Question about Husqvarna Chain Saw 20" Bar
How do I adjust the oiler on my Stihl 038av super
  • Husqvarna Master
  • 1,807 Answers
Turn the saw upside down so you're looking at the bottom. There will be a little hole with a flat head adjusting screw on the clutch side of the crank housing with an arrow and a + and - sign with an oil drip logo.
Posted on Feb 27, 2016
2 Suggested Answers
dontbother10
  • 2220 Answers
SOURCE: i'm looking for the oiler drive gear ona stihl chainsaw
Second duplicate post:
You provide no model or serial numbers, start with the IPL for your saw. It can be found here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
Oil System Plugged.
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar), if equipped with a sprocket nose ensure it rotates easily at least one complete revolution. Clean the saw oiler hole and channel. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out. Pay attention to the screen or filter on the free end (clean or replace, difficult to determine serviceability). Start the saw and see if it oils when revved up. If yes reassemble your saw. If no, continue with 2.
  2. Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is a left handed thread). Please make extensive notes & some digital pictures will help during reassembly.
If it does not oil on completion of 1 it is most likely a bad oiler or worm gear. Please see the IPL to aid in oiler component identification. Most Huskys have an outboard clutch we will presume this one does too. Use this a guide for clutch removal:
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check the IPL for your saw to see if any special tools are needed. Poulan (Craftsman, Jonsered, Husky) clutch removal tool part number 530031112 if needed, is under $5 from many sources,
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of starter cord or nylon rope be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises. Everyone I have ever removed had a left handed thread (tighten it to loosen it).
The clutch is under the clutch cover, Watch the video.
I hope this is most helpful. If you need additional help you can reply below and I will gladly assist you further. Good Luck, it is not as difficult as it appears.
Lou
Second duplicate answer:
Posted on Jan 22, 2010
My stihl 038av wont engage the flywheel when I pull the start rope it just pulls free
Starting assembly probably needs new spring and/or reattachment.
Jan 02, 2016 | Stihl Garden
Stihl 028 av super not oiling
Part of the routine service while sharpening the chain and adjusting the chain tension is to remove the guide bar to clean the slot and to clean the side of the saw case of any and all impacted crud. This impacted crud many times inhibits the oil flow to the bar causing it to appear as though the oiler is not oiling. Make sure you clean the discharge port of the oil pump...it will be the opening that aligns with a slot in the bar to transfer the oil to the chain.
After cleaning and reassembling, start the saw and rev it up for 2 to 3 seconds and observe the bar tip as it is aimed against a clean piece of cardboard. If the oiler is working, within this time frame, a thin film of oil will appear as it is slung off the bar tip.
Nov 25, 2015 | Stihl Garden
How does one replace the chain oiler in a 0009 Stihl chainsaw?
from stihl documentation it does not seem that you can replace it. I have appended the manual for you and an article dealing with chain oil delivery system for 0009
Stihl Chain Oiler Trouble
How to Unstop the Oiler on Stihl Chainsaw
http://www.stihlusa.com/stihl_ownersmanuals/009_manual.pdf
Jan 26, 2015 | Stihl Garden
Stihl super pro chainsaw bar oiler not working
The oiler may have become clogged with debris. Thorough cleaning may restore proper operation.
Jun 23, 2014 | Garden
How to adjust chainsaw oiler on stihl MS230
you cant. the oiler on an Ms230 is preset and non adjustable. Make sure the oil worm gear isnt damaged
Apr 13, 2014 | Stihl 021 023 025 Ms210 Ms230 Ms250...
038av fuel tank vent line
What's your question about this item? Regarding what?
Feb 07, 2013 | Stihl 038av "metal Tank" Screws Case 038...
Stihl 038 super av starts hard, once started runs great till its warmed up then dies and wont start
check the seals on the crankshaft for a leak and the ignition module for a loss of spark as it warms up.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Dec 07, 2012 | Stihl 038av Case Buffers Caps / Plugs 2...
Too much oil is being delivered on the chain, how do I adjust the oiler on my Stihl 038av super?
This is Stihl's manual showing the proper adjustment for the oiler. Flip the saw on its side, chain and bar side up, and look for a flat head screw.
Clockwise rotation on any saw is more oil, and counterclockwise will be less oil.
Nov 25, 2010 | Garden
How to adjust chain bar oiler
The Stihl 026 PRO does have an adjustable oiler and it is located on the bottom of the saw just below the clutch drum.
Stihl also builds an 026 "Standard" without the adjustable oiler, however, the hole location for adjustment is still there.
The 026 PRO will also have a decompression valve on top of the saw to make the rope easier to pull during startup. If you have the DECO valve you should also have the adjustable oiler. Hope this helps.
Sep 26, 2009 | Standard Oregon Chainsaw Chain For Stihl...
Husqvarna Chain Saw 20" Bar Logo
593 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
