Question about Whirlpool LER5636P Electric Dryer
How do I replace the drum rollers? - Whirlpool LER5636P Electric Dryer
Maytag ensignia
follow this steps and fix it. God bless you
Drive Motor
The dryer drive motor turns the drum and the blower wheel to exhaust the air. If the dryer stops the motor might be defective. If the dryer stops and the dryer motor makes a humming noise there might be something caught in the blower wheel, or the drum might be binding. Try removing the belt from the motor and checking the blower wheel for obstructions. Also try rotating the drum by hand with the belt off, it should rotate freely. If the drum doesn't turn freely, determine what is causing it to bind. The dryer motor can't be tested easily. If the drum turns freely and the blower wheel is clear, and yet the dryer still keeps stopping mid-cycle the motor may be defective. it will need to be replaced. It is not serviceable.
Enter your model number to see parts for your dryer.
Help me find my model number
Drum Roller Axle
This dryer has drum support rollers. There will always be two supporting the rear of the drum, and on some models there may be two supporting the front of the drum. The rollers must spin freely to work properly. If the roller axles are worn out the rollers may not spin freely which can overload the motor and the dryer stops. If the dryer stops mid-cycle, remove the belt and spin the drum, it should spin freely. If not, check the rollers and roller shafts.
Drum Roller
This dryer has drum support rollers. There will always be two supporting the rear of the drum, and on some models there may be two supporting the front of the drum. The rollers must spin freely to work properly. If they are worn out or start binding the motor can get overloaded and the dryer stops. If the dryer stops mid-cycle, check to be sure the drum turns freely with the belt removed. If not, check the rollers. Do not lubricate the rollers or roller shaft, lubrication will attract lint and cause the roller bearings to wear out faster. If the rollers don't turn freely, replace them. The roller shaft can often be reused, unless it has worn down. Clean the shaft thoroughly before installing the new rollers.
Drum Support Roller & Axle
This dryer has drum support rollers.There will always be two supporting the rear of the drum and on some models there may be two supporting the front of the drum. The rollers must spin freely to work properly. If the roller axles are worn out the rollers may not spin freely. If not, check the rollers and rollers shafts. If they are worn or do not turn freely they will need to be replaced.
Drum Slide, Glide, or Pad
The front of the dryer drum is supported by small pieces of plastic-like material. As the drum rotates, it slides on these plastic pieces. If the dryer stops mid-cycle, it may be that one or more of these plastic slides or glides has worn out. When they wear out the drum can start binding and put strain on the motor. The motor then shuts down and the dryer stops. Check the glides for wear and replace as needed.
Drum Bearing
The drum bearing supports the rear of the dryer drum. Over time this bearing will wear out and may cause several different problems. If the dryer stops during the cycle it may be that this drum bearing has worn out and is putting too much strain on the motor. If the belt is removed and the drum spins freely, the drum bearing is probably not worn out. If the drum bearing is worn out, there may be some grinding or squealing, and the drum will be hard to turn.
Drum Support Bearing
Dryness Control Board
The dryness control board shuts off the dryer when the clothes have reached the level of dryness selected by the user. If the dryer stops too early, the dryness control board might be defective. This is not very common and other possibilities should be checked first.
Jul 21, 2013 | Maytag Dryers
Kenmore 86582800 drum has a high pitched squeak after been on for 5minutes. 1983 model
see this steps and fix it. God bless you
Drive Belt
If the dryer makes noise, the belt may be frayed or damaged. If the belt is damaged, it will make noise every time it travels around the pulleys. The drive belt is a long, narrow band that wraps around the entire drum, then around a tension pulley and the motor pulley.
er
Drum Roller
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers. If one is worn out replace all of them at the same time as a preventative measure.
Drum Roller Axle
Over time the drum roller axles can wear out, causing the rollers to wobble. If this happens the dryer makes noise. If the dryer is making a rumbling noise, check the rollers and axles. If any are worn out, replace them all at the same time.
