Question about Raypak Pool & Spa
My blue essence controler says is working ok but the pool is not generatig cholrine
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Raypak Master
  • 1,448 Answers
Crack union after cell check with test strip if shows chlorine your pool might have phosphates and is using up the chlorine if so super shock pool that should solve your problem if chlorinator is not working try cleaning sensor and cell 4 parts water 1 part muriatic acid
Posted on May 26, 2014
P1353ME Intermatic Pool Timer starts and then stops
sounds like you are working with 220 2 blue are two hots across the two you should get 220 volts each of the greens and green should only give you 120 volts make sure unit can be wired 220 volts
Jul 05, 2015 | Intermatic P1353ME Timer, 3-Circuit Pool &...
How do I clean blue essence saltwater generating cell?
clean cell in a 4 parts water and 1 part muriatic acid solution
Sep 13, 2014 | Pool & Spa
Hayward H250FDN blue temperature control will not respond (MODE and RED up button are OK)
up and down button at same time with either mode or enter at same time for seven seconds that should unlock
May 16, 2014 | Hayward H250FDN Low NOx Natural Gas Pool...
Blue haven bh6100
wire to the house controller has been cut or plugs at aqualink or controller wires touching if all ok then check controller at aqualink with cheater cord cut some off wiring on inside of cover if still doesn't work bad bezel board
Jun 20, 2012 | Jandy AQUALINK RS TELELINK KIT
My Mr Zippy moves throughout the pool, but constantly gets "stuck" against the wall.
With these pool cleaners, I would first check your Star Control settings. It could definitely be a problem with your flow. Blue or black means insufficient flow (increase flow by turning clockwise until the black indicator line aligns with the yellow area on the indicator gauge). Yellow is optimal and orange is slightly high but may be ok for larger pools. If you are getting red, your flow is too high and is driving the cleaner into the wall area. Turn the star control counter-clockwise until the black indicator line aligns with the yellow area on the indicator gauge.In addition to flow, check for hose memory and to make sure that the hose floats are evenly spaced. Assure that the nozzle assembly swivels freely.
Apr 25, 2011 | Zodiac Baracuda Zippy Pool Cleaner
When I turn on the pool, the pacer works for about 5 minutes then just gets stuck on the wall. If I turn off the pool and reset, it starts again then stops. How can I decrease the suction or adjust the...
You need to use the Pool Pulse feature to control the flow of water through the cleaner. Here is a brief overview, but if you need more details, consult page 6 of the users manual for this pool cleaner (below if you don't have it).
"Remove the cleaner head. Attach the Pool Pulse to the end of the hose and keep it under water. Turn on the filtration system.
• For pools with one skimmer, flow is automatically regulated by the Flowkeeper Valve. Insure the blue indicator of the Pool Pulse is in the ideal range (when viewed from the side).
• For pools with two or more skimmers, leave the selected skimmer open and slowly close the other skimmer(s) until the blue indicator of the Pool Pulse moves into the ideal range (when viewed from the side).
• For pools with a wall vacuum fitting, leave the wall vacuum fitting fully open and slowly close the skimmer valve until the blue indicator of the Pool Pulse moves into the ideal range (when viewed from the side).
Keeping the hose under water, remove the Pool Pulse. Submerge the cleaner head, and when the bubbles stop coming from the extension pipe, attach the hose end. Your installation is now complete."
http://www.baracuda.com/resources/manuals/PacerW83410.pdf
Dec 05, 2010 | Zodiac Pacer Pool Cleaner
The heater come on and cycles on and off, but the water no longer reaches the correct temperature. Pool techicina has replaced the thermostat and disassembled and cleaned something, but it still will not...
This could be the flow rate / value...maybe the unit is under rated in its BTU value. But if it did work fine and heat the water ok then its not this...next thing would be the system control switches...each of these needs to be tested one by one to see if it cutting out the system too early...failing that it is the flame being produced and the heat value is cold see if the flames are blue or yellow...blue is fine nice and hot yellow is too cold to heat the water passing through
http://www.laarsman.co.uk
Miles
Jun 05, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Pool & Spa Logo
50 people viewed this question
Top Raypak Pool & Spa Experts
Bill Jordan
paulcarew
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
