Question about Whirlpool Washing Machines
Heavy duty super capacity roper 8 cycle 2 speed combination washer manual
4 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: Fill Cycle Won't Stop
heres hteaprt numbr for both the water level switch and the connecting tube, before i replace he switch make sure the tube is connected to rear of tub nad isnot cracked or kinked, and connected correctly to the switch for that matter. a hole in the tube would hamper he switches ability to sense when unit is full
3356466 water level switch,3347780 pressure switch tube
Posted on Mar 16, 2008
  • 747 Answers
SOURCE: Roper heavy duty super capacity 8 cycle fabric softener mess
check to see when and where you are to add the softener read the manual for tips look in the trouble shooting guide
Posted on Jul 07, 2012
SOURCE: Roper, whirlpool heavy duty super capacity plus will fill and agitate, but will not spin and drain. Help?
Have this problem right now. Problem was lid switch. I taped the switch back together the first time it busted. That fix lasted 5 months, and just happened again. I've seen the part online for about $25, but that seems a bit high to me. I may buy a generic lid switch and wire it in myself. Won't be as convenient as replacing the entire assembly, but it's probably a $5 fix if I do that.
Posted on Dec 07, 2012
My Roper heavy duty 8 cycle 2 speed combination washer does not fill up on rinse cycle
when in rinse washers use just cold water so clothes don't wrinkle,try this,set the washer to just cold,start it and see if it fills or fills slowly if so you have a bad water valve on washer or no cold water going to washer.
Dec 04, 2017 | Roper Washing Machines
I HAVE A Roper heavy duty 8 cycle 2 speed combination water won't come into washer machine nor will it work on any wash cycle, but will spin
If u have no water I SUGGEST CHECKING WITH A METER UR INLET WATER VALVE THE COILS MAY HAVE GONE BAD
ALSO MAY WANT TO CHECK THE WATER PRESSURE SWITCH MAY BE STUCK OPEN
Jun 02, 2015 | Roper Washing Machines
What is the capacity size of washer model fws1339ac1
Dimensions/Weight/Electrical Height: 43 5/8" Width: 27" Depth: 27" Approximate Shipping Weight: 180 lbs. Electrical Requirements: 120V/60Hz. Features Control Location: Top Console Capacity: Super Capacity Tub Size (cu. ft.): 3 Agitator Style: Twin Spin Cycles: 13 Wash/Rinse Temperature Combinations: 3 Motor Speeds: 2 Heavy Duty Motor (Hp): 3/4 Total Front Serviceability: Yes
Aug 30, 2012 | Frigidaire FWS1339A Top Load Washer
Jul 06, 2012 | Roper RAS8445KQ Top Load Washer
I'm just a tentant asking a question before calling maintenance. Is the agitator suppose to only turn in one direction? I thought it was suppose to be a back and forth movement. This model is a...
You have a 2 part agitator.
The bottom portion moves back and forth. The upper corkscrew moves clockwise only,pulling the laundry down and around the tub.
Jul 21, 2011 | Estate ETW4400VQ Top Load Washer
I have a Whirlpool Heavy Duty-Super Capacity Plus, 7cycle/2 speed. Model LSR7200EQO , the agitator stopped working
My whirlpool heavy duty 2 speed 7 cycle washer machine stopped working, It fills up and aggitates for the first cycle then when it should drain and spin it doesnt drain nor spin
Jun 05, 2010 | Whirlpool LSB6200KQ Top Load Washer
Won't spin or agitate
coupling.between motor and gearcase.
Nov 11, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
257 people viewed this question
Dan Webster
Dan Webster
Sal De
