Question about Scotsman Ice Maker CM3 30inW Cubed Ice Machine 750LB
Why Scotsman CM3 ice machine shows diagnostics water problem?
My Scotsman CM3 ice cubes maker machine stopped working and is currently showing a green light in OFF and a red light in DIAGNOSTICS WATER. I tried to reset it by pushing the OFF button and then the FREEZE button and it starts working for about 30 minutes and then again it stops with the same error as above. Can anybody has a solution?
  • Scotsman Master
  • 4,654 Answers
Should you have any questions, Thanks John Tripp Appliance 911
First let's look through the different service manuals. CM3 Water level sense diagnosticsDOWNLOAD
Head Pressure Control Kit - CM3DOWNLOAD
Reduce Air in CM3 ModelsDOWNLOAD
Replacement of the CM3 controllerDOWNLOAD
Service Handbook to 2007 - CM/CM3DOWNLOAD . I am here should you have any questions, Thanks John Tripp Appliance 911
Posted on May 16, 2014
TheMobilian
  • 8220 Answers
SOURCE: scotsman 500 cm3 ice machine
Remove all molex connections and check for corrosion. Clean the connections and retry.
Posted on Mar 01, 2009
  • 102 Answers
SOURCE: Brand new Scotsman DCE33 ice maker melts ice
Check that the condenser is clean, the plastic sheet is hanging over the opening and trhat both spray nozzles are in place.
Posted on Aug 06, 2009
  • 33 Answers
SOURCE: Scotsman Ice Maker CME 256
descale bin level sensors, check for corrsion on wire harness. if does nt work. replace . bin level sensors
Posted on Aug 26, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: I have a scotsman commercial ice machine mdl#
I am going to assume that the machine has been cleaned, I would adjust the cube thickness to less.
Posted on May 06, 2010
  • 112 Answers
SOURCE: On our Scotsman cm3 the
These units have a real problem with the bin controls. I can't begin to tell you how bad. There are two - for lack of a better term - paddles - that are basically just pushed into the left and right side of the drop area that have small lenses in them with a low level beam that when broken indicates a full bin. You have to reach in from under the bin opening and feel to the left and right, pull the paddles toward the middle and there should be enough slack on the wires to get a good hold of them and clean the lenses with a Q-tip soaked in grapefruit juice. Pop them back in and try them - if that doesn't work (and sorry but most of the time it doesn't) then they will have to be replaced.
Posted on Dec 11, 2010
I have a scotsman CM3 with aquaarmor ice machine. There is a constant trickle of water coming from each leg. Why is the happening???
Try taking off a side or back panel and see if there is frost building up. If frost is present, it could be low on refrigerant.
If there is condensation, it could be the insulation is saturated with water allowing thermal transfer to condense water out of the air.
Feb 06, 2015 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Scotsman ice machine
Check the water inlet valve water seeping through valve should be running over into bin. Replace or rebuild valve. the machine should have slowed down on production of ice also.
Jul 17, 2014 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Scottsman SCE170A-1B how can i have to make ice faster
The only way to make ice faster for this machine is done with cooler ambient room temperature and colder water temperature from supply water before it reaches water sump tray.
Jun 06, 2014 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Scotsman cm3 does not harvest
your sump level control sensor is not reading the water level drop to go in harvest.you can do a self check test or replace the sensor(little blk box) could be wire harness. check to makeure your water value is leaking through
Feb 11, 2014 | Scotsman Ice Maker CM3 30inW Cubed Ice...
The water only flows then it stops
Check water filter or make sure water is on....sounds like slow water fill
Jul 31, 2013 | Scotsman Ice Maker CM3 30inW Cubed Ice...
How ofter should you clean the Scotsman ice maker?
Every 6 months and change filter unless you notice ice hanging up during harvest and dirty ice then i would every 3 monts.
May 25, 2013 | Scotsman Ice Maker CM3 30inW Cubed Ice...
We have four Scotsman Ice Makers. The curtains are beginning to turn a little green. What is the approximate cost of replacing these curtains. How much per curtain?
Unless they are terrible you can clean the curtains. What you do is put icemaker cleaner in the icemaker and run it through a cycle. I don't know how much the curtains cost.
Sep 28, 2010 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Refrigerators Logo
364 people viewed this question
Top Scotsman Refrigerators Experts
john h
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Scotsman Refrigerator Expert? Answer questions, earn points and help others
