Question about Sennheiser RS 110 Consumer Headphones
I have Sennheiser TR 110 headphones. They are connected to Audio Output port in the back of my Samsung TV. I can hear sound as seen on the screen for Netflix movies but when I change to Cable Network chanels, I can not hear any sound on my headphones inspite of diligent tuning effort.Any help will be appreciated.
  • 3 Answers
SOURCE: unable to listen to my wireless
They need a minimum level of signal to switch on the transmitter.
Verify if it works on yet another system.
Make sure you have the right output on your Samsung.
Try to increase the output level of your Samsung...(up the volume, but it may be a fixed output..)
Posted on Mar 08, 2008
  • 31 Answers
SOURCE: Sennheiser rs-126 connection
Yes, you may. RCA connections are universal, just don't connect an input lead to an output jack: you might damage the jack.
Posted on Mar 08, 2009
  • 155 Answers
SOURCE: RS120 Can still hear TV when headphones are on
Ok.. first.. the simple thing is to go into your television menu and turn the television speaker OFF.
Then exit the menu and turn the volume up.. try your headphones now.
Next.. check the back of the TV for a FIXED AUDIO OUT.. plut your headphones into these outputs.. if you have these.. you can simply turn the set down.. and use the volume control on the headphones.
Posted on Apr 24, 2009
  • 155 Answers
SOURCE: audio from tv is not restored by turning off power on headphones
It sounds as if you are plugging the base into a standard headphone jack located on the Television set.
RCA Headphone jacks (incl mini) automatically stop the sound output to the main speakers on almost every set I have seen.. or home stereo.. etc etc
In other words you can take a standard RCA jack.. with nothing connected to it.. plug it in while the music or sound is coming out the main speaker.. and it will cut off the output to those speakers..
If you set has audio outputs on the back.. preferably Fixed Audio Out .. you will need to connect your base unit to those.. turn your set volume to 0 and adjust the headset volume using the control on the right ear-cup.
If you have variable audio out.. you will need to go into your TV sets setup menu.. turn off the speaker.. and turn up the set until you achieve a signal and decent volume through the headset.
If you are missing these connections.. your current “work around” is your only solution.
Best of luck
Posted on Jul 07, 2009
flipje1989
SOURCE: Sennheiser Hd 205 headphones stopped working properly
Although I'm not an expert I'm not quite sure if armadillopic is right. I had the exact same problem and managed to overcome it by replacing the cable from the headphone to the mini-jack plug. I actually only had to renew the last bit of the cable but chose to replace the entire cable. I found out that when I bend the last part of the cable in the exact right position the strange high pitched sound that was going over the vocals went away and the vocals became much louder and clearer like they normally did. Perhaps you can try if this works for you as well? Just bend the last end of the cable in various kinds of positions (NOT TO EXTREME OR YOU WILL ONLY DAMAGE THE CABLE MORE!). Hope you are able to narrow down the problem to just the cable. Greetings!
Posted on Sep 13, 2012
We have just purchased a Samsung Smart TV - we have the Sennheiser RS116 headphones - they are working with the TV but when you put the TV on mute they do not mute. Is their anyway I can get them to mute....
On your old TV, the headphones connected to the internal speaker output so muting the TV also muted the headphone output. Your new TV headphone circuit connects elsewhere to provide constant output regardless of mute selection.
Jan 04, 2015 | Sennheiser Audio Players & Recorders
Sennheiser 126 connect to tv
You should be able to hook the tv to the cable box the cable box should have your A/V jacks. If so unplug the PS3 plug in your receiver to the cable box and run the PS3 through the receiver. Also check the side of the tv for HDMI inputs if you have HMDI you can go to Radio Shack and get a converter to go from HDMI into A/V
Nov 07, 2013 | Sennheiser Audio Players & Recorders
How do you connect the Sennheister RS120 Wireless Headphones to Samsung Smark TV?
You should have either a digital audio out port in the back of your tv or color coded analog out ports. Are you sure you have the cables plugged into the appropriate ports? I made the same mistake when hooking mine up, sometimes the print identifying the ports is very small. Also, since the headphones are wireless you may be receiving some kind of interference from somewhere. If you live in an apartment complex or next to a power substation that could be an issue.
Jan 02, 2013 | Sennheiser RS 120 Consumer Headphones
I am attempting to use my sennheiser rs 110 headphones with my lcd-led tv. the componet jacks coming out of the transmitter are red and black. All my componets on the tv are red and white. so when i plug...
What are you plugging your 2 RCA connectors (from the headphones) into on the television?
