your unit as soon as you plug it in you know if the outlet is on or not.
Posted on Oct 17, 2009
joecoolvette
  • 5660 Answers
SOURCE: how to install fan in dell 2400 desktop computer
Rear computer case fan?
This is going to be a fairly long solution. Advising you in advance.
1) Computer off, and unplugged from power.
2) Open the computer case, TOUCH the metal frame BEFORE you reach inside. Your body carries Static electricity. Touching the metal case will relieve your body of Static.
3) Remove the Processor Air Shroud.
This is the plastic U shaped part that covers the Processor, and Heatsink. It's at the back of the computer next to the computer case, and the fan in the rear.
First, unplug the fan's power cable from the motherboard connector.
(J30 connector on motherboard.
In-between Ram slot 1, and the Processor)
Second, you may have to disconnect the power cable for the Processor, in order to remove the Air Shroud. Disconnect the Processor power cable from the motherboard.
(J10 connector. Square connector on the motherboard to the left of the Processor, and down. There is a power cable from the power supply that goes to it, with a square connector, and has four wires in the cable. Two Yellow, two Black wires)
You may have to disconnect the 20-pin ATX main power cable also, in order to have room to remove the Air Shroud.
(J21 connector on motherboard. Long connector with 20 socket holes in it. It's on the outside edge of the motherboard, to the right of the ram slots.
The power cable connector is a Male connector. The connector on the motherboard is a Female connector.
The Male connector has a lock tab on the side of it. The tab is hinged so that it pivots. The top of the tab is squeezed in to release the lock.
This action draws a hooked end of the tab, out of the Female connector on the motherboard. While keeping the tab squeezed, the Male connector is gently wiggled side to side, while pulling up, and out.
Do Not pull on the wires, pull on the Male connector only. Use a gentle force)
The Air Shroud is gently squeezed in on the sides, with your fingers, and thumb. (Side that is towards the Front of the computer)
Then the side of the Air Shroud that is towards the front of the computer, is lifted up.
The Air Shroud pivots towards the rear of the computer.
The Air Shroud pivots on two round pins. Pins are made into the plastic shroud itself.
Each side of the air shroud, is gently pried out on the bottom where the round pivot pin is, and this action draws the pin out of the rear fan's mounting flange.
Remove the Air Shroud, sit it aside.
Now you can look more closely as to how the fan's mounting flange is attached to the computer case.
At this point I cannot lead you directly, only guide you.
The fan's mounting flange, may have small flat protrusions coming out of it, that go through the rectangular ventilation holes, in the rear of the computer case.
The flat protrusions has a hooked end on them, that hooks on the edge of the ventilation hole. Usual style, requires that you push the hooked end, towards the inside.
(Reference is made in relation to the outside edge of the computer case. The hooked end is pushed towards the middle of the computer case)
It may be a style of mounting flange, where the flange's edge has a lock tang that sticks up.
This lock tang is part of the plastic mounting flange itself.
The lock tang is depressed towards the computer case, and the fan is slid up, and out of a metal bracket.
(May be more than one locking tang)
Observing the mounting flange for the fan, you should be able to see how the fan itself, is attached to the mounting flange.
Usually it's another form of locking tang that is used.
The locking tang, or tangs, are depressed, and the fan slides out of the mounting flange.
If you did not buy a replacement fan directly from Dell, (Don't even know if you can), observe the fan's power cable connector.
Observe where the wires go in the connector. Look at the color code of the insulation of the wires. Match this wire color code, to the original Dell computer case fan.
Are the wires in the same place as the Dell fan?
If not, tell me. Post in a comment.
Posted on Jan 24, 2010
My dell inspiron 2400 pc will not start up
If the power light doesn't come on at all, it could be the power supply is dead, or the power switch is defective.
Check to make sure the power cord and power supply cables are securely connected.
Here are some diagnostic tools for DELL computers.
http://www.dell.com/support/Article/us/en/19/SLN284978/EN#2012_to_Present
May 19, 2014 | Dell Dimension Computers & Internet
Dell Dimension 2400 Keeps Shutting Off
its smps problem...if u want clean ur cpu read ur dell guider ....
Jul 24, 2012 | Dell Dimension 2400 PC Desktop
Dell dimension 2400 fan replacement
it is very easy just remove the plastic cover from the fan & lose the screw and replace the fan with the new one
Feb 27, 2012 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 desktop I had a blue screen and reinstalled windows, and that fixed it. I was then able to use my computer for a day. And now it shuts off and turns on all by itself repeatedly? I am...
This Usually happens when the heat sink fan is not working open the computer and make sure the fan is spinning if it is not you will have to replace it.
Jun 04, 2011 | Dell Dimension 2400 PC Desktop
I have a dell dimension 2400 and there is a noise. It's not coming from the poser supply or the cooling fan. It's coming from that large rectangular metal above the microprocessor. But I am not sure. The...
It may be from processor cooling fan fixed over heat sink ( ie large metal rectangular with fins).clean heat sink fins and fans.extreme case fan to be changed by service technicians
Feb 15, 2011 | Dell Dimension 2400 PC Desktop
1) How to you open the cpu case to get to the fan, etc. 2) My fan has started making noises......can it be cleaned - or is it likely to need replacement?
Things You'll Need:
  • phillips Screwdriver
  1. Shut down your Dell desktop computer.
  2. Remove all of the power and peripheral cables from your computer. There should be no cables connected to your computer when you attempt to remove the cover and open the case.
  3. Watch for the green "Power" indicator light to dim. This light is on the back of the case near where the power cable plugs in. Your computer will hold onto an excess amount of energy for a few seconds after it is unplugged. You don't want to open your Dell computer case while this light is still lit.
  4. Use a screwdriver to remove the screws holding the side of your Dell desktop computer's case. Set the screws aside.
  5. Use your hands to pull up on the side of the case, separating it from the base of the computer. This will allow you to access the inside of your Dell desktop computer.
Jan 23, 2011 | Dell Dimension 2400 PC Desktop
Dell desktop won't boot up get blue screen and beep when I turn it on
overheating most likely. If you can, open computer up and make certain bios and cpu heatsinks (aluminum R2D2 looking things often with fans on top) are firmly seated on board with maufacture latches. Also see that teh fans are all working, could be a non-operating fan.
Oct 29, 2009 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 PC Desktop Logo
Alun Cox
