Question about Electrolux Washing Machines
Repair manual for electrolux EWT 806 washing machine
Electroluc EWT 806 washing machine won't go into spin and the lid lock is not working
4 Suggested Answers
  • 123 Answers
SOURCE: Need Manual for Electrolux EWT 13420 W - EWT 10420
These site carries the full line of Electrolux Manuals
http://userguides.50webs.com/manual.htm
Posted on Sep 06, 2009
  • 6277 Answers
SOURCE: I have an electrolux top loader model EWT 806 and
(no promises but try this!)
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jun 16, 2011
ftw1952
  • 10319 Answers
by clicking onto the provided website below you can download the manual for your washer explaining how to correct your problem. It has a chart toward the end which explains what to do
It would be too long to type everything in myself
http://www.google.com/search?q=electrolux+top+loader+model+EWT+806+it+will+not+spin+dry+The+lid+lock+light+is+blinking+and+it+keeps+beeping+&rlz=1I7GPCK_en&ie=UTF-8&oe=UTF-8&sourceid=ie7
Posted on Aug 06, 2011
Electrolux ewt 115
Hi Cong Tran.
To buy parts for your machine you should go the the manufacturers distributor with the full model number. (The shop where you bought the machine may be able to help you with that information) The parts shop can easily tell you cost and availability of the part.
Good Luck
Cheers
Nomess
Jan 03, 2015 | Electrolux Washing Machines
Ewt 905 manual
my ewt 905 couldn't start at all when i switch on power. but i tried my other devices on that paticular socket and it works.
Jan 18, 2014 | Electrolux Washing Machines
Ewt 1010 electrolux washing machine door won't open
Hello - Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes. If the door does not open, then it sounds like the washer is possibly experiencing a communication problem with the control board, wiring failure or faulty door lock. Contact a professional to move forward accurately to properly diagnose/repair unit.
Nov 05, 2012 | Washing Machines
I have an error code "EF" for my Electrolux
Generally, EF error is showed with an additional number on your display... EF 1, EF 2, EF 3, EF 5, EF8, or EBF.
Each error code will depict a different cause and solution. Out of these solutions, the most common is the control board and possibly the UIB (User Interface Board), or too higher mains voltage coming into the house, causing damage in this UIB device.
Test and check voltage, if this isnt solve it, relace UIB device.
Hope this helps.
Mar 05, 2012 | Electrolux EW1200i Front Load Washer /...
I have an electrolux top loader model EWT 806 and the lid won't open even have tried to turn it off still won't open please help thanking you
John C
Jun 16, 2011 | Electrolux Washing Machines
Hi, My electrolux EWT 959 washing machine keeps saying please close the lid when the lid is closed. The machine filled up full of water before saying this & now wont finish the wash. Are you able to...
Hi Donna,
I just wondering have you solved the problems? as I have a similar problems in the same washing machine model. Please advse if you've solved the problems and how
Thanks
Nov 14, 2010 | Washing Machines
My Electrolux Washing machine has fault code
www.electrolux.com.auGo here and type in the model in the search bar and download the manual for the machine this will help
Jun 11, 2009 | Electrolux Washing Machines
Washing Machines Logo
87 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
