Samsung C9201 printer motor failure A1-1213. Anyone seen this and which motor could be the fault?
  • Thomas Kielbasa
    Thomas Kielbasa Aug 25, 2014
    Ended up being a Main Controller replacement.
I also had an actuator motor failure error on my Samsung CLP-415NW (Error A1-3612 for this model). Fortunately, there are two identical motors in the printer. I opened up the right side of the machine (four screws) and swapped the two motors to determine which one was broken and to make sure it's not the motherboard or a connector causing the problem. (Just unscrew the motor circuit boards (3 or 4 screws) and pull out the connectors). I googled the part number (Moatech BL55U-M01) for the motor/circuitboard and found them for sale on eBay (sold as a pair for $34). Worked a charm and quite a simple repair.
(Please just be careful to unplug the machine when you're disassembling things).
Posted on Oct 30, 2015
FAULT CODE 009-380
The Yellow ATC Sensor detects a low TC (toner concentration).
Initial Action
  • Check that Toner/Developer is present.
  • Check the Yellow ATC Sensor for contamination. Ensure that the sensor is seated correctly.
NOTE:
To clear this fault, enter Component Control and set the value of NVM location 752-109 to 0.
This can be caused by many things. I've seen broken Drum contacts from improper drum installation causing Developer bead carryover. Toner dispense motor assy's failing. Developer Housing failure. DVHVPS failure.
Sep 19, 2014 | Xerox Fuser Cartridge 008R13040 for Work...
The dryer on the samsung super jumbo WT10S2P is not working
Possible fault of the motor or the drive to the motor which is the main controller unit. Possible failure of the drive output.
Aug 22, 2013 | Samsung Dryers
Samsung Digimax Cyber 530 does not show image on screen
Check the memory cards on your PC for the quality of the images that were shot now. if there is no fault seen the fault is in the display section. It can be a fault of the LCD or the failure of the flexible strip to the LCD.
May 06, 2011 | Samsung Digimax S500 Digital Camera
The open on a cyberhome dvd player isn,t working and its not opening
Possible that the CD mechanism is out of order due to a fault in the loading section. This can be failure of the motor, failure of the drive, gear, belt or jamming of the drive. you need to remove the machanism to check this fault. If there is no signs of fault seen then the voltage to the motor at the time of eject from the drive IC and procesor must be checked. Check motor, driver IC and signal to eject from the processor.
Apr 27, 2011 | Cameras
VIBRATE NOT WORKING WHAT EXPENSES COMES OF MODEL NO. SGH E-840 SAMSUNG
Depends on whether the fault is minor like the wires to the motor being cut off or a possible fault of the software or failure in hardware - fault in main board or motor.
You can always check out for the minor fault but if not take estimate from the dealer.
Feb 03, 2011 | Cell Phones
Error code "PE"....paper not jammed.....model,435dx
Then you may have a sensor fault or motor/ drive failure in the printer.
If anyone needs an operation / programming manual for a Royal 435dx, c-tech collective have it here:
http://the-checkout-tech.com/manuals/cashregisters/Royal_435dx_instruction_manual.html
Sep 24, 2010 | Casio Parts Cash Register PC Desktop
Display shows 'deve home sensor error' and red fault light.
hi,
most likely is your main motor drive is having issue.
got to be replace to fix this issue
May 10, 2010 | Samsung CLX-3175FW Multifunction Laser...
Fault with the picture of a Samsung television
You appear to have a DMD failure part# BP96-00249A with a list price of about $622.00.This is a common failure with Samsung DLP type televisions.
Jan 14, 2009 | Samsung HLN5065W 50" Rear Projection...
138 people viewed this question
jasbo
jasbo
