Question about Amana NDG5800 Gas Dryer
I can only find a thermodisc i cant find a thermal fuse so are they consider the same thing?
    Novelist:
  • 102 Answers
Look on the hot air exhaust tube for a small white plastic module with two small wire leads coming off of it. It will have only one mounting screw holding it on. This is your thermal fuse and all dryers will have this plus a hi-temp sensor mounted fairly close by on the blower exhaust tube usually on the left side of the dryer when your looking at the back panel area. Use a multimeter or ohm meter to check to see if you have continuity between the terminals. Should be less than .5 ohms or almost showing a dead short. Be sure to remove the wires to test this. Also, before doing any work on a dryer or washer, UNPL:UG IT!
Posted on Jun 15, 2014
How do I replace my Ascaso dream safety fuse
which of the two thermodisc is busted? there are two values. 100 deg and 140 deg. use a wrench and rotate the body similar like screw
Dec 13, 2017 | Ascaso Coffee Makers & Espresso Machines
Can a GE electric dryer Thermodisc be tested by cogtinuity?
That picture looks like a thermistor of some type. If you have the wiring diagram (usually inside the control panel) it should tell you the resistance it should be at different temps. If it is a thermal fuse or hi limit it will read like a switch. Closed if good---opened if burned out from too much heat.
Apr 15, 2015 | GE Dryers
Can a Thermodisc thermal limit switch be tested with a volt ohm meter
yes but you will need a heat source to activate it but before you do this check the part number printed on the device with thermo disc web site as it may be a single activation type ie trips and stays tripped. If it is it may reset with a co2 blast from something like an air duster
Dec 05, 2013 | Heating & Cooling
What is the thermal fuse temp in a Nutone 665rp heater?
Our thermal fuse blew as well, and my son was able to read the small print. Mine is a MicroTemp SRCAXK G4A01 TF 100, which according to the ThermoDisc website appears to have an open temperature of 100C (212F).
Dec 11, 2010 | Broan-NuTone 665RP Electric Compact Heater
Dryer not getting hot why
Both the flame detect0bbc370.jpg and the igniter has to have continuity. 98f97da.jpgIf it work a little bit but quits then the solenoids are getting hot and failing. A common problem on gas dryers89b9845.jpgIf you aint got any heat at all and all of the gas assembly stuff is fine, then you needs to check the safetys thermodiscs for continuity. These thermodiscs called Klixons mount where the air temp can effectively bend the bi-metal inside and kill the circuit. Any of these sensors trip the circuit if an overheating situation should occur during the heating cycle.ec94686.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 29, 2010 | Kenmore 73952 Gas Dryer
Whirlpool gdb307 oven display not working after storm
Some things to consider:
1. There are two thermal fuses on this unit
- one fuse is in the bake/broil element circuit and if blown, would cause no-heat but the display would still light.
- the other thermal fuse is in series with power to the control board, if blown the control board display would be dark and no oven related functions would work
2. There is a low voltage transformer that supplies power to the control board that sometimes gets damaged by lightning surges. This would also cause the display to be dark with no oven functionality.
3. We repair a number of these control boards that are damaged by lightning storms. Here's a link to a related article that might be helpful:
//www.fixyourboard.com/techzone/ovens/e6_f2/e6_f2.html
Best Regards,
Bruce
Mar 03, 2010 | Whirlpool Ovens
Yesterday, my sharp carousel r-1460 went dead. I took apart the front keypad and replaced the 20amp fuse behind it. the microwave light and fan work.But, when I start microwave to cook something, pop! fuse...
If the 20A fuse is blowing, it is often the high voltage transformer or magnetron. If this is the case, and the microwave is not under warranty, replace it. Residential microwaves are generally considered disposable. Parts and labor are just too expensive. A magntron or transformer can cost more that half the cost of a new microwave.
Feb 24, 2010 | Emerson MW8102SS 1100 Watts Microwave Oven
Waffle maker won't heat
There is a thermal fuse inside the bottom half of the unit, enclosed in a white insulating sleeve. A replacement can be found on Amazon.com at the following URL:
http://www.amazon.com/Thermodisc-Degrees-Celsius-Thermal-Fuse/dp/B000T9VEV6/ref=wl_it_dp_o?ie=UTF8&coliid=I2M3QCVRS1C1IV&colid=2LRN9SBBQ2MW7
Aug 24, 2009 | Waring WMK300 Professional Belgian Waffle...
No wires attached to thermal cut-off WHY?
the thermal cut off is what cycles the heater,the thermal fuse is the fuse that pop if the heater get to hot,back in the day they never had thermal fuses to begin with,hope this helps-mike
Mar 13, 2009 | Kenmore Dryers
Amana NDG5800 Gas Dryer Logo
Top Amana Dryers Experts
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
