Question about Linksys (NR041) Router
I cant get my wired linksys router to get online and everything eles is lighting up fine how can i fix this
  • 390 Answers
Hi
1. first have you tried with the ISP if you need any Proxy settings
2. also check with the ISP if you need any specific DNS server settings
3. if the above two are given or not required but the router still does not give out connections then try this
instead of connecting the cable from the Modem to the slot named INTERNET try connecting it in one of the out going slots (numbered 1,2,3,4) and now connect the other systems as usual.
cheers
Posted on Jun 23, 2009
We moved and when everything was hooked up i cant get a connection from my linksys wireless router to my laptop
Ok - hook the power to the Linksys - then RESET - the folded out paper clip will work. Once RESET - hook it up to your ISP provided MODEM [ You must have this service to get on the web] now unplug the Modem provided by your ISP or provider - and unplug the router.
WAIT
15 seconds - then
hook up the MODEM from the provider - then hook up the router - then restart the laptop - if wired it will need to be plugged in - if wireless - run your 'search for a wireless signal and you should have it.
Thanks
Gary @ Fix Ya
Sep 06, 2010 | Linksys WRT160N Wireless Router
Red light at power on
Too bad. The quickest/cheapest way to proceed is to buy another router, either online (through 'www.UsedEverywhere.com') or at a "big-box" consumer electronics store, for less than $50.
Aug 01, 2010 | Linksys Wireless-G WRT54GS Router...
Everything is connected my laptop was able to find the name of my wireless but was not able to connect. I'm using windows 7 on the laptop. Any idea of what i should do to fix the problem. Everything was...
Hi. First issue why your laptop cant connect to your router is regarding witht the password. Make sure that you are typing in the correct password of your router. Check the type of authentication used e.g WPA, WEP etc. Second issue, is this the first time you used windows 7 OS in connecting to your router. There are issues in linkys routers that is not compatible with windows 7 and you need firmware upgrade for your router. You can also try to test the connectivity using a wired conncetion (LAN cable) conncet directly to your router nd se if you were able to get an internet concetion using a wired connection.
Have a good one!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Jul 28, 2010 | Linksys Wireless-G WRT54GS Router...
Trying to install linksys wireless router to
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Mar 04, 2010 | NetGear WNDR3300 - RangeMax Dual Band...
Ps3 will not get online now
I had that problem with my D-Link router. What I did was re-installed the router, then my PS3 would connect and so would my PSP.
Hope this helps!
Feb 05, 2010 | Linksys Wireless-G WRT54GS Router...
I have linksys, may itouch wont connect to the internet with it
I had exactly the same problem with a brand new 3rd gen iTouch. It showed it was connected to the network but wouldn't access anything (invalid argument etc). I tried everything but no joy. Eventually I fixed it by changing the router's encryption from WEP to WPA2-PSK. Fixed it like magic. Where there had been no router or DNA data before, they were suddenly filled in. The key was different but was still on the bottom of the router. I had to re-enter the key on my wireless laptop2_bing.gif but that was a small price.
You can get into the router set-up page through your web browser. I found a guide on You Tube.
Jul 07, 2009 | Zyxel P660HW-D1 Router
Two router home network problem
Can you still connect to the Internet with the Linksys router? I suggest that you go ahead and reset the SMC router to clear up your previously configured settings. Then before reconnecting it to the linksys router, make sure that you can access its web interface via 192.168.1.1. Don't disable DHCP as your computer won't be able to obtain an IP address from it automatically. Do not change other settings. Next, disconnect the ethernet cable and check if you can access the router interface wirelessly. Once done, connect SMC's WAN port to Linksys' numbered port. Make sure SMC's WAN light is on, as well as the light for the port you used on the Linksys router. Check if you can get online.
With this configuration, the linksys router is now acting like a modem, and the SMC as your router. As long as you're online when wired to the linksys, you should also be able to access the net on the SMC once you physically connect them.
Dec 22, 2008 | SMC2804WBR Wireless Cable/DSL Broadband...
Router Question
hello!
-- what is the brand of your modem? have you tried connecting your computer directly to the modem and check if you can get online? If yes, Internet connection is fine and the problem is on the router if not, call your ISP first and check your connectivity with them.
-- have you tried connecting your computer directly to the router without connecting the modem to the router and check if you can access the router setup page? there are some cases where in the modem and the router have same IP address that's why you cant access the setup page of the router because of IP Conflict. Try to access the router page , router not connected to the modem only on the computer and change the LAN IP address of the router to 192.168.2.1. Connect the modem to the router and try again to shut down everything and power on the devices one by one and check if you can get online.
-- if after changing the LAN IP address still doesnt work, try to check if you can access the router page by the new IP Address. Make sure that you do not have other firewall or any security enabled on the pc. If yes, try to enable the MAC Address clone on the router and check again the internet connection. Try to configure the router with a diff computer also help isolate the problem
-- if after that and it still not working last option is to upgrade the firmware of the router. possible that there is a problem with the router and upgrading the firmware normally fix internal problem. If that still doesnt work, the router is defective.
Aug 29, 2008 | Linksys Wireless-N WRT150N Router
Linksys wireless router
You can try the steps on this link. This will give you a step by step guide on how you can reconfigure the the router for timewarner (cable) connection. click here.
Jul 31, 2008 | Linksys Wireless-G Broadband Router
Linksys (NR041) Router Logo
254 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
