Question about Samsung L100 Digital Camera
Samsung L100 cant figure out how to charge!!! Adaptor supplied but no battery charger to plug in to mains. Do I need to purchase a battery mains charger???
No! your camera was suppose to come with the usb and the charger top.. you should go back to the store and tell them but until then you can charge your camera with the computer and the usb drive
Posted on Jul 10, 2009
  • 56 Answers
You can charge the battery through the camera like a cellphone.
plug the USB cable to the ADAPTER then plug it to a wall socket then plug the USB cable connected to the AC power adapter to your camera
the USB cable should have an indicator (RED) if it is already charging and (GREEN) when its done
Posted on Jul 03, 2009
  • oohlalarr Nov 03, 2010
    Do you have the 'quick start guide' ? This boklet explains iot with diagrams!
How to charge tab on 12 volts?
why are you trying to destroy your phone it runs on 5 volts and charges on a maximum supply of 7 volts
if it hasnt stopped yet it soon will go to tescos by the charger you need fort a few £s and have a long and happy relationship with your main meens of comunication its not built to take 12volts in the same way your not built to handle 250volts
Nov 26, 2014 | Eforcity CAR CHARGER PLUG FOR SAMSUNG...
Hi, I have a Dell Inspiron 1501 laptop, model no. PP23LA. My problem is that the system does not recognise the power adaptor/charger & will not charge the battery. The laptop will run with the power...
If the battery is not charging, the problem is most likely the battery...not the charger. Check around to see if you can get a battery replacement I think would be your best course of action. If you have a friend with a model laptop with the same battery you could always "test out the scenario" before purchasing one.
Good Luck
May 19, 2011 | Dell Inspiron 1501 Notebook
My laptop was fine last night. i always use it on the charger but needed to take it off and use it. i did so and it ran out of battery so i put it on the charger but then it shut down. i just thought ill...
Remove the battery and mains adaptor. Press and hold the power button for a few seconds. Replace the battery and plug in the mains supply, press power for a few seconds and it should start up.
Aug 31, 2017 | Acer Gateway NV5814u Notebook
I can't get it to charge
This is typically caused by one of two issues:
  1. (Most likely) The battery has failed and needs to be replaced. If the battery is older than a year and seen heavy use or been plugged in to the charger for long periods of time, this is likely the problem. Verify that the power adaptor is not bad (below) and purchase a new battery from a local retailer or online.
  2. The power adaptor is bad. Plug in your power adaptor and verify that the power LED is lit. If it is not, then it is bad and will need to be replaced or alternately, you can purchase an inexpensive external battery charger. They are available online or often from your local retailer.
A couple good sources for batteries/chargers:
http://everydaysource.com
http://www.all-battery.com/
Hope this helps.
-Tor
Dec 12, 2009 | Sony Handycam DCR-PC9E Mini DV Digital...
Over loaded via 12volt mains adaptor
at great expense cheaper to buy a new one
Jul 31, 2009 | Tomtom RIDER GPS Devices
CANT LOCATE CORRECT CHARGER
Howdy,
Most office supply stores and home supply stores, Office Max, Office Depot, Staples, Home Depot, Lowes, carry a Universal AC Adaptor that has multiple voltage settings with multiple plugs that fit a variety of low voltage charger connections.
Dec 11, 2008 | Peg Perego 12 Volt Rechargeable Battery
I cant turn it on =/
Go to https://www.p4c.philips.com/files/p/psa615_05/psa615_05_dfu_eng.pdf
to download manual.
You can also download the driver software from
https://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?slg=ENG&sct=PORTABLE_SPORT_AUDIO_SU&cat=MP3_PLAYERS_CA&grp=PORTABLE_ENTERTAINMENT_GR&session=20080429150746_91.107.126.21&ctn=PSA615/05&mid=Link_Software&hlt=Link_Software
The PSA615 has a rechargeable battery, which can only be charged from the supplied mains adaptor. It wonn't charge from the computer.
If you need a charger contact www.cheapestelectrical.co.uk
They should have some in stock.
Apr 29, 2008 | Philips PSA-615 MP3 Player
Sony Viao, won't power up
Sir,
you remove your Laptop main battery and adaptor for aprox 10 min then fix again battery and adaptor then on power button m/c is on.
Mar 06, 2008 | Sony MBX-49 ASSY Motherboard
Charging
I do not know this particular camera but it is not usual to take a battery charge from the computer. Charger plug in the the household supply. Is this one different? There is usually a more comprehensive manual in PDF on the disk- have you checked that out. Finally get on to customer support, if you feel you are getting nowhere. I would like to know more about the battery charger.
Jul 10, 2007 | Samsung NV3 Digital Camera
Samsung L100 Digital Camera Logo
220 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
