Question about Fitness Quest Eclipse 1100 Hr/A Elliptical
How can I get the timing circuit and/or circuit board fixed on the Eclipes 1100Hr/A?
When I call the customer service number or (try to) go to fitnessquest.com they appear to be out of business. I am willing to send the board somewhere, but don't know where or if it would even be worth it.
    Scholar:
    New Friend:
  • 61 Answers
You're quite correct: Fitness Quest failed, and replacement parts prove virtually non-existent. The company faced a huge recall for a machine which the 1100/hra served as the replacement. (Searching and auction sites only very rarely come up with such items as your console.)
My story with the Fitness Quest1100Hr/A:
Are you certain that the console's innards are shorted out? During the last few turbulent years, spiders seemed prefer lodging and breeding in the console of my same-model elliptical--the board proved filthy and covered with spider webs!
I have a good background with self-building PCs: That involves fooling a good deal with circuit boards. Forgive me for not making a youtube video--frankly, I figured that my chances of success proved quite poor. (I did succeed, though: It seems a miracle.)
Retracing your steps:
It's likely a good idea to take a video of disassembly with your phone or other camera/videocam--then, you'll be able to note again which screws and parts prove necessary to replace--in the correct locations--upon reassembly. Put a good light overhead--or, have a good lamp nearby--decent lighting improves photo resolution.
Tools needed:
1. Appropriate-sized Phillips screwdrivers.
2. Some type of very pure alcohol--95%, or bettter. Ethyl Alcohol ("Everclear" from a liquor store) may be the best choice for most non-pros. Old-fashioned Tape head cleaner is mentioned favorably, too--it's hard to obtain these days, though. If you must use a solvent, acetone is my favorite--it's really pure and evaporates really quickly. (I'd avoid solvents, though--they may hurt the circuit board or electronics. (Electronics jargon: PCB--printed circuit board)
2. A clean (new) toothbrush--or, better yet--a special brush, intended for cleaning from a hardware store. (These tend to be from China and are in sets of three--you need the brush with the nylon bristles, of course.) Why not both the toothbrush and the better hardware store brushes?!
3. Compressed air can.
4. Alternately, A techie friend, relative, or teen--knowledgeable with fixing PCs, TVs, phones, tablets, consumer electronics, or circuit boards--if practical. (Often, "gamer" whiz-kids qualify.)
Removing the console from the machine:
Use jar lids, small saucers, etc. to keep identical screws and fasteners together and intact--corralled! (Also, they actually might not lodge into your bare feet later!) Plates or smaller plastic containers, etc. will help you to corral the plastic parts--front/back plates, bezel, etc.
1. Unplug the power cord/power block from the console. (An aside: The power block (technically (and, fittingly) called a "rectifier") changes your wall's alternating AC voltage current to a far weaker "straightened" continuous DC current and voltage. Circuitry generally requires such weak DC power. Such circuitry naturally proves quite delicate and also really sensitive to static electricity. (Thus, the need for grounding oneself.) The need for DC current indicates why you see so many of these blocks prove necessary for electronics--if such a block is not necessary outside such devices, internal circuitry likely must achieve the same results.)
2. Unscrew the console from the top tube. (Larger screws here.)
3. Undo the connectors of the wires (three, I believe--two are associated with heart-rate monitoring) connected to the console. Keep track of the wires--if necessary, tape them to the outside--on the sides analogous to original connection. Don't touch any parts of the circuit boards or LED screen at this point.
Dealing with the circuit board.
1. Find a place featuring clean hard-surface flooring (a clean kitchen counter top or a clean good table). Try to avoid carpet. If necessary, obtain an anti-static wrist strap--if pressed for a better environment, as described--waiting a few days from an online vendor like amazon, newegg, or tigerdirect may prove a good idea. (Radioshack may still have these, too.)
2. Ground yourself (and, the optional wrist strap) by touching the middle screw of a nearby electrical outlet--or touch a metal plumbing fixture. Alternately, if you have a plugged in desktop PC nearby (and have turned if off), touch a mounting screw for its power supply. Probably, something large and metal will do, as well. It's a very good idea to re-ground yourself often when fooling with the boards and other electronics (LCD/LED screen).
3. Unscrew the back plate from the console. Note any damage (burned electronics, etc.), dust, debris, and cobwebs. Note also the screws holding the circuit boards to the front plate and those attaching the bezel (the plastic "frame" at the front which secures the LED/LCD) to the front plate. It's an analogous and similar setup for laptops, PC monitors, phones, and tablets, by the way.) Certainly avoid breaking plastic parts--they simply may not be replaced.
4. Carefully, use the canned air to blow much or most of the debris away--try to avoid pointing the can downward too far--the air will then prove even colder, causing a little condensation on the boards/LCD. It's probably OK, though--such condensation likely evaporates pretty rapidly.
