Question about Electrolux Refrigerators
Electrolux icon all fridge single door has water coming out from bottom? what should i look at?
No ice maker in unit.
    Genius:
  • Electrolux Master
  • 1,342 Answers
Vacuum all the dust bunnys under the fridge and on the back.
Posted on May 16, 2014
SOURCE: Superba ice maker stopped working, door water still dispensing
Use a cup of water and just fill the ice cube maker with enough water for the first batch and the sensor will then begin making ice again.
My ice cube maker stopped working after I changed the filter. After reading countless posts about wiring and defrosting and using a blowdryer into the fill line I emptied my freezer and fridge, then unplugged it. I got no results after two days. I finally just put some water in the ice cube maker (the metal ice cube tray below the white plastic fingers that forms the cubes) plugged it back in and closed the door for a few hours and it worked. I wonder if I needed to defrost the unit at all. It was working before I changed the filter, then the filter was full and stopped water from flowing (or decreased the flow dramatically anyway).
Good Luck
Barry Eager
Posted on May 05, 2008
SOURCE: HOOK UP OF ICE MAKER TO THE WATER LINE
The ice maker is not making any ice, or water or crush ice. The wheel that crushes the ice will not spin. Please help
Posted on Aug 19, 2008
catriver
  • 878 Answers
SOURCE: Frost on Ice Maker shute
Dtot, does the flap shut all the way? Sounds like you are drawing moisture from the chute. The flapper should seat so that no air is being drawn in. I have seen a number of these Whirlpools where the pin and spring retainer has broken off from the dispensor housing causing this problem. They use to replace the whole freezer door because the dispensor housing is not a servicable part. They have now come out with a kit to address this problem. This is not a fun job for a first timer. You may want to contact Whirlpool and inquire about the aforementioned. If this is your case, there is a good chance they will cover it. Catriver..post back.
Posted on Oct 21, 2006
SOURCE: My whirlpool refride #GD5RHAXNQOO is not releasing water to the ice maker fill line
Hi all rootbeergirl here. I had the optics changed and the moter on the other side of the icemaker changed I was able to send them both back to Whirlpool because they were both faulty and my fridge was still under warranty and the repair person I had out was a whirlpool warranty certifed rep. I guess I was lucky but whirlpool did tell me that they were having issues with both parts burning out. But now that they are changed it has been been working like a charm. The repair man did suggest that if you are not useing your ice maker alot then you should turn it to the off posistion and let the ice run low or dump the ice holder on a weekly basis. Hope this helps. alsop to replace both parts if you have to pay runs about $300.00
Posted on Oct 06, 2008
SOURCE: leaking fridge
my maytag had cloged defrost drain cleaned drain all ok
Posted on Jul 03, 2009
Electrolux Ref. 3yrs old. ice maker will not make ice, water dispencer will work. I have replaced filter.Ice maker goes through the motion but, no water. can you help me?
either your fill tube is clogged or the water valve in the back of the refer has failed. Go to the back of the unit, if my memory is correct the yellow hose is for the ice maker, at the water valve disconnect the 1/4 hose from the valve to the ice maker only, place valve in a bowl, cycle ice maker. If you get water, fill tube is obstructed, if not water the valve has failed and needs to be replaced.
Good Luck
Oct 28, 2013 | Electrolux EI28BS56IS (278 cu ft) Bottom...
Electrolux Pure advantage water filter
Open and shut the water valve quickly to verify the water supply, it could be a bad water supply valve. Bench test the filters for flow or obstruction.
Aug 01, 2017 | Electrolux Icon Freezers
Ice maker not working
my icemaker has a wire overfill sensor which shuts off the icemaker if there is too much ice in the basket. If this wire gets pushed up it will stop making ice until level lowers OR manually lowered.
Feb 08, 2012 | Electrolux EW28BS71IS (278 cu ft) Bottom...
I have an Electrolux EW28BS71IS and I have water dripping from the ice maker. When I take the ice maker tray out it has water sitting in the bottom of it. I can't tell if it might be overfilling the...
i have an elecolux ice maker leaks water into the bottom trays from the back of the fridge and water always drips from the front dispenser. the ice freezes in a solid block can anyone help me please. ew23bc71is3 is the model double door freezer on the bottom tks.
Mar 31, 2011 | Refrigerators
My wave touch does not make ice filter and water connection are ok .frigde is 6 months old
Mine does this quite often. I turn the ice maker off from the options control panel on the front and leave it off several hours if not over night. When I turn it back on using the same control panel and it works. Sometimes I will see a puddle of water on bottom of the water dispenser or inside the fridge after turning off the unit.
Mar 04, 2011 | Electrolux EI23BC56IS (226 cu ft) Bottom...
French Door with bottom freezer Electrolux ice maker not making ice and when ice maker on it clunks 8-10 times every few minutes. Water dispenser works fine. Whats could be the issue?
sounds like the drive in icemker head is bad and not turning the timing wheel . the timing wheel controls the harvest and the water comming in ect . best to replace the icemker with ther kit . come with instructions . mm hope this helps . if more info needed i need the model # and ser of your unit .. feed back pls ..
Dec 11, 2010 | Electrolux Refrigerators
Fridge makes knocking sound. it sounds like it is coming from the ice maker. Is this a common problem and how do I fix it?
Ice maker could be stuck with frozen ice on the rotator look over and if you see some turn ice maker off and use hairdryer to free up
Nov 19, 2010 | Electrolux EI23BC56IS (226 cu ft) Bottom...
Water puddling in bottom of fridge. water is
If the water to the ice maker is off then the source would be the defrost drain. I have put together some instructions on how to clean out the drain so the water will go to the proper place. Follow the link below and let me know if it helps.
http://www.fixya.com/support/r4686046-water_leak_from_freezer_ice_freezer
May 17, 2010 | Electrolux Refrigerators
Water running from bottom front of refridgertor
Can you tell if there is any water in the ice cube "basket"? If it is full, then your ice maker is not sensing the water level "full" and keeps running. The fridge is normally able to handle a little overflow, about one pint or so, but cannot handle a constant run of water. If it is empty, the supply line may be disconnected somehwhere along its route, most likely near the bottom and at the rear of the fridge. You can pull the fridge out and look at it by removing the back cover. If the line is disconnected, reconnect and have a happy new year. If it is connected, here are two options as I see it.
One - check to make sure your ice maker is properly plugged in and installed at its location in the freezer. If you or someone you love has recently cleaned the fridge or shoved a fifty pound turkey in there, the ice maker may have come dislodged.
Two - replace the icemaker. These units come as a single purchase as you cannot just buy the senser. Cost of most of these I have seen are about $125 for the part (easy to install), which can be a deal breaker. Ice cube trays are $1.99 for two at the local hardware and they don't usually overflow.
Dec 26, 2008 | Refrigerators
Refrigerators Logo
50 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
