Question about Amana NFW7300WW 4.0 cu. ft. Front Load Washer
My Amana 7300 will not finish the wash cycle. I've unplugged it, checked the hoses and run water through it. I can get to eventually drain and then spin but it does it again on the next load. could it be the drain?
  • Amana Master
  • 5,323 Answers
Washer will not drain:
Thedrain water pumpis the main part in your washing machine that pumps out the water. If this is defective or has failed in any way, this will be the reason why your washer will not drain the water. Before you order a new drain pump, make sure tocheck the pump to be sure a small object like clothing or similar has not lodged itself insideof it causing the NO DRAIN issue. If the drain pump is not clogged, you can test it with a multimeter and remove and replace if needed. Go to Google or YouTube and search for "Replace Washing Machine Drain Pump" then type your brand and model number of washer to show you details on replacement.
Read more:http://removeandreplace.com/2014/10/30/fix-washing-machine-that-wont-drain-washer-not-draining-water/#ixzz3X2LbXMWJ
The washing machinedrain hoseis where the water flows through to get the water out.If this drain hose is blocked, kinked, bent, or clogged, the washer will NOT be able to remove the waterfrom the tub. Check the drain hose to be sure it allows the water to flow freely. You can take the drain hose off and run water through it in your sink to be sure it is not blocked. If there is water STILL in the washer when you remove the drain hose, grab a bucket as the water will exit from where you disconnected it
Thewater pump belt(to drain out the water) may have broke or become frayed or loose.If this belt breaks then it is unable to drain and remove the water from your washer. Inspect the belt to see if this is causing theNO DRAINissue and remove and replace if needed. Go to Google or YouTube and search for "
If thelid switchis not working as required it will cause your washer to not drain (and many other problems).This may be unlikely as a bad lid switch will usually cause your washer to alsonot agitate or spin.However on some models this can vary. The best thing to do if you have a suspected bad lid switch is to test it. It can fail electrically and or mechanically. If mechanical failure is the issue, you should be able to see if it is cracked, broken, or not in place to make contact with the lid. To test it electrically, use a multimeter set on Ohms and test it for continuity
Posted on Apr 11, 2015
fanny
  • 146 Answers
SOURCE: Amana Top Load Washer model# LW3502W
Sounds like the water seal is damaged and the leaking water has damaged the top bearing which is just below the water seal. You will need to have the hub & seal kit replaced.
Posted on Oct 31, 2007
SOURCE: Amana LWA50AW Washer Leaks!
Same problem here. It's coming from Shaft. Any instructions???
Posted on Apr 26, 2008
SOURCE: won't drain or spin
Sounds like the lid switch which is only about 30.00 to fix if you do it yourself. It's a little difficult but it's much better than replacing or having someone come in and do it
Posted on Mar 11, 2009
smartr10U
  • 1305 Answers
SOURCE: amana nav5800aww water on floor after spin cycle
Sounds very similar to having something such as a sock or small article of clothing that is too large to be sucked down the drain hose into the pump. So what happens is it hangs around between the inner and outer drums and sometimes gets itself lodged over the drum drain hole, and can allow water to be centrifically flung over the top of the drum. Most times when the spin cycle stops, the article of clothing will dislodge and float around inside the drum only to do it again later....
If you can remove the top of the machine, you can usually see the gap between the two drums and use a piece of coathanger wire with a small hook on the end and "go fishing in the area between the two drums and close to the drain hole location... bet you'll find something in there... Let me know how it goes... and if I can help .. ken
Posted on May 10, 2009
Illeagle
  • 525 Answers
SOURCE: noise in the spin mode on a Amana LWA50AW top load washer
Based on your description, it sounds as if your outer spin bearing is faulty. See link below for an illustration of the bearing. Special tools are required to replace this item.
Illustration provided by; www.repairclinic.com
http://www.repairclinic.com/SSPartDetail.aspx?s=t-ALW480DA-%3d%3di549695&PartID=549695
Posted on Aug 07, 2009
Amana front load washer has wet clothes after the complete wash cycle finishes
From the information you have supplied, I suspect that the machine is not draining the water away,
1] Check that the drain pump is working (it would be easier to hear it running, before the machine starts the spin cycle, or if your machine has a "drain down" feature)
2] If the pump is running, stop the machine and unplug it from the mains power. Remove the machine drain tube from the point where it is plumbed into the household waste pipe, and lay it down into a bucket, or large pan and allow the water to drain down [ you should expect to get up to 2 gallons (10 Litres) of water from the machine]
Allow the water to drain down completely by holding the drain hose as low as possible into the bucket.
