Question about Whirlpool 3.2 cu. ft. Plus Washer
Wont agitate or spin just hums - Whirlpool 3.2 cu. ft. Plus Washer
  • 3 Answers
More information is needed. What model is this?
I am suspecting a coupler between Motor and Transmission. This rubber part breaks over the time. It is easy to fix if you are little handy. Provide more description to the problem.
Posted on Jun 30, 2014
3 Suggested Answers
  • 1314 Answers
SOURCE: wont agitate, spin or drain
more than likely you have something jamming your pump im going to give you the procedure for replacing the motor coupling but stop at the pump take the hoses off of it and see if its jammed if not then reply to me and we will go further First unplug the washer and turn off the water. If you have a shop vac take the drain hose out of the drain, and through the drain hose vacuum the water out of your washer. If you don't have a shop vac go to the auto parts store and buy a pair of radiator hose clamps. Then facing the washer locates the two screws. They will either be in the front or rear of the control panel or back them out far as you can. Once you have done that pull the control panel slightly forward, and tilt it back on the hinges. Now unplug the lid switch wire but don't forget to plug it back when you’re done. Next locate at the rear of the washer body the two gold clips then push forward, and take careful note of how they fit. Then pop them out with a screw driver tilt the washer body forward at 45 degree angel and walk forward with the body, and set it down. Now you will see the white pump and motor assembly. You should see two clips holding the pump to the motor pop them off, and pull the pump off the motor shaft. Now if you fell the need to remove the pump use the radiator hose clamp. Take them and clamp the hose coming from the tub but it’s not necessary for the repair. Next disconnect the wiring harness from the motor (note the position of the harness for reassembly). Remove the two 5/16 inch screws from the motor clamps and pop the clamps off. Once that is complete, remove the motor put the new coupling on the motor and transmission shaft. I use a socket and a hammer
Posted on Mar 27, 2008
lenwest
  • 150 Answers
SOURCE: will fill water but agitator wont run.
Thats very agitating.There is a motor that runs the agitater,its either going out or you have lost the drive,a little spendy to have fixed.
Hope this helped.Let me know by rating me
For more help go to live chat.
lenwest
Posted on Jan 31, 2009
A ge top load washer first began by making a buzzing noise instead of spinning. Now it doesn't spin as fast as before or just wont spin. Jeans wrapped around the agitator shouldn't damage the spin?
the agitator spins with the tub so clothes wrapped around the agitator will have no effect on the spin other than a balance problem
The hum and failure to start spinning may be attributed to a failed (failing ) start run capacitor or program board not moving on properly
As the start /run capacitor is for the motor and if it start the wash cycle ok but after that cycle ( around 30-40 minutes) it may be too hot to restart the motor for the spin
I suggest that a technician be called in to get a proper diagnosis and a quote
Apr 14, 2016 | GE Washing Machines
Whirlpool washing machine wont drain or spin but will agitate
you have a bad lid switch. located under lid on left side of machine.
Dec 24, 2014 | Whirlpool Washing Machines
Replaced the clutch and motor coupler a month ago. Ran great. Washed tennis shoes. Came in to remove clothes, didn't spin. Wont agitate or spin, i could hear the motor running. Just replaced the motor...
Check for a failed capacitor under the control panel It is a start/run capacitor that the motor needs to start running. The motor will hum and if left will eventually burn out.
Aug 17, 2013 | Kenmore 23822 Top Load Washer
Washing machine filled but wont agitate after the fill,it humms
Maybe the agitator isnt agitated enough.....yell at it for a bit...see what happens....if it that dont make it spin poor a lil rum in the tub....
Mar 01, 2010 | Whirlpool Washing Machines
Wont spin
motor coupling is the problem. You have two one for the motor and one for the transmission one of these are broke.It does agitate doesn't it?
Sep 03, 2009 | GE WBSE2090A Top Load Washer
Washer wont agitate or spin motor hums i canturn
if the moter hums when working but does not move time for a new moter the torque side of the moter has gone look on ebay or espares
Jul 29, 2009 | Washing Machines
Will fill water but agitator wont run.
lenwest
Jan 31, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Kitchenaid top load washer wont agitate or spin
you have a direct drive washer with a coupling broke.Here is a good article on it http://repair2000.com/coupling.html
Dec 11, 2008 | KitchenAid KAWS700L Top Load Washer
Kenmore 90 series that wont agitate or spin
Could be the door switch, do you hear a clicking sound when you close the lid?
Does the motor hum at all in drain/spin?
Mar 12, 2008 | Kenmore 45981 Washer
Whirlpool 3.2 cu. ft. Plus Washer Logo
41 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
