Question about Carrier 38CKC036 Air Conditioner
Carrier 38CKC036 compressor will not cycle after initial run.
When i turn the unit on it will cycle for the first event and as normal. Once room temp calls for cooling the condenser fan will come on but the compressor will not. Contactor is energized so i think it may be the pressure on the high side is not equal to the low side? it takes about 30 minutes before the compressor will come back on. Unit is 10 years old, should I just replace it with a newer unit?
Does it have a low pressure switch. It sounds like it is a pressure switch issue
Posted on May 17, 2014
Testimonial: "Well it turned out to be the capacitor for the compressor. Thanks again for everyones help on this site."
  • 82 Answers
SOURCE: I have a Carrier 38CKC036 Air Conditioner
Hello, this is one of 2 items...the motor itself, or the start capacitor. The capacitor is responsible for boosting the motor to get it started. Follow the wires from the motor and they will lead to an oval or round cylinder. Check the cylinder for any bulging or leaking oil. When the motor should be running, reach in with a stick or ruler and try to assist the fan to get going. If the it feels resistant...it is most likely bd motor. If it trys to start and feels smooth it is most likely capacitor.
Posted on May 13, 2010
Testimonial: "It was the capacitor."
james3751
  • 614 Answers
SOURCE: Possible Contactor Issue
Sounds like a bad fan switch in your unit. That unit has a fan board in it that is time delay on and off. Turn the fan to the on position and let it run all the time. If it keeps temp and does not shut off it is the fan realy board. The board also controls the compressor. Check that first and then the tsat. Russ
Posted on Jul 24, 2009
  • 148 Answers
SOURCE: UNIT RUNS AN EXCESSIVE AMOUNT OF TIME AND AIR IS
DOES THE HOUSE FEEL DRIER IF IT IS 80 OUTSIDE WITH ALOT OF HUMIDITY THE UNIT WILL RUN FOR A LONG TIME TO REMOVE THE MOISTURE(HUMIDITY) OUT OF THE HOUSE BEFORE TEMP DROPS DRAMATICALLY IS THERE WATER COMING OUT OF THE DRAIN PIPE OUTSIDE
Posted on May 03, 2009
SOURCE: 24ABR348A0031010 compressor starts then stops.
Hello RR Hard start can't hurt BUT dosen't sound like the problem.Do you have a scroll compressor?They don't need a kit.Does it start every time?It could be short cycling on LOW PRESSURE SWITCH.If the unit is (pumping down) during the run time you have a restriction in the system.Make sure the service valves are open ,do you have a filter dryer colgging up or a bad TXV valve also could cause short run times.20-30 PSI the switch cuts out.
Posted on Jul 15, 2010
  • 157 Answers
Yes, you need a new fan capacitor, assuming its wired correctly. don't let compressor run without fan
Posted on Jun 22, 2011
Which capacittor to use with this unit? Carrier 38CKC036 Air Conditioner
depending on compressor it would be 40uf to 45uf 370v; 5uf/370 for the outdoor fan motor
Aug 01, 2011 | Carrier 38CKC036 Air Conditioner
ON excessively hot days, the outside heat pupmp trips the circuit breaker. Most times it is only once, I turn the breaker to "on" and it works fine. Some days it pops two or three times. When the outside...
Hello I would add a HARD START KIT to the run capasitor (if there is not one already).This makes the compressor come on easy.If the breaker trips during running time the pressures are too high,hose off the condenser coil (fins).The unit might be slightly overcharged but I would be careful before adjusting the freon at all.
Sep 02, 2010 | Carrier 38CKC036 Air Conditioner
AC running inside but outside unit not....keeps blowing breakers
Hello my name is Heath it will be my pleasure to assist you. The compressor is locked up. What you could do is try a hard start capacitor on the unit which would probably get the compressor turning without blowing the breaker.
Apr 27, 2010 | Carrier 38CKC036 Air Conditioner
Jul 24, 2009 | Carrier 38CKC042 Air Conditioner
When unit starts the condensor fan only comes, not compressor
You need a new fan motor and the correct capacitors for your sydtem I think they are 35 or 45 5 cap. Try a hard start kit on compressor. Are you sure you have the cap wired correctly?Russ
Jul 16, 2009 | Carrier 38CKC036 Air Conditioner
Compressor fan cycles on and off .1986 carrier mo#38eh0363300l
Usually compressors cycle on and off due to the low preasure switch which disconects the compressor when their is a freeon leak. Put the gages on it and see if the preasures are correct.
Jun 26, 2009 | Carrier 38CKC036 Air Conditioner
Carrier Comfort 13 Puron model 24ACA3 / FV4NB006 installed 3/18/08 no longer cooling. Carrier AC1-100 Thermostat checked per manual - all default settings intact. Test override did not turn unit on though....
Verify 24 volts at the low voltage transformer inside the air handler. If it is OK, jump out the red/green and yellow thermostat wires. If everything comes on, replace the thermostat.
Jun 07, 2009 | Carrier 38CKC036 Air Conditioner
Carrier central ac model 38EN036300
If you have an electronic thermostat, they can short out, leaving the compressor running. Also, the big relay that runs the compressor can get its contacts welded together. See if the contacts are stuck closed.
Jul 27, 2008 | Carrier 38CKC036 Air Conditioner
1 1/2 years old 5 tons leaking yellow rusty water
Most likely yours has a scroll compressor which are notorious for being quite loud on start they will start for years, just a liitle noisy. Is the water from the pvc drain or from the base of the outdoor unit??
Oct 02, 2007 | Carrier 38CKC036 Air Conditioner
Carrier 38CKC036 Air Conditioner Logo
63 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
