Question about Ovens
Cloth stuck to bottom of hot oven - Ovens
    Sergeant:
  • 218 Answers
Oven clean mode=burns everything up black dust easy to clean.
Posted on Jul 21, 2014
How do i get my bulb that is stuck solid out of my diplomat adp4600 oven i have got the cover off it is the bulb that is stuck
1. do spray little oven cleaner on the bulb (switch off and disconnect electricity first!),
2. leave for 15min and then wipe it off with wet (but not dripping! well moist) cloth or sink sponge, wear gloves as this foam/liquid is extremely caustic and will eat through your skin...
3. wipe off with tissue and try to undo now,
if not - spray again on the exposed bit of the thread and repeat above procedure
bit what is holding the bulb is "ancient" grease and sugars which evaporate during cooking process, then solidify and carbonise, oven cleaner is dissolving this carbonisation and allowing it to be wiped with water and cloth.
hope it work for you - as well, do not forget to vote
Jan 09, 2015 | Ovens
How to clean inside glass oven door
Taking the door off the oven and lay door on a soft surface so as to prevent scratching ,taking the door apart ( Carefully ), allow for a large work space, lay out your screws, the glass you are trying to reach is an inner glass, so obviously self clean is not going to help. Good luck!
Oct 02, 2014 | GE Profile JTP56 Electric Double Oven
Candy Built in double fan oven bottom oven not getting hot
Cheak the coils. Do a continuity test also look for signs of an electrical short(small scorched area) and clean the contact where the coil attaches to the appliance.
Apr 17, 2014 | Candy Ovens
Did not realize that burner was under the bottom of stove. Put in an aluminum drip pan on the bottom and turned ove n on for the first time. The pan is now melted to the bottom of my brand new oven. ...
Can you see that the pan has actually melted, or is it just stuck? Aluminum melts at over a thousand degrees, an oven only gets half that hot.
Try to pry it up with a putty knife.
Worse case scenario would be sanding it out with a rotary power sander after cutting as much out as possible with tin snips.
Nov 27, 2013 | Kenmore Ovens
How to change oven lamps on Stoves 600EF oven
Well if it is the same as the 720, you will find a small recess in the leading edge of the glass lens/cover. Using a blunt screwdriver, insert it in the slot and twist it. The lens should gradually come away from the side of the oven. DO NOT attempt to do this if the oven has been in use as the lenses will become too hot to handle. Put a cloth on the bottom of the oven to catch the lens as it falls to protect it. Note that there may be a cut out on the inside of the lens to go over the edge of the bulb/bulb holder, so don't try to put the lense back round the wrong way.
Nov 08, 2011 | Stoves 720EF Electric Double Oven
My light cover only turns half of cm eitherway.any idea/
It is caused by a build up of burnt grease and fat on the glass lens.
Try putting a hot cloth around it, and try to remove it with the cloth wrapped around it
Jan 25, 2010 | Neff B1641 Single circotherm super...
Heating elementglowing bright red funny smell
I
make sure the fan is working o/k, because if it is not, then the element will get bright red hot.
If the fan is working o/k, then the element will still get red hot, but not bright red.
If the fan is not working, then it needs replacing.
Jan 15, 2010 | AEG D5701-4 Electric Double Oven
How do i get an aluminum foil pan stuck from the
You may be able to get it opff with the oven hot. Whatever is holding it was liquid when hot before, so should at least loosen enough for you to remove it.
Nov 04, 2009 | Kenmore 47783 Electric Single Oven
Trouble baking
Sounds like it's running too hot. Check temps. May have a stuck relay on board. Run oven and check to see if bake element is cycling off when it reaches temps. It should stop glowing within
15 minutes from start. If it doesn't you need a relay board most likely.
Nov 04, 2007 | Jenn-Air JJW8330D Electric Single Oven
Ovens Logo
29 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
