Question about Dell Inspiron 6000 Notebook
.dell inspiron shuts off before boot. when charger is connected it periodically flashes once on charging light. battery is good and is charged
  • 778 Answers
Hello, The hard drive operating software or the hard drive is bad. You will have to try using the recovery cd to reload the software.
Posted on May 16, 2014
Kegtapper
  • 94 Answers
SOURCE: Dell latitude D600 battery charge light flashing
You have a ground fault issue in the DC JACK.
There are escentially 4 circuits in the jack and one is not making contact.
1: Negative Charge circuit (outter ring)
2: Negative Run circuit (outter ring)
3 Positive (Inner Ring)
4: Signal (center pin)
I believe the negative charge circuit (outter ring) is not making contact internally. Typically what happens on that model DC Jack is the tension contact metal becomes fatigued, and does not touch the outter ring.
This could come from Heat causing early fatigue of the metal.
Or normal wear, the metal has simply worn out from regular insert/removal.
Don't forget to rate suggestions
Posted on Apr 01, 2008
ArnWuLF
  • 55 Answers
SOURCE: DELL INSPIRON 6400 BATTERY CHARGE PROBLEM
The battery has 5 small dots in it. Those are there for no reason. Those are actually LED lights. There's a button you can press. If we number the lights 1-2-3-4-5 with 1 being closest to the button, check the lights when you press the button. If 1-3-5 are lit, that means that you have a dead battery and needs to be replaced. Other than that, you're battery might still be working but nearing the end of its life. Goto support.dell.com -> drivers and downloads -> enter your service tag or system type -> download Dell Quickset. Once Quickset is installed, it will diagnose your battery automatically and let you know if your battery already needs a replacement. It is just sad that batteries are covered with a separate 1-year warranty only. You can also go to www.dellbatteryprogram.com and check if your battery was part of the Dell Battery Recall Program.
Posted on Nov 25, 2008
  • 629 Answers
SOURCE: Battery Charge light flashing 4 red one green Dell Inspiron 9200
usually, its an indication that the battery is nearing the end of its useful life. you can try to use another battery to isolate it further. If the same thing happens with another battery, chances are, the mobo is failing. Flashing the BIOS can usually help with battery issues. If another battery works fine and your computer is within its first year since you bought it, you can request a replacement battery from Dell
Posted on Mar 16, 2009
SOURCE: Problems with Dell Inspiron 6000 Battery ? DELL Inspiron 6000 laptop battery is popular, why ?
Dell inspiron 6000 laptop battery URL(UK shop): http://laptop-battery.org.uk/laptopbattery/1001074.htm
Dell inspiron 6000 battery URL(US store): http://www.cheap-laptop-batteries.com/laptop-battery/dell-inspiron-6000.htm
Dell inspiron 6000 battery URL(AU Buy): http://laptop-batteries.com.au/computer-battery/dell-inspiron-6000.htm
Posted on Jul 31, 2009
SOURCE: My Dell Inspiron 6400 battery is overheating and light is flashin
Hello I own a Dell Inspiron 6400, i guess what happened was that it must have overheated of so but its on the screen your system automatically powered off because it became warmer than expected. This may have been caused by:o) operating or storing the system in an environment where ambient temperature is too high or o) obstructing the air flow from the system fan vents. if this problem recurs please call dell support with error code #M1004. strike the f1 key to continue. f2 to run the setup utility pressf5 to run onboard diagnostics.
Posted on Aug 03, 2010
Dell inspiron M5030 won't charge, green light is
This is a common problem. It may be that the charger is dammaged. these Dell chargers have a micro thin communication cable in them that tell the charger to charge the battery. this micro thin cable can often break. Its use it to prevent the laptop battery from over charging, but if it breaks or becomed broken inside tha charger cable, then the laptop simply won't get the charge signal and the battery won't charge. If this is the case, then you will need to replace the charger with another Dell charger compatible with your laptop
Dec 23, 2012 | Computers & Internet
Inspiron 1525 charging problem
Try the following steps to solve it:
it of googling on the web and finally found the solution here.1 Turn off laptop.2 Unplug AC power.3 Remove battery.4 Replace AC power.5 Turn on laptop, allow OS to boot.6 Once logged in to the machine, perform a normal shut down.7 Unplug AC power.8 Replace battery.9 Replace AC power.10 Turn on laptop, allow OS to boot. The battery should once again be charging as normal.If it can't still resolve this problem, try a new laptop charger or repair your laptop dc jack.
