Question about Glacier Bay Stainless Steel Kitchen Sink: 2-Hole Double Bowl All-in-One Top Mount
How do I get a replacement woven hose that connects to the pullout faucet head and goes under the sink?
The woven hose that is connected to the pullout faucet/sprayer head and goes under the sink is cracked. Did try wrapping it with waterproof tape for a temp fix but it does not work. Need the replacement piece and not able to find. Was purchased this a few years ago as a kitchen sink/faucet combo. Believe the glacier bay was purchased at HomeDepot and the # that may help is SM1071
    New Friend:
Take the old one to home depot and have them find a replacement
Posted on May 16, 2014
Leaking faucet
I've had problems with the O-rings at the head leaking, feeding back inside the corrugated hose covering, and pooling under the sink. Might be your problem as well. Verify by holding the head downward, and look for water beading out further up the hose.
Apr 04, 2014 | Grohe Ladylux Cafe Faucet with PullOut...
Replacing hose on a Kohler model numbe K- 10433
http://411plumb.com/kohler-forte-faucet-troubleshooting-repair-guide/
Mar 11, 2014 | Kohler Model 10433: FortĀ® Single-control...
Do I have to remove the entire Delta kitchen faucet in order to replace the pullout faucet hose? If not, can you give me step by step instructions on how to replace it? Thanks.
Should be able to turn water supply off to faucet and trace the line connecting the pull-out faucet. Remove weight in center on hose line this weight helps retract the faucet head in with the line. Remove it and disconnect the line connection and remove the old one.
Feb 14, 2011 | Delta Faucet 470-DST Signature Diamond...
We have a Delta kitchen faucet with a pullout sprayer everything was fine for over a year then it started making a bang bang rattle sound very loud only when the hot water is on it only does it about ever...
Delta comes with a limited lifetime warranty. call them to get free parts. I believe you will need to check several things. Remove the spray head from the sprayer hose, point the hose into the sink drain and turn the faucet on. If it no longer makes the banging noise, replace the spray head. You need to look for a leaking spray hose under the sink also. If the faucet is making noise, replace the ball and cam assembly under the faucet handle. One other thing that I have run into is that the shut-off valves under the sink can also go bad and cause banging and vibration.
Sep 06, 2010 | Delta Model 470: Signature Kitchen...
How can I remove this faucet to allow me to replace this fixture?
there is abacking nut & plate securing tap to sink, most are 1/2 inch use long socket to make it easier, also you must disconnect pullout hose from tap (connection also under sink) & remove hose weight located usally at the bottom of pull out hose. Make sure you isolate all water first!
hope this helps
Nov 07, 2009 | Hamat 3-2861ST Everest Pull-Out Kitchen...
The pullout faucet wobbles when returned to the base.
check that nothing blocking hose return weight under sink
Oct 06, 2009 | Danze D405058 Parma Single Handle...
Leaking under sink and st base on sink
Remove spray head then faucet tighten connection on the spray hose
Sep 25, 2009 | Danze D403412 Melrose Single Handle...
Srayer leaking down the hose from pivot joint near spray head
there is an oring in that connection that is most likey bad. turn water off and disconnect coupling to spayer. remove the black oring and match it up at your local hardware store. when installin it lubricate it with vaseline for ease of insatlltion and to help protect it during installation.
Apr 21, 2009 | Kohler Model 10433: FortĀ® Single-control...
Kitchen faucet Installation
Many new faucets require some assembly before mounting to the sink; if that is the case, follow the manufacturer's directions. With most pullout sprayer faucets, the sprayer needs to be threaded through the faucet body first. Insert the rubber gasket between the base plate of the faucet and the sink top to create a watertight seal. If no gasket is provided, pack the cavity of the faucet with plumber's putty, then insert the faucet body through the holes in the sink top. Thread the mounting nuts provided onto the faucet shafts, then center the threaded shafts in the sink's holes and tighten the nuts firmly. Many manufacturers include a special long socket specifically to aid in tightening the mounting nuts. A hole in the socket accepts the shank of a screwdriver, guiding it as you tighten the nuts. If you're mounting the faucet on an installed sink, use this method. If you're installing a pullout sprayer faucet--or a faucet with a separate sprayer--now is the time to connect the sprayer to the faucet body. Check the manufacturer's directions to see if using pipe-wrap tape for this connection is recommended. Use an adjustable wrench to tighten the connection. Most pullout sprayer faucets and faucets with separate sprayers come with a counterweight that attaches to the sprayer hose. This weight helps retract the hose back in to the sink cabinet after you've used the sprayer. Follow the manufacturer's directions on where to secure the weight, and take care not to crimp the hose as you attach the weight. Hook up the faucet's hot and cold supply lines to the water supply shutoff valves under the sink. If necessary, gently bend the copper tubes coming out of the faucet for better access and connect flexible supply tubes to them. Simply wrap a couple of turns of pipe-wrap tape around the threaded nipples on the valves and connect the tubes. Tighten the nuts with an adjustable wrench.
Aug 27, 2008 | Danze D316440RBT Fairmont Two Handle Wall...
Glacier Bay Stainless Steel Kitchen Sink: 2-Hole Double Bowl All-in-One Top Mount Logo
472 people viewed this question
Top Glacier Bay Plumbing Experts
Paul Carew
Tom Chichester
Are you a Glacier Bay Plumbing Expert? Answer questions, earn points and help others
