Question about Kenmore Heating & Cooling
Air conditioner kicks the breaker off whenever it is turned on.
I would like to try to fix it, but need a wiring diagram. Do you know where I can get one for this unit? We think the problem is the starting capacitor.
    New Friend:
    Problem Solver:
  • 9 Answers
Air conditioner kicks the breaker off whenever it  - air-conditioner-kicks-breaker-off-cfywo2zfz032fqb2kezt5zxs-4-0_0.jpg
Posted on Aug 19, 2015
  • 43 Answers
Look at the run capacitor first.
Posted on Jun 23, 2009
Ac wont start kicks breaker why.
Either the breaker rating is too small for the air conditioner or the unit is defective. Choose the right size breaker for the air conditioner power requirements and ensure the wire size to the unit is correct.
May 26, 2014 | Electrical Supplies
Keeps kicking breaker
Your unit is pulling too much power which is popping the circuit breaker. Either the compressor motor or Fan motor has a problem and you need a pro here. Drawing excessive electrical current is not good and you can do even more damage to your unit by continuing to try and run it!
Jul 19, 2010 | Dometic Rooftop RV Air Conditioner
Whenever i try and turn on unit the breaker pops?
You need to check the maximum amperage the A/C units pulls and compar it to the breaker amperage. The breaker amperage needs to be greater than the A/C amperage. Also A/C's draw more than the rating when they first kick on, so a 15 amp A/C should be on a 20 amp breaker and so on.
Jul 12, 2010 | Heating & Cooling
Breaker box clicks on then air conditioner still running but warm
When you say breaker box clicks and then warm air, are you referring to the actual breaker switch in your power panel, or clicking at your ceiling assembly? When the breaker trips, the air conditioner should shut down completely, is that what happens? The compressor kicking in and out could cause circuit breaker to trip. Did the electrician record incoming voltage supply, and what was it ? 115 volts?
Jul 12, 2010 | Dometic Rooftop RV Air Conditioner
Breaker kicks as soon as it is set wont stay set need wiring diagram
Is it the breaker for the outdoor unit, because if so then chances are good you either have a locked up compressor, or a grounded compressor.... a locked up compressor can sometimes be freed with a "hard start" capacitor, but a grounded compressor is a completely failed one
Mar 10, 2010 | Ruud UBHC Air Conditioner
Air conditioner tries to start but kicks back out
Hi. are you saying that the unit tries to start up....do you mean the compressor only or that the unit does come on fan and all, runs for a short time and shuts off completely?? I just need to no what it is doing on start up before it kicks out, this would be very helpful in solving this for you. If it trips the breaker or not or does anything at all run for a second. Please let me know and I can have a solution for you. Thank You.
Shastalaker7
Jan 17, 2010 | Dometic Rooftop RV Air Conditioner
My RC air conditioner (Duotherm) kicks the circuit breaker every time I turn it on. It used to kick the circuit breaker every so often, but lately it kicks it immediately if I try to turn on the AC.
Try replaceing the start or run capacitor to the compressor. If no help you can install a start assist capacitor, it helps to start a tight compressor.
Sep 10, 2009 | Dometic Rooftop RV Air Conditioner
Air conditioner does not kick on when I turn down the thermostat
What kind of a unit is it? Is it integrated with a furnace in the attic? Need to now this information. Also, turn the thermostat to Cool/Auto and go outside to see if the condenser unit is running, if so, then there is a problem with the indoor blower motor or thermostat. Jumper the green and red wires on the thermostat and see if the blower comes on. If so, you have a bad thermostat. If not, you could have a bad fan motor or capacitor.
Jul 08, 2009 | Heating & Cooling
My son's RV throws Breakers if Hot Water Heater is on with A/C
well not knowing the year Id say you might want to get new breakers if there already new check the lines for wares and damage.
Jun 24, 2009 | Dometic Rooftop RV Air Conditioner
Panasonic cs-pw9gke i need wiring diagram
Split A/C-Cold:
You need four wires(two #10 and two #12) to the outdoor unit, leaving you house, and three wires(#10) coming from the breaker to tye indoor unit inside your house.
Split A/C-Cold and Hot:
You need five wires(two #10 and three #12) to the outdoor unit, leaving your house, and thee wires(#10) coming from the breaker to your indoor unit inside your house.
This ypical arrangment(all of them use three wires fro the breaker), yet there are other units which may require 6-7 wires connected to the the outdoor unit depends on the added features to the unit.
Regards,
Gulftecheng
Dec 05, 2008 | GE Quiet-Aire Ductless Split System Air...
Heating & Cooling Logo
112 people viewed this question
Top Kenmore Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
1STHVACMAN
Bill Long
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