Blower Wheel
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
Drum Bearing
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers or axles may be worn out. After removing the drum from the dryer, inspect the rollers and axles. If one is worn out replace all of them at the same time as a preventative measure.
The drum support bearing is at the rear of the drum. If the dryer makes noise check this bearing. If it is worn out, replace the entire bearing.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
Drive Motor
Although not very common, if the dryer makes noise the drive motor may be worn out and the motor bearings can become noisy. If this happens the drive motor must be replaced. The bearings are permanently sealed and cannot be lubricated.
Jul 13, 2013 | Dryers
Our Dell 5110cn stopped working and the 'diagnostic' said to replace the transfer roller. I had purchased a Dell Imaging Drum and replaced that. I believe it has a transfer roller as part of the Imaging...
Dell sells the drum & transfer roller a kit, but there are 2 different parts to it, the drum & the transfer roller & they do not look the same. Replacing the drum does NOT replace the transfer roller. We've had a 5110cn for 4 years, I've replace both of these parts & the fuser unit several times.
May 07, 2010 | Dell 5110cn Laser Printer
Drive belt broken
If you have to replace your drum belt and if you have a front loading machine.
First you will need to unplug your dryer from the electric.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley.
While you have the drum out, I would also recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
Good luck,
I hope this helps
Oct 11, 2009 | LG Dryers
Drum doesnt spin
Sounds like your problem may be a broken belt.
Good luck,
I hope this helps
Oct 10, 2009 | Whirlpool Dryers
How to replace my belt on Cabrio?
I am not sure about the Cabrio, but
Good luck,
I hope this helps
Drum wont turn, how do i open up the dryer to replace the belt
Good luck,
I hope this helps
Oct 09, 2009 | Frigidaire Dryers
We are trying to replace the belt to our front loader dryer DLE5977W and are not sure how to take the dryer apart. Do we start from the front or the back.What steps do we need to replace the belt. Thank...
If it is a front loading machine:
You would remove the front of the machine, that will expose the drum and belt, remove the drum and belt and that will expose the drum rollers,motor, idler arm pulley.
Before you replace the drum and belt assembly, Check you drum rollers for flat spots, If they have flat spots on them replace them. I would also recommend that you lubricate your drum rollers with a good quality of machine oil such as 3 in One Oil. This will save you later on another disassembly because of noisy drum rollers.Apply the oil at the shaft of the drum rollers.
I hope this helps
Oct 04, 2009 | Dryers
Very noisy vibrating sound when dryer is turned on.
You problem sounds to be noisy drum rollers.
Drum rollers will get flat spots on them and over time they will need lubrication.
If you have a front load machine, then you would normally remove the front and this will expose the drum...remove the drum and this will expose the drum rollers.
If you have flat spots on the rollers replace them...if they are in need of lubrication you can use a good grade of machine oil...such as 3 in one oil. You would oil the shaft of the drum roller.
If this does not solve the problem, then you may have to replace the drum rollers
I hope this helps.
Oct 01, 2009 | Amana Dryers
Griding noise while spinning. the unit heats and spins but makes grinding noise as if the drum were off track
Hello Friend, Your problem is very simple to fix. You need to replace the Rear drum support rollers. To replace the Rear drum support rollers just remove front of dryer body exposing the drum, look under the drum and you will see the belt and tention wheel in front of the motor. Now, release the tention on the belt and remove belt from motor shaft. At this point you can remove the drum up and out of the dryer cabinet. Look towards the rear of the dryer cabinet and you will see the rear drum rollers. The roller on the left has a support strap held on by a press on clip. just pry this clip off and remove support bar. Now there will be a plactic triangular clip holding the roller in place. Just remove the plastic clip and replace roller. The roller on the right just has the triangle plastic clip just remove and replace that roller as well. Be sure to lubricate the roller shafts with some 3 in one oil prior to re-installing the new rollers. Make sure you re-install all of the retaining clips. After re-assymbly of your dryer if should run like new. Happy to help, Tim. And please don't forget to give me your rating for my help. Thanks.
Jun 28, 2009 | Whirlpool LEQ8000JQ Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
18 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