If you plan to be on a budget for your dell 1525, you may try the following third party charger:
Replacement Dell Inspiron 1525 AC Adapter 65Watt 19.5V 3.34A
Oct 20, 2012 | Dell Inspiron 1525 Laptop Midnight Blue
My laptop, dell inspiron 1800, cuts on but after a few seconds cuts back off. it lights up but shuts back off
A few things to check:
1.) Check the battery is charged and the charger is supplying the right voltage and the power jack is tight in the laptop DC port. Check that the charger (on charger) light is steady green, not flashing.
2.) Remove battery and try to boot on AC Power, if this works, either the battery is not charging (dead battery) or the charging circuit in the laptop is damaged.
3.) Remove Ram modules oner at a time, see if it boots with one module in, if it does, then issue is with the ram
4.) Examine the cooling vents, try blowing them to see if any dust is released, hoover them as best you can, if this cures the problem (and it will be a temporary fix), get the laptop stripped down and give it a proper clean around the processor and fan areas. (overheating issue)
If it does not help, then Its looking like your motherboard has developed a fault through maybe overheating
Jan 20, 2011 | Dell Computers & Internet
I have a Dell Inspirion 1525. I have a fairly new after market replacement battery which I have only had now for 4 months. I am using Vista. As soon as I unplug, computer shuts down. I go to power settings...
The adapter is working correctly. The battery is either slow to charge or in need of replacement.
It's possible your battery isn't charging at all so to test this boot into bios -> battery status and watch it run overnight.
Sep 09, 2010 | Dell Inspiron 1525 Notebook
I just bought a replacement 9 cell battery and a 90 watt power adapter for my Dell E1505. With the new battery and power adapter my battery indicator light keeps flashing green and the battery doesn't...
If a new DELL ac adapter (3rd party Adapters are not recognized and the charging circuit is disabled) and a new battery doesn't resolve then the charging circuit on the motherboard is bad
Dec 29, 2009 | Dell Inspiron E1505 Notebook
Hi, The battery light on my Inspiron 6000 flashes 3 times red and then green repeatedly. What does this mean? Also, after the computer is plugged into an outlet for an extended period of time the power...
the battery has reached its expected life, you need to replace it. If it is under warranty, you can call dell and have them replace it. You can still use you laptop with the wall power/charger plugged in, remove the battery to get rid of the flashing red/green light.
Jul 10, 2009 | Dell Inspiron 6000 Notebook
Dell inspiron 1525 won't charge
The battery has most likely been "Over charged". Most rechargeable batteries can only be charged around 500-1000 times depending on the brand of your computer. I would recommend buying a new one.
May 30, 2009 | Dell Inspiron 1525 Laptop
Replacement battery for Dell Inspiron 1501 won't charge
If your old battery was doing the same (not charging), then is is because the charger is not charging the battery. Do you have a friend with a Dell laptop? Maybe you can use a borrowed charger to test and see if it will charge the batteries. To answer your question , no Dell does not have anything built in to prevent you from using a 3rd party battery.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 28, 2008 | Dell Inspiron 1501 Notebook
Dell Inspiron 5150 no power, no lights
it could be that the ports where you plug in the charger is damaged. if you have an identical or a known good battery that is charged, try to install that and check if it works. you need a motherboard replacement if the system works with a charged battery.
Sep 24, 2008 | Dell Inspiron 6000 Notebook
The Charger light flashes orange 3x and green once but it wont charge
Your battery has died, of a fail safe has kicked in. The orange light indicates that the battery isn't charging properly, and needs replaced. Replace the battery and it will be fine. Keep in mind that batteries are just batteries, they eventually wear out, and some faster than others. Also, the more you use the battery, the faster it will wear out, so I always recommend keeping the machine plugged in when possible.
Aug 25, 2008 | Dell Inspiron 8000 Notebook
Dell Inspiron 6000 Notebook Logo
29 people viewed this question
Alun Cox