You are correct, usually:
White = Left Red = Right
In this case
Black = Left Red = Right
Not sure....guess some manufacturers need to be different...
Back to the issue,
You to need to connect the Black to White and Red to Red to the TV BUT you need to make sure you are connecting to an OUTPUT and not to an INPUT on the TV. Most newer TV's do have an "audio out RCA jacks" on the TV but not all. It should be labeled at the connector if it is an output, or just another input. You can always consult the TV manual to be sure.
Few things you can do to test
  • Does your TV have a "headphone jack", use the adapter (2 RCA female - 3.5mm connector) to plug into the headphone jack and see if there is sound
  • Connect the Black and Red RCAs from the headphones directly to the another output, like a DVD player, CD Player etc....
I hope this helps,
Magoo
Mar 10, 2011 | Sennheiser RS 110 Consumer Headphones
My television does not have an audio output so i connected the rs 110 to my cable box and it works fine...however i also have a dvd player connected to the tv video input and for some reason i cannot hear...
You cannot hear the audio from the DVD player because your headphones are connected directly into the cable box. I'm assuming that your DVD does not route through your cable box, thus the audio has no way of getting to your RS 110's. Also, changing the channel on the TV has no effect on the cable box, thus it won't alter than audio.
What you need to do:
  1. Look on the cable box to see if there is an option for AUDIO in (should be a pair of red and white RCA plugs)
  2. You want to run an RCA cable from the AUDIO OUT of the DVD player to the AUDIO IN of the cable box
  3. Then select the Auxillary input from the cable box and you should be able to hear the DVD
Alternatively you can run both DVD audio and video through the cable box
  1. Look for DVD IN on the cable box
  2. Connect the audio/video cables from the DVD player to the cable box
  3. To watch a DVD, switch to the DVD input on the cable box
Alternatively you can run the cable box through the DVD player
  1. There may be inputs for AUDIO and VIDEO in on the back of the DVD player
  2. You want to connect the outputs of the Cable box into the back of the DVD player
  3. You can then select the input on the DVD player to control whether you see/hear the cable or DVD
Mar 08, 2011 | Sennheiser RS 110 Consumer Headphones
No sound from the TV when the headphones are plugged in.
if you have a stereo unit(am+fm reciever) that has output to speakers, connect the out jack of the tv to input on back of stereo unit(aux in or cd input) then you can have output to headphone and speakers also.
Apr 07, 2009 | Sennheiser RS 110 Consumer Headphones
Audio from tv is not restored by turning off power on headphones
Best of luck
Dec 31, 2008 | Sennheiser RS 120 Consumer Headphones
Unable to listen to my wireless
Dec 02, 2007 | Sennheiser RS 110 Consumer Headphones
Sennheiser hookup to noncompatable Samsung DLP TV
Ok if I understand what you are saying. You are going from your TVs audio jack into an amplifier TEAC AG-V8050 and then into the Sennheiser T1250 unit? This is done to amplify the sound so your wife can hear the TV via Infared into headphones I am guessing. The connections would have to be as follows. TV RCA jack (Installed by someone to TV audio Output section, most likely the speaker) to the Amplifier TEAC AG-V8050 via RCA cable then from the Amplifier via RCA cable to the Sennheiser TI 250 IR Transmitter. The transmitter then takes the audio input and turns it into a digital signal which is transmitted via IR to headphones which your wife is using. First of all the amp TEAC AG-V8050 is not needed. what happend here is the person doing the installation took sound off of a preamp to avoid having to deal with the TV volume control. This works but it makes matters harder. So here is how you troubleshoot this problem: 1) Disconnect the amplifier and plug the RCA jack of the TV into the RCA jack of a set of amplified Mono headphones. (This is to determine if sound is coming from the TV) If not the problem is in the TV audio section and you will need to take it to a TV repair shop. 2) If audio is coming through the headset the trouble is in the amp or the sennhiser unit. To test the sennhiser unit: plug the sennhiser into the audio out of a VCR and listen in the headphones for sound. If you have sound, the sennheiser is good and the problem may be in the amplifier, but if you do not have sound the the sennheiser is bad. 3)Connect the audio out of the VCR into the audio in of the amplifier and plug the output of the amplifier into the sennheiser which tested good with just the VCR alone. If no sound is present then the amp is your culprit. Once you find out which component is the problem, I would suggest finding a rapair shop here on FitYa to repair your unit or having an electronics technician come to you to fix the bad component. This should help, Thank you, Shuttle83
Sep 07, 2007 | Televison & Video
Sennheiser RS 110 Consumer Headphones Logo
112 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
