HL2140 - DRUM REPLACED APPROX 3 WEEKS AGO, LIGHT KEEPS COMING ON
  • dianne862 Jun 23, 2009
    Thank you!
    President:
  • 2,306 Answers
When you replace a drum in a brother machine you have to tell the machine it's a new drum. The instructions are on a sheet packed with the new drum. With the front door open you hold the panel button until all the lights flash on, then close the door and you're ready to print.
Posted on Jun 23, 2009
HOW TO REMOVE DRUM ERROR IN BROTHER HL2140 PRINTER
Need to replace drum and reset the counter
(Essentially the cartridge/drum unit should not be in the printer when you reset it)
1) Open front door
2) Remove the cartridge/drum unit
3) Hold down front button until all lights come on
4) Put cartridge/drum unit back in
5) Close the front door
The Drum life should be reset.
Jul 07, 2011 | Brother HL 2140 Laser Printer
2001 Grandam service engine light is on and now the coolant light keeps coming on even though just filled it 3 weeks ago
check the coolant level and if ok then remove the sensor in the header tank and shake it and then refit and see what happens ,the ball in the sensor often gets stuck
Dec 15, 2010 | 2001 Pontiac Grand Am SE
98 4 runner MAF problem. Was replaced 1 year ago with after market MAF. Check engine light would come on every 3 months. They would clean it and clear code. Now it only lasts 2 weeks. Took it to Toyota -...
Make sure that there are no leaks, on your duct hose..where the MAF is located..because if you are getting too much air..the MAF, will try to adjust to it, and it will throw your injectors out of wack, and then you will have a code...stating that you are running too rich, or lean, and then your plugs will foul out, because of too much gas, or not enough...and then it will trickle down to your O2 senors..it's a big chain reaction when it comes down to the MAF sensor...but check your Duct....
Dec 02, 2009 | 1998 Toyota 4Runner
My check charging system light keeps coming on. I replaced the alternator about 2 years ago, and the battery about 10 months ago. Trying to figure out the possible problem before taking it to a shop.
Check the voltage ot the battery when the light is on. Ity should be approx 13.6 volts. If its around 12 volts, the alternator isnt charging. BUT just beacause it isnt charging, doesnt mean its bad, wirng has to be verified good, and connection.
Nov 23, 2009 | 1999 Ford Windstar
Power steering fluid leaks, rack replaced approx a year ago
May have a failure in the replaced rack. I would take it back to the shop that did the work for warranty. If you got a remanufactured rack it was re-built and may have had major problems that were not fixed with the rebuild.
Oct 03, 2009 | 1998 Chevrolet Cavalier
Replaced the projector lamp 3 weeks ago. Reset
If the lamp is working it should be fairly obvious but stand to one side of the lens and see whether there is any light coming from the projector. If there is you know that it's an input problem. If there isn't either a fuse has gone, the bulb has blown or the filters might need cleaning. If the bulb has blown it's probably because you handled the bulb. It's vital not to touch these bulbs with your fingers. If you do wipe it with methylated spirits.
Aug 21, 2009 | Sharp Office Equipment & Supplies
2001 dodge ram keeps over charging battery
you need to have the pcm checked...it acts as the voltage regulator
Mar 16, 2009 | 2001 Dodge Ram 1500 Truck 2WD
Break light keeps coming on
ok, as far as you brake light gos it will come on if you have air in the system try bleeding the system and also will come on if your front pads are getting really thin,as far as your change oil light you need too reset the computer by turning the switch on(but not starting the car) then pump the gas peddle 3 times real fast you may have too do this several times my trucks a pain in the neck too do takes about 15 times
Mar 04, 2009 | 2005 Chevrolet Malibu
We have a Sharp 1641CS copier and the drum light came on a few weeks ago, we replaced it, and the light never turned off, now it blinks, and the will not copy at all? Help!
If you will replaced the drum you should reset the drum counter .
To reset follow these steps:
Step1: Press continuously Clear key then press Exposure key then Clear key then Exposure key
Step2: You are inside the simulation if the display turns off but if not do again step1
Step 3: Press 24 then press print button then press 7 then print button
If not canceled try step4
Step4: Do step1 to step2 then Press 24 then press print button then press 6 then print button
Mar 02, 2009 | Sharp AL-1641CS Copier
217 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
