Just bought brand new whirlpool top loading commercial washer and dryer with the coin sli
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 59 Answers
I think the answer is in the question....
you have bought a machine for multiple users (apartment. camping sites)
did you get a key for the coin box?
if so. just keep coins handy run them through the coin-op.
otherwise, you may need to employ an electrician to bypass it
Posted on May 31, 2014
4 Suggested Answers
SOURCE: whirlpool coin operated washer and dryer
you need to take the coin slot out by using a socket wrench. then you need to flip the slot over and take the screws off. there is going to be two more screws to unscrew. take off that piece and also the claw like coin catcher. form here on out you should be able to remove as many slots as you need to.
Posted on Feb 15, 2008
  • 111 Answers
SOURCE: Just bought brand new commercial coin operated
maybe when you were moving it, one or more of the springs that keep the drum centered came off,unhook everything,drain it,tip it over face down on a piece of clean carpet, make sure everything is in order,all supports are in place, 2 people to tip it
Posted on Jan 31, 2010
blueextc3221
  • 15935 Answers
SOURCE: Whirlpool front loading washer and dryer F28 keeps coming up
F28 is a serial bus error from the CCU (Central Control Unit) to the MCU (Motor Control Unit).
All you need is some Electronics contact cleaner spray and a 1/4 inch socket to remove the top of the machine and the back of the machine.
The CCU is the computer looking box at the top front right hand corner.
Find connector M13, (has red marking on it and only 3 wires) disconnect it by pushing the retainer tab back and pulling gently on the connector.
Spray the contacts of the connector and computer with connector cleaner.
Then re-assemble connector.
The MCU is in the back lower left corner.
Find the connector with 3 wires and red mark, and remove this connector in the same way you did the other, spray it and re-install.
Put the back and top back on.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Posted on Sep 28, 2010
Whirlpool commercial top load coin washing machine with only Luke warm water
i would take hoses off washer and check screens infill valves first.valve may have a thermister in it to control water temp this may be bad.may have to call a tech.
Dec 10, 2013 | Whirlpool CAM2752RQ Coin Operated...
Just bought brand new commercial coin operated washing machine top load...everything is level tried washing a load and at the spin cycle the machine vibrates so bad it seems like it's going to take off. ...
Jan 31, 2010 | Whirlpool CAM2752RQ Coin Operated...
Timer located on the dryer
it is under the service door on the top or the coin vault. it is located just behind the coin chute
Dec 04, 2009 | Whirlpool CEM2760KQ Electric Dryer
I just bought a house that included in the sale a Maytag Coin-op Washer and Dryer. The coin box on each contains a key. How do I disable the need for putting coins in the washer and dryer so that I can...
  1. purchase a coin insert and blank the slot that coins fit in, then the slide will slid in without coins, just acting like a button, if you examine the slide you wil notice that there are plastic inserts in unused coin slots, any maytag commercial dealer has them.
  2. replace coin slide with 'free operation' converter, which is just a button plate that pushes the striker on the timer switch
  3. take top cover off and just push the striker on the timer, (this is NOT) a recommended option, 220v is enough to spoil you whole day)
Oct 24, 2008 | Maytag Washing Machines
Coin operated machines: slide mechanism is not moving back.
I had a coin washer and dryer.The slider has little fingers(metal)that slide over the coins.If the coin isn't placed and the slider is pushed hard will jam. Mine had a side cover with a lock. Open that and there is a long rod that has to be unscrewed to remove the lock box,then you should is what went wrong.Hope this helps>
Jul 04, 2008 | Whirlpool CAM2752RQ Coin Operated...
Whirlpool coin operated washer and dryer
Sep 06, 2007 | Washing Machines
Washing Machines Logo
126 people viewed this question
Top Washing Machines Experts
