Question about Vehicle Parts & Accessories
I have a 2000 jaguar S-Type. My heater hasnt worked for 2 yrs. my A/C worked last yr but is not working this year. What could be wrong w/it?
The pipes going to the heater core heat up when i try to use the heat. But the heat still wont work. When i try to use the A/C it only blows out warm air. I dont know what to do. Any suggestions?
    Habit-Forming:
  • 27 Answers
There is a gas(freon) leakage and the ac circuit lost all or large quantity of the liquid...so ac compressor does not start .You have to find where the leakage comes from and repair it accordingly and then refill ac system with freon liquid. Have in mind that this kind of liquid can easily leak from a cracked hose and which crack is like a single hair.
Posted on May 15, 2014
    Dedicated:
    Visited the website for 20 consecutive days.
  • 341 Answers
Unfortunately it's a big problem with all jags for over 25 years. same thing every time. Inside the heater unit there is a complex system of pipes and diverter flaps that direct the air flow through the matrix and a/c exchanger. It's a mess. they fail or get jammed (or both) sometimes a fuse can be changed (but it probably blew because of a jam) It's over complicated. Sorry I can't wave a wand here, but I've owned 7 Jags, between 87-98, same with all of them.
Can you afford a Jag service centre ? (I love jags but this kind of problem wore me out) But just check if you a/c needs charging and your coolant is topped up. It sounds like Heater diverter valve has jammed though. All electronic !
  • gmduvall May 22, 2014
    As an instant check, look towards the "Heater Valve" they become corroded, often due to incorrect coolant mixture. It starts to draw more amps as it fails, this in turn will eventually cause the climate control module to fail. Vibration and leakage are the main cause of this problem, then it spreads, control flaps etc....It's a common problem as I said in my previous note. At least you have a start point. good luck Red
Galaxy dx55hp stuck on channel 10.695
radio has a 3 yr warranty .send it back to galaxy
Nov 15, 2012 | Galaxy Radios DX-959 40-Channels Base CB...
I have a jaguar s type , year 2000 , the heater is only blowing cold air
Sounds like your heater core could be blocked up or a blockage in the pipes. Most car heaters run off a heater core that cycles hot water from the engine's water jacket, or a heat exchanger around the exhaust manifold, through the core, with a fan then blowing this hot air through the vents to you. If the pipes from the water jacket to the heater core are blocked then no hot water will get through. Alternatively, the heater core or pipes may be damaged and leaking. Check to ensure you're not losing any coolant. If it's the heater core, there's really nothing for it but to replace it. I'm not 100% sure where it would be on your car, on my old car it was up behind the centre console, under the dash. Hope that helps. Cheers, John
Nov 23, 2010 | 2000 Jaguar S-Type
Air conditioner not working after not using the car for 1 year?
Could be that the system needs re-charging with freon, if its not been used for a year, it probably needs an overhaul, Get some one whor's qualified to check the aircon system over. Otherwise you'll just be pumping freon into the atmosphere creating you own hole in the ozone layer.
Jul 19, 2010 | 2000 Jaguar S-Type
My heater is not blowing hot air, i have a jaguar s type
look under the hood to be sure the heater lines are ok and hooked up also look for a shut off valve - some people shut off the heater core for the summer -
also check all fuses if it is not blowing or is an all electric control on the dash -
Dec 26, 2009 | 2000 Jaguar S-Type
Cataliyst converter bank one; heater valve; etc. for Jaguar typeS
change O2 sensor their cheap enough ,heater valve not sure about ,seat and mirrors is either a fuse or a relay
Jan 05, 2009 | 2000 Jaguar S-Type
2000 jaguar s-type heat does not work from the driver side vent.
Hi there is a, dual valve down on the right side of the radiator to split the heat to each side. are the pipes hot where they enter the car be careful       D
Dec 30, 2008 | 2000 Jaguar S-Type
2000 Stype Jaguar Heater doesn't work properly
WATER CONTROL VALVE.LOCATED AT BOTTOM OF RADIATOR ON DRIVERS SIDE.HAS 5 WATER PIPES COMING OFF IT.CHANGED MINE YESTERDAY AT A COST OF £145 +VAT.HEATER IS NOW RED HOT
Nov 18, 2008 | 2000 Jaguar S-Type
Jaguar x type
I have the same car and had same problem. Your water pump needs to be replaced. That is where the leak is. Not a major job nor that expensive. I recommend using the green 2-year coolant vs. the orange 5-year coolant. The 5 year coolant does not protect well against cavitation (exploding bubbles) which is what caused your water pump leak. (You can research this on the I-net). The standard 2-yr coolant does protect against cavitation.
Aug 05, 2008 | 2003 Jaguar X-Type
Heater will not work
Its likely to be the heater contol distributor located in the front of the engine compartment under the right hand (when sitting in the drivers seat) headlights. Its very difficult to get to, it took me around 2 hours to change. Its ideally done on a ramp & cost around £150 (ukp) for the distributor valve block + £30 for proper antifreeze aprox 2 years ago.
Jul 31, 2008 | 2000 Jaguar S-Type
Dyna glo RMC95C6 kero heater
I suggest you replace the wick and clean the wick feeder assembly. I did not own that model but did have one a number of years ago. The wicks can begin to dry out.
Jan 08, 2008 | Northern Tool 10,600 BTU Radiant Kerosene...
Vehicle Parts & Accessories Logo
77 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