3] once the water has drained completely, remove the drain hose from the pump and check that the drain hose is not blocked.
4] If the hose was clear, and the pump was running (in tests [1] & [2] ), it will be necessary to check that the drain pump, and the main hose from the tub to the pump are clear of obstructions.
Remove any foreign objects, and re-assemble the hoses to the pump to the machine, and the drain hose to the domestic plumbing.
Plug the machine into the mains power, and and set the machine to run on the "last rinse" and "spin" cycles and test to see if the problem has been rectified.
I hope this helps cure your problem.
Oct 13, 2016 | Amana Washing Machines
Why is my Amanda 7300 tandem washing machine not doing the wash cycle? It stops after water has filled and stats to beep 3 times in intervals....
Sometimes this can happen when the power button does not return completely when pressed in. My cheap & cheerful solution was to use a bit of Blu-Tak on the button, so I could pull it all the way out.
Sep 23, 2016 | Amana Tandem 7300 Washer and Dryer Stack...
My Amana 7300 tandem is holding water in the wash tub won't drain
Check for a sock or other obstruction in the drain hose before the pump...
Mar 23, 2016 | Amana Washing Machines
I have an amana tandem 7300... It does not do anything i turn it on it makes a buzzing noise....
First part any program is to activate pump to expel any water left from previous wash.sounds like something is blocking pump.coins/bra wire / hair bobble etc.if theres a flap at bottom of machine you ll find a bung behind to unscrew.water will come out! So tke drain hose from back and hold at ground level in a bucket etc then remove bung.u should be able to feel a plastic impeller(cross piece that turns) if it wont turn pullout what ever is stopping it.best to unplug machine first but quite safe to clear by hand.then put back bung and it should then work
Nov 22, 2015 | Amana Washing Machines
I have an Amana front load washer, it will run through a complete cycle when empty but will not run with a load in it.
Hi Ben
I see you have posted on this before , I think you may have done this already judging from your post , but have you checked the filter on the drain pump? also when you run a cycle empty, is it filling and draining the water correctly , or is there water left in the machine , and last is the drain hose high enough to make sure that there is not a "syphoning" effect taking place as in when it fills with water it drains at the same time , just a thought let me know.
Oct 13, 2017 | Amana Front Load Washing Machine Washer...
Cycle not working properly
Hi.
When problem is in the spin part of the cycle it is usually because of either drain filter blockage, siphoning because of incorrect setting of the drain hose at the back, or because of a defective pressure switch.
Check the drain filter, check the setting of the drain hose at the back; clean the rubber hose attached to the pressure switch and eventually replace the pressure switch.
Most washers hide a copy of the service tech sheet inside the control panel assembly, tucked in a sealed envelope. If you retrieve the tech sheet you can also run the diagnostic cycle illustrated in the document.
Regards.
Ginko
Dec 15, 2011 | Washing Machines
Washer will not advance in the rinse cycle,water just runs continuely.
check the drain hose it should be only 6 to 8 inch in your drain line if drain hose is all the way in the drain line correct it and you will be fine.
May 21, 2009 | Washing Machines
Water runs into tub but does not fill?
be sure the drain hose is not lower than the wash tub this will caust the water to run out, 2nd be sure the drain hose is not pushed to far into the house stand pipe and the there is rome for air to go inbetween the drain hose and stand pipe eather of these will cause the machine to siphon mostly on rince cycle or on the 2nd and third loads you do. last your house drain could be starting to back up fill the washer with water and listen to it drain if you hear a gurggling sound in the house pipe you may need a plumber to cleanthis out for you.
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
E20 During Drying Cycle
if the wash cycle runs ok then unlikely to be the drain pump or hoses. put drain hose into a bucket and check waster comes out during dry - it wont be large amounts of water. can you hear the drain pump running during the dry cycle?
Mar 08, 2007 | AEG Lavamat 16810 Front Load Washer/Dryer
Amana NFW7300WW 4.0 cu. ft. Front Load Washer Logo
49 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
