Question about Margaritaville Frozen Concoction (DM1000) Blender
I cannot get the button to release the ice hopper.
My cuisinart CB1400PC lights up for a second and then turns off and won't start. Any suggestions
Is the hopper in when you try this? Can you turn the motor at all by hand?
Jan 09, 2015 | Cuisinart Blenders
Ice maker not making ice
Sounds like the intake line at the entrance to the refrigerator is plugged with lime residue. It has a needle valve in the center and will clog with foreign material, this can be cleaned out by forcing compressed air pressure backwards thru this connection to remove tiny particles inside.
Dec 28, 2013 | Nostalgia Electrics RIC-100 Retro Series...
How to remove the blender top
http://www.ninjakitchen.com/manual/NJ600_30_IB_ENG_100226.pdf
on page ten it describes how to remove the lid by lifting the handle and pulling straight up, also shows a diagram.
Nov 10, 2013 | Euro-Pro Ninja NJ600 Pro Blender - NJ600
Cant take apart ice crusher portion of unit
The Ice Reservoir has a release botton at the back of the reservoir. The button must be pushed down at which time you can lift from the back and remove the ice reservoir. You can download the operating instructions for your machine here:
http://www.jardenstore.com/manuals/MANUALS/DM1000-000-000_43_64821634.PDF
Dec 22, 2011 | Margaritaville Frozen Concoction (DM1000)...
Filter replacement
Hi and welcome FixYa. I am Kelly.
I have to assume we are talking about a refrigerator. The question listing is under blenders and if so that is one fancy blender.
On most refrigerators the filter is in the lower left side of the floor grill. The will be lable that says press to release. Then you turn the filter cap counter clock wise to unlock the filter. When installing the new filter you must swap the cap from the old filter to the new one then press in hard and turn Clockwise until it locks in place. (see the instruction sheet with the new filter)
Thanks for using FixYa,
Kelly
Apr 24, 2010 | Blenders
A red light is on my margaritaville machine and have to manually hold switch to shave ice. what can I do to fix?
As soon as I turn my tahiti on I get a red flashing start button is this normal? And I also have to hold the button to mix?.
Aug 02, 2009 | Margaritaville Frozen Concoction (DM1000)...
Can not get Margaritaville blender to start
look for rocker switch left side of machine near bottom
Jun 30, 2009 | Margaritaville Frozen Concoction (DM1000)...
Rival ice maker
plz cont - 23051554 \ 23095757
Jul 26, 2008 | Blenders
Cleaning
You have to hold the button (above the blending jar) down while turning the rotating paddle in the ice hopper. It will eventually catch, then you can unscrew it, take it apart, and clean it. Just be careful not to cut yourself on the shaver blade.
Nov 21, 2007 | Margaritaville Frozen Concoction (DM1000)...
Margaritaville Frozen Concoction (DM1000) Blender Logo
Top Margaritaville Blenders Experts
john h
Tom Chichester
Are you a Margaritaville Blender Expert? Answer questions, earn points and help others