5. If you believe that enough debris proves left to short out the board, don't reassemble and plug it in to test--yet! (Please note step 6 (the LCD area), too.) Given that compressed air isn't enough, and, remembering to ground yourself (again!)--unscrew the circuit boards from the front plate. Note that the main (or, another) circuit board is attached to the LCD with a small ribbon cable. Undo the connector--noting the orientation of the relevant connector--it likely fits in only one manner, anyway. (Your phone or cam may prove useful again, here.) I believe that a small piece of tape (similar to duct tape) weakly secures the small ribbon cable to the LCD--simply peel that from the LCD--leave it attached to the cable. (Note the tape's purpose.)
6. Note the space between the front plate/bezel and the LCD. If you have major debris problems, undo also the bezel and the small LCD screen. (be gentle and "static-free," of course!) Carefully invoke the canned air again on the LCD--avoid condensation onto that. Keep track of your screws, fasteners, and plastic parts.
7. Given stubborn debris (or cobwebs) remain, ground yourself again, and work over the circuit boards gently with the brush and alcohol.
8. Let the ethanol or other nearly-pure alcohol or gentle solvent dry for several minutes.
9. Retrace assembly. Plug in the rectifier, and note function.
Given that you (and, your pal(s)) can't get your console to work, loads of used ellipticals, treadmills, and stationary bikes prove available at used sporting-goods stores, thrift stores, online/craig/ebay, or free/inexpensive print classifieds ("Iwanna," etc.).
The economy remains still at least somewhat poor: Such beasts prove too heavy to ship economically--thus, users must sell or donate locally. Moving, deaths, illness, quitting, space, and shedding keeps prices low. (This includes instructive content--really, almost anything exercise/fitness gear-related--resistance-cords, weights, benches, etc.)
Replacement may prove a better solution than trying to find someone to fix your console's board(s)/LCD. (Besides, such pros likely prove not well set up to test the board(s)/LCD--certainly, without the rest of your machine!)
Frankly, such pros these days prove too busy fixing phones, tablets, laptops, enterprise-computing/networking, and expensive LCD/LED TVs/pricey home theater electronics to fool with this. Thus, it will prove difficult and expensive to find a business willing to take this on--it's far too rare a request--a specialized and discontinued item, as well. If your console proves actually broken--"biting the bullet" by obtaining used or new likely prove better options....
I know that this appears long and complicated--once you get into it, it's much easier than this seems! I'll keep track!
Posted on May 16, 2014
How do i find the value of a burnt component on a circuit board from a samsung tv?
JAMES THERE SHOULD BE A SITE ON THE INTERNET WHERE YOU COULD CALL SANSUNG CUSTOMER SUPPORT TAKE A LOOK!
Jan 24, 2016 | Samsung Televison & Video
Tip
How to choose a good PCB (Printed Circuit Board) manufacturer ?
RayMing - Your trusted partner
RayMing - In Asia alone, there are so many thousands of options when you want to select a printed circuit board manufacturer or fabricator, but which one is the best? RayMing has been in Printed Circuit Board industry and confident we offer the best combination of price, quality, on time delivery and customerservice to the customer. That is the reason we think that as a customer of Printed Circuit Board product, you should ask about PCB manufacturers to help youcompare and choose the best printed circuit board manufacturer for your company.
First factor: When selecting a quick turn PCB manufacturer or supplier, you need to look at how long they have been in business and how stable in term offinancial stability of the company. The printed circuit board industry is highly competitive especially in Asia and many PCB manufacturers come and goespecially in Taiwan and China. This causes your commodity manager or purchaser continue searching for Printed Circuit Board supplier which will costs youboth time and money when come to selecting a Printed Circuit Board company.
Second factor: Does your Printed Circuit Board supplier just take your order or do they offer value added services to ensure highest quality,
manufacturability, and performance accuracy of your circuit boards?A good quick turn Printed Circuit Board shop will offer extra value added services to go above and beyond their competitors. The obvious services like
additional cost savings proposal, extra reliability design, manufacturing assistance through the project, timely communications to ensure no surprises and noimpact in term of on-time delivery.
Third factor: Is your supplier follows new regulations and standards associated with RoHS compliance and lead free finishes?
While most other Printed Circuit Board companies were trying very hard to makes changes to meet RoHS compliance for circuit boards, you need to ask specificquestions and look detail into various industry standards that the Printed Circuit Board supplier has met. In Asia, ISO standard might be a good gauge. Anautomotive certification of a Printed Circuit Shop houses might be an additional value add to their capabilities standard that you can consider in your PCBsurvey list. refer
Quick Turn PCB for more information for quick turn pcb.
www.raypcb.com
on Jul 22, 2010 | Computers & Internet
I can't sign in with my address
What about User Name?
Has account been banned or suspended?
