Question about GE JVM1650 1000 Watts Microwave Oven
The display says 8888 and the microwave won't run.
Tappan microwave has se or 5e on diplay wont push buttons
this a problem a dust in the control board keypads, You must open the keypad, and clean any connector with contact cleaner specially the ribbon cable or plastic and use pencil eraser for to fix the corrosion, dust, and try again.
Jul 08, 2013 | Microwave Ovens
Sharp microwave 8888 is flashing and I cannot remove
see this steps and fix it. God bless you
Reset the clock. Press "Clock" and the correct time, using the number pads. Press "AM/PM" if applicable, and press "Start" or "Clock" to confirm.
  • 2 Press "Timer On/Off" to reset the timer if nothing on the touch pad will operate. Use the number pads to select a new timed amount, if desired, and press "Timer On/Off" to start. Press again to cancel.
  • 3 Press and hold "Clear/Off" for three seconds if the timer will not function or is blinking when you touch the pads. This will release the "Child Lock" feature. Make a new touch pad selection.
  • 4 Disconnect power to the microwave if following Steps 1 through 3 does not resolve the blinking timer. Wait a few minutes, and then restore power to reset the microwave.
  • However if the problem persist the display board
    main control board is faulty
    Oct 02, 2012 | Sharp Microwave Ovens
    Samsung microwave displays 8888 beeps then 6666
    how can i fix this problem i have an air conditioner whit the same problem and don t work please help me here are very hot
    Jun 20, 2012 | Microwave Ovens
    Microwave was run empty and now it won't run. Display works but no fan or microwave. What to do?
    The magnetron does not fair well when running empty, the thermal fuse usually kicks in if a metal object was put in by mistake, but should be checked along with the door switches.
    May 31, 2012 | Panasonic Microwave Ovens
    ?E - 5" message
    From Samsung's FAQs:
    "Some models are equipped with a sensor that can automatically adjust the oven's heating time based on the amount of steam in the oven. If your microwave is displaying E1, E4, or E5, there may be an issue with the gas sensor. For an E1 error, press the Cancel button and check on the food.
    "Other microwaves do not give specific error messages and just display "8888" on the LED. If you get this error message, your microwave needs service.
    "If the message is either ERROR or E-6, it indicates a mechanical fault.
    "For all error indications, including the SE or 5E error, try unplugging the microwave from the outlet for at least ten minutes and then plug it back in. If the error persists, the microwave may require service. Please use our ASC Locator to find your nearest Authorized Service Center."
    Or instead let us know if we can help further.
    Aug 22, 2010 | Samsung MU3050 Microwave Oven
    Microwave display flashes "8888" continuously and when door is open, the interior light also flashes. What could be the problem?
    It may be bad electrolytic capacitors on the control board, but I would need your model number
    We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week or two with a one-year guarantee.
    Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
    William E. Miller, AS-EET
    prototech@usa.net
    http://www.microwavedisplay.com
    Jan 21, 2010 | Maytag Appliances Over-the-Range Microwave...
    Nothing on my touch pad works
    My microwave way manafacture May 2008. Nothing on the touch pad works.???. It just abrubtly stopped
    after a few seconds.
    We brought it in July or August
    Debbie
    Mar 27, 2009 | Maytag MMV1153A Microwave Oven
    Display only shows 8888 - display buttons do not work.
    try a reset. unplug for 10 mins, plug it back, see if it will work.
    if not , open the housing, see a ribbon cable from the touch pad to the main pc board. remove the ribbon cable for 1 min. re install it back and test the unit.
    be sure to return all cover and screws of the unit before plugging it back. microwaves are hazardous to your health.
    tnx 4 using fixya,
    drcool
    Oct 05, 2008 | Sharp Microwave Ovens
    We have a 1986 montgomery ward microwave that the cotrol panel will only display 8888. It appears to be locked.
    You can try resetting the micorwave by unplugging it, waiting awhile then plugging it back in. However, considering it's age. It is probably worn out and repair would cost much more than a new mupdated microwave. They are very reasonable in price now.
    Aug 01, 2008 | Microwave Ovens
    GE JVM1650 1000 Watts Microwave Oven Logo
    37 people viewed this question
    Top GE Microwave Ovens Experts
    D. E. Hev
     Larry
    Larry
    Shekar Avadhani
    Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
