Question about Mtd Garden
Honda mtd 6.5 self propelled - Mtd Garden
  • Gary R. Kipfer Dec 22, 2014
    Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?What is your question?
  • 1,631 Answers
Posted on Mar 09, 2015
  • 40 Answers
SOURCE: SELF PROPELLED WILL NOT WORK
I would look at replacing the belt. they stretch and start slipping. also a proper cleaning and some belt dressing spray may take care of that.
Posted on Mar 31, 2009
SOURCE: Honda HRB 216 self propelled mower Cable Broke for self propelled
there is a panel in front of the gear that completes the curve of the blade path that you can remove with a single bolt on the outside of the mower between the wheel and the deck
Posted on Aug 07, 2009
SOURCE: Honda lawn mower, self propelled mechanism not working
check the mechanism first before changing the gearbox its possible that the cable might jump out from the pulley or the cable is worn out or its possible that the gear on the tire is worn out to if not then that would be the time for you to change the gear box it would be hard to change it if you don't have the right tools to work on it if you know how everything work its not that hard to replace it just make sure were everything goes memorize the parts before disassembling cause that would be you guide to reassemble it...goodluck
Posted on Aug 16, 2009
bulldogchief
  • 388 Answers
SOURCE: honda harmony self propelled cable snapped at end
Get a replacement cable, part number should be in your user manual...when you get the cable it should have directions on how to replace.
Posted on Sep 08, 2009
Dolfoff
  • 148 Answers
SOURCE: how to remove and replace rear wheel tire on my
Part # 634-0020 is listed for the FRONT wheel. Your post asks about the rear wheel. I was unable to determine if the same part number fits the rear.
FRONT
1) Remove plastic hub cab with a screwdriver around the outer edge.
2) Loosen the shoulder bolt in the center of the wheel (My guess is that you will need a 3/4 inch socket).
3) Leave the bolt and all washers/bushings together and remove the entire wheel assembly as a unit (the bolt serves as the axle).
4) Note the component locations and install the new wheel exactly as the old came off. Do one side at a time to be sure the reassembly is in correct order.
Working from the bolt-head to the mount hole, the assembly should go as follows: Shoulder-Bolt, Wave-Washer, Wheel-Bushing, Wheel, Wheel Bushing, Bell-Cone Washer, Mounting-Hole.
REAR
2) Straighten and remove 1/8 inch cotter pin from center of axle and slide ratchet-spur off the axle while making note of the tooth direction.
3) Slide the remainder of the wheel assembly off the axle.
4) Remove the small shoulder bolt from the ratchet-pawl and note the direction. Remove the ratchet-pawl and ratchet-plate from the wheel. On the inside of the wheel is a "pem-nut" which may need to be held with pliers.
5) Reassemble Ratchet-Plate, Pawl, Pem-Nut, Spur and Cotter Pin in the reverse order.
As was mentioned before, doing one at a time will help keep the parts in the proper order.
Hope this helps!
Posted on Sep 30, 2009
What is the sprkplug gap for a 6.5 briggs &statton
Contact MTD if your manual doesn't cover this, or buy a shop manual. Or go to the Briggs & Stratton website.
May 20, 2014 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Where is the spark plug on an MTD self propelled 123cc lawn mower?
Look in front of engine. Your see rubber coated wire. Unplug it, and there your plug.
Jun 03, 2012 | Mtd Yard - Man 160cc, 21" Self - Propelled...
How much oil do I put in my Mtd Gold self propelled mower
most push mowers are about a half a quart
May 11, 2012 | Mtd Garden
MTD front wheel drive self-propelled 21". Self-propelled does not work. Can it be fixed?
Yes it can be fixed. Try some basics first.
1) Check under belt drive cover for excess debris
2) Belt and Idler pulley condition
3) Control cable operation
a) rusted, frozen, broken, disconnected
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Dec 03, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
I have a self propelled MTD Model #12AV55DQ513
CONTACT A LOCAL MTD DEALER. GOOD GUESS WOULD BE 100.00
Sep 21, 2009 | Mtd 22" Yard Machine Push Mower
MTD model 123-458B 205, how to i replace starting rope
MTD does not manufacture engines. Find out what type of engine you have, then check one of the following links for more information.
Briggs & Stratton:
http://www.briggsandstratton.com/
Tecumseh
http://www.tecumsehpower.com/
Kohler
http://www.kohler.com/
Honda
http://www.honda-engines.com/
Aug 06, 2009 | Mtd 22" White Outdoor Self Propelled High...
Self propel won't allow the mower to back up freely. works fine moving forward.
either the wire going to the transmission is not tight enough and need adjustment or belt needs replaceing
May 26, 2009 | Mtd 22" White Outdoor Self Propelled High...
Garden Logo
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
