Question about Simmons 119422C ProHunter Trail Cam 6mp Grey w/Night Vision, 32 Black LED
How can I set this camera up to overwrite the images on the SD card?
For many of these types of Trail Cams, you cannot instruct it to overwrite images, you just need to reformat the SD card using the camera's menu option for that function.
Posted on May 30, 2014
Unlock memory card sd
All SD cards I have ever seen can be locked with a little slide on the left side as you face the label. if the slide is up, the card is unlocked and can be used for taking pictures. If the slide is down, it is in the locked position, which prevents it from overwriting anything that is currently on the card. Before you unlock it you may want to verify that all pictures on the card (if any) have been saved because once you start using the card and overwriting its contents, the pictures are gone forever. If the card is empty, just unlock it, format it and start taking pictures
Nov 28, 2013 | Nikon D3000 Digital Camera
DC6550
We need to be sure of some things:
Are you saving the picture to the internal flash memory or an external SD card?
1) The internal memory will only hold 16MB of pictures, check if it's full.
2) The external SD memory can only be up to 1GB in size, anything bigger will not be recognized by the camera
1. Make sure the SD card is not "locked". Some SD cards have a little switch to prevent them to be written into.
2. SD card should be formatted by the camera preferably or as the FAT format in your PC.
Does this help you in any way?
Please give us more information as to how you are saving them and/or any further questions you may have.
Dec 12, 2007 | Cobra Digital DC6550 Digital Camera
Kodak easyshare m360 says memory full after 3 photos i just bought the camera, what i shell do < shell i buy memory card or usb for it ?
You need to switch the camera over to saving pictures directly onto the SD card.
  • Menu
  • Cam settings
  • Chose AUTO or SD card option
  • Press OK to SD card
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
If you experience problems:
The lever on your SD card might be turned the wrong way so the SD card is reading protective.
Please turn the lever and try again.
The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 2 Gigabyte and SDHC up to 8 Gigabyte
The SD card might not be faulty, try another card, since the camera could give you a message like the one you're experiencing.
Try with a different SD card that is supported by the camera.
Once you have set the settings to save onto the SD card directly you might like to transferre your existing pictures from the internal memory onto the SD card:
Question :
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card? Answer :
Follow these steps:
  • On the camera, press Review and then Menu.
  • Select Image Storage.
  • Change to Internal Memory.
  • In the menu listing, scroll down to Copy, and select OK.
  • Select a single picture, or select All.
  • When you have finished copying pictures, reset the Image Storage location to your original setting.
  • Jan 18, 2010 | Kodak EasyShare One Digital Camera
    How do I recover images that I accidently deleted?
    Yes, with a good image recovery software like asoftech photo recovery, it will be an easy job to recover deleted images from camera's memory card. follow the instructions here
    http://www.asoftech.com/articles/how-to-recover-deleted-photos-from-camera.html
    Dec 19, 2009 | Canon PowerShot A550 Digital Camera
    Pictures won't record on SD card
    maybe you are saving pictures to your camera internal memory,if so try to change it in settings for SD card,or it could be that your camera does not accept the type of sd you are using,try any other card and see
    Feb 27, 2009 | Bushnell Trail Scout 11-9830 Digital...
    Canon a400
    Card locked means that the tab on the edge of the SD card has been moved to the "locked" position. This prevents deleting or overwriting anything that is on the card, and also prevents any more images being added to the card. Move the little tab to the "unlocked" position.
    Nov 05, 2007 | Photography
    Digital Camera Will Not Save Images To SD Card
    Take a look at this caption, it may be your setting is not correct.
    Dec 16, 2006 | Concord Camera Eye-Q Go 2000 Digital...
    Storage path
    On removable memory cards. Panasonic iPalm Digital Cameras are equipped with an SD Card Slot which allows the camera to store images on EITHER an MultiMediaCard (MMC) or an SD Memory Card. Simply insert an MMC or SD Card into the camera, take pictures until the card is full, then remove it or replace it with a fresh card. You can selectively erase any or all of the images from the either the MultiMediaCard or the SD Memory Card and reuse it. Storage capacity for the PV-DC3000-A (based on included 16MB SD Memory Card) SuperFine Mode* (2048x1536/low compression) up to 13 images Fine Mode (2048x1536) up to 27 images Normal/2x Digital Zoom Modes (1024x768) up to 69 images Burst Recording Mode (1024x768) up to 82 images 3x Digital Zoom Mode (640x480) up to 150 images Motion Image Recording Mode (12 sec. max./320x240) 9 sets TIFF Mode (2048x1536/no compression) 1 image Storage capacity for the PV-DC3010 (based on included 32MB SD Memory Card) SuperFine Mode* (2048x1536/low compression) up to 29 images Fine Mode (2048x1536) up to 57 images Normal/2x Digital Zoom Modes (1024x768) up to 145 images Burst Recording Mode (1024x768) up to 172 images 3x Digital Zoom Mode (640x480) up to 315 images Motion Image Recording Mode (12 sec. max./320x240) 19 sets TIFF Mode (2048x1536/no compression) 3 images
    Aug 31, 2005 | Panasonic iPalm PV-DC3010 Digital Camera
    Storage path
    Aug 31, 2005 | Panasonic iPalm PV-DC3000 Digital Camera
    Simmons 119422C ProHunter Trail Cam 6mp Grey w/Night Vision, 32 Black LED Logo
    177 people viewed this question
    Top Simmons Video Cameras Experts
    Are you a Simmons Video Camera Expert? Answer questions, earn points and help others
