Question about Kensington Computers & Internet
How to sync an HP laptop to a wireless mouse
I have a new HP laptop and I am trying to sync it to an old wireless Kensington mouse. I am not sure how to do that. Any ideas?
  • 778 Answers
Hello, The new hp laptops with win 8 aren't compatiable with the old wireless mouse. Wireless mouse are cheap now. So, will have too buy one.
Posted on May 16, 2014
yooperbud
  • 8637 Answers
SOURCE: how to install batteries on kensington wireless mouse 72214
Normal 0 If the mouse doesn't have a little door to open on the bottom, then try this.
Just behind the Left and Right keys where your hand rests, apply firm pressure down on the cover and slide to the rear. Some mouse manufactures have used this type of access to replace the batteries.
Hope this helps. Bud
Posted on Jan 22, 2009
  • 310 Answers
SOURCE: I have a kensington wireless mouse. the wireless
Have you tried to resync the mouse with the receiver. Usually,you need to press the button on the reciever first, then quickly hit the button on bottom of the mouse.
Posted on Oct 05, 2009
  • 12 Answers
SOURCE: flashing red light on the Kensington wireless mouse base
My adapter says 5.6V DC 600mA tip is positive
Posted on Jan 26, 2010
SOURCE: Mouse does not move cursor
I was having the same problem on Windows 7 and thought it might be a software issue. But then I found an online manual for the Kensington 72214 and got the solution.
You need to make sure to establish a wireless connection between the mouse and the USB receiver by first pressing the connect button on the end of the USB stick and then pressing the connect button on the bottom of the mouse. It is not simultaneous - do step one then two. This also has to be done any time your replace the batteries.
Here is the manual: http://files.acco.com/KENSINGTON/K72214/K72214-4697.pdf
Posted on Jun 02, 2010
  • 903 Answers
SOURCE: Dynex wireless mouse DX-PWLMSE won't work
The mouse should be Plug and Play. Did you install the drivers before plugging the mouse's receiver in? The PC has to have the drivers first in order to take advantage of the Plug and Play capability. If you plugged the mouse's receiver in before installing the drivers, unplug the mouse receiver, uninstall the driver, reboot your PC, reinstall the driver, then plug the receiver in and you should be fine.
Otherwise, press the Connect button on the receiver first, and then the Connect button on the mouse, and that should establish the connection. You don't need to disable your touch pad in order to use the mouse.
Posted on Aug 20, 2010
I have a Kensington Ci65m mouse. The right click button works but the "left" click button doesn't work. Sometimes it works but I have to press pretty firmly to get it to respond. I have an old...
Mice are pretty cheap just replace this mouse and get another one. You can spend time taking it apart and trying to fix it or make some other USB connector work with another mouse so on and so forth. Just go and purchase another mouse that would be really much easier. I hate to say it. I guess that is my humble opinion odds are that you will be doing that anyway. Thanks for using FixYa! John
Apr 12, 2011 | ACCO Brands Kensington® Ci65m (DHK72267)...
Kensington wireless mouse won't work - need instructrions
Plug in the USB dongle. Wait for windows to acknowledge the device is installed. Turn on the mouse. If the battery has been recently installed or replaced press the small reset button to sync the device to the dongle transceiver.
Dec 12, 2009 | Kensington PocketMouse Pro 72117 Wireless...
I have a kensington wireless mouse. the wireless keyboard works, but the mouse does not. The red laser light is on, but it won't move
Oct 05, 2009 | Kensington Computers & Internet
Kensington wireless mouse doesn't work on Mac laptop.
Kensington wireless mouse is compatible with this system:
PC-Windows® 98, Me, 2000, or XP with USB port
USB Macintosh® with OS 10.1.5 or later
USB Macintosh® with OS 8 and 9 device will only function as a 1-button mouse
If you buy this item you have a disk utility on it and provide the software to run on the system. If not you can download it at this site: http://us.kensington.com/html/4398.html
Jul 08, 2009 | Kensington PocketMouse 72214
Kennsington 72216 mouse continuosly clicking after changing batte
try installing the software that came with the mouse. if none came with it then go to the manufacturers website and down load the drivers. if none available then there might be something physically wrong with the mouse and you replace it.
Feb 28, 2009 | Kensington PilotMouse Optical Wireless...
Mouse does not move cursor -Kensington mouse and latitude laptop
Feb 27, 2009 | Kensington PocketMouse 72214
Kensington PilotMouse Wireless Mini interference
buy a different mouse for one of them not same make
Sep 30, 2017 | Kensington Pilotmouse Wireless Mini...
My mouse dose not move
There is a connect button under the mouse.
and there is a button on the reciever. Please press both the buttons together for 2 minutes and after this it is supposed to work. However if it is not working replace the battries and do this sync process again.
If still not working contact kensington support they will replace for you.
click on the link below to contact through email.
http://kensington.custhelp.com/cgi-bin/kensington.cfg/php/enduser/ask.php?p_cat_lvl1=8
Regards,
Mohammed
Regards.
Mohammed.
Nov 24, 2007 | Kensington 72219 Mouse
Kensington Pilotmouse Mini Wireless Model 72314
check batteries
make sure the mouse and receiver can 'hear' each other
Oct 13, 2007 | Kensington 72223 (72213) Mouse
Computers & Internet Logo
141 people viewed this question
Top Kensington Computers & Internet Experts
dctocali
Level 1 Expert
Alun Cox
Are you a Kensington Computer and Internet Expert? Answer questions, earn points and help others