Have you tried Pogo Help Options? http://news.pogo.com/faqs/?site=pogo
Nov 19, 2015 | Pogo.com Video Game Consoles & Games
Get my account back
######## 1-888-218-0473 ###### Pogo games technical support number//Pogo games telephone number//pogo game tech support
Feb 22, 2015 | Pogo.com Video Game Consoles & Games
Why am I having a problem to get in the Rated Games in Jungle Gin
Get Instant Fix by Pogo Game Customer Support Call Us : 1-888-218-0473 Now To Get Support, Instant Fix.
Dec 22, 2014 | Pogo.com Video Game Consoles & Games
I bought a samsung LCD TV 32 inch series 5 on april 2010 after an year in june 1st, my tv is not turn on. samsung service man saying that PC Board should be changes costing INR 5000/. How can I solve the...
Dear Moorthi,
Generally the manufacturer will not give warranty after the time expired.they will charge for it.but you can try by contacting their customer care and tell them about what the service man said and request for a consideration:(with old complaint no)
Samsung Customer Care Numbers India : 1800 110011 (Toll Free from MTNL/BSNL) & 30308282(Prefix Local STD Code)
Timing For Calls Monday - Sunday : 9.00 AM - 8.00 PM
if they reject for a service please contact any local LCD service center they will fix your problem . authorized service center guys will change the entire board for a simple problem and they always charge a heavy coast.
Jun 17, 2011 | Samsung Televison & Video
Mag 37MFR231D turns off when volume - buttion pushed
You will need a service manual for this repair. The repair will be of the switching circuits and requires a way to trace the circuits from the switches to the main switching control.This is most likely a IC and will have designated pin in pin out circuits for each switch control.You can go to the Magnavox customer support website at http://www.magnavox.com Go to the support section and ther you will find a place to buy parts and accessories. You may be able to purchase a service manual there. You can also call the customer support at this telephone number 1-800-705-2000. Give them the model number of your television and ask them for help in geeting the service information and parts for your repair. I hope this information helps you with your problem.
May 07, 2009 | Philips Magnavox 27MS343S 27" TV
Volume on the tv
You must first determine if the audio in the television set is still working. You will need to connect the television audio output to a stereo input. Then try using the volume control and see if the circuit responds normally. If the circuit responds normally , you have a problem with the television speakers. They can can be serviced or replaced. If the circuit does not respond normally you have a much more serious problem in the audio circuits.This is usually found on the main controller board. The probelm could be with cold solder joins, component failure, or a bad audio processor ic. These problems will have to be serviced by a service center. They will have all the correct service information to test the television and repair it. You can call Dynex customer support at this telephone number 1-800-305-2204 between the hours of 7am-12am CST. Give them the model number of your television and tell them about the problem with a loss of audio. They will be able to tell you how you can get the television tested and repaired. I hope this information helps you with your problem.
Apr 15, 2009 | Dynex DX-LCD37 TV
Time Projector problem
The reason these projection displays have problems is usually caused by over expanded solder joints. This is caused by heating in the circuit,through prolonged use. This causes the metal in the solder joints to expand. This expansion will eventually cause the joint to loosen. The join because of the combination of expansion and vibration eventually loses contact with the circuit board connection.The problem is usually easily repaired by resoldering the cold solder joints. This type of problem occurs in all types of electronic devices. When this type of repair does not fix the problem, it is because during the process of becoming faulty it has taken it toll on other circuitry in the circuits of the leds. This is usually the power supply circuit for the leds. This will require the replacing the defective components, like transistors and ic's. This is usually best handled in the service centers. They will have all the service information and parts for the repairs. The customer support telephone number for Emerson is 1-800-898-9020 you can call them between the hours of 9am-5pm CT. Give them the make and model number of you Clock/Radio and ask them for assistance.I hope this information has help you understand the reason for the problem with your Clock/Radio. Thank you for using FixYa and have a nice day.
Sep 21, 2008 | Emerson Smartset Clock Radio
Beam Central Vac Breaker Pops
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=797869
Generic problem for all Vacuums
Posted by tinateggart1 on Jul 17, 2008
The breaker on our beam model 167 central vac popped while in use. Every time I try and restart it, it immediately pops again. What's the problem? Circuit board? Motor? Overheating?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Chances are it is the relay switch on the inside of the Beam Central Vac, if it was a motor, it would not turn on @ all. If it was a circuit board, it may or may not be turned on, but if it will turn on and then pop your circuit breaker than it probably is the relay switch. Please, check with your local Beam vacuum cleaner dealer in your area or contact the Beam website or cust serv @ the phone number listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.beamvac.com/usa/ Owner Support
Customer Service 1-800-369-2326 Phone #
Email: beam.dir-support@beamvac.com
Technical Support: beam.tech-info@beasmvac.com
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 17, 2008 | Vacuums
Fitness Quest Eclipse 1100 Hr/A Elliptical Logo
425 people viewed this question
Top Fitness Quest Sport & Outdoor - Others Experts
Joseph Mueller
Joseph Mueller
Dave Callender
Dave Callender
Rigger
Are you a Fitness Quest Sport and Outdoor - Other Expert? Answer questions, earn points and help others
