Question about Frigidaire FEF355 Electric Kitchen Range
What's wrong with it?
Display panel no longer works, therefore oven will not turn on.
  • Official Brand Answer
  • 2,267 Answers
Good Morning Friend,
I see that the display panel is no longer working on your Frigidaire range, model# FEF355. I suggest resetting your appliance, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. Sometimes the control boards inside your appliance can miscommunicate with each other and can cause things such as this to occur. Most times they need the hard reset to get them communicating again. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your range status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Posted on May 17, 2014
2 Suggested Answers
SOURCE: Frigidaire stove
I believe the oven it has a power surge protector within the appliance. Try to unplug it and plug it back in. It should solve the problem.
Posted on Dec 20, 2008
Bottom oven stopped working there is a key symbol showing on the panel what is wrong ?
There are a few reasons for this. One is the most obvious and that is the child lock switch needs to be engaged to unlock.Some models call it panel lock.
Turning the panel lock on and off:
To turn the panel lock on, press and hold the Panel Lock key for four seconds. The Panel Lock symbol will appear in the display.
To turn the panel lock off, press and hold the Panel Lock key for four seconds. The message in the display will disappear.
Oct 04, 2014 | Bosch HBL 5056 Electric Double Oven
What is wrong????
disconnect power, pull off back panel check paperwork for fuse location if that is not broken then a simple solution I found to work on other display screens for my parents oven was to take the circuit boards ribbons(parallel lines for coding to pass through like an old school computer and simply remove and re attach this most of the time can solve this type of issue just be careful not to damage anything else). if you have any questions just ask.
May 15, 2014 | Frigidaire FEF366 Electric Kitchen Range
Kenmore c970-657084
Explosion from what? If this was a gas explosion then you should have a professional look at it. If this was a power supply issue then you will have to replace the power supply board.
Dec 02, 2013 | Kitchen Ranges
The digital display no longer lights up. How do I
if your oven works correctly and the only thing that is wrong is that the digital display is blank you will have to replace the control board remove the two screws on the side rails lower remove them set them aside remove the two screws in the side of the of the control panel pull up on it and lean it down take the screws out of the control board and disconnect the wires one at a time and put them one at a time on the new control board reassemble the unit that will complete the replacement
Apr 04, 2010 | Whirlpool GBD277PD Electric Double Oven
The Display is Dim. Hard to read the numbers.
I have the same model and problem. The time display is totally unreadable. Looking for a solution as well. I suspect given the cost (I believe around $60), it's time for a new one. Anyone have any suggestions or easy repair ideas?
Mar 12, 2009 | Sharp R-314FS Microwave Oven
No display on EOC68000 electric oven
flip breaker off then turn back on after a few min.see if that resets panel.if not you will need to call and have the control module replaced.
Mar 11, 2009 | Electrolux EOB5630 Ultrafan Electric...
F1 code on display pad
That error means the main control board has a internal failure. The board will have to replaced to fix that issue. If you need detailed repair help with that visit the link below:
Appliance Repair Help With Live Chat
Mar 23, 2017 | Amana AOGD2750 Gas Double Oven
Clock display/oven control panel
a few screws will drop rear panel to check connections, , check your power supply as wellpossible bad connection at outlet
Feb 25, 2008 | Maytag MGR5770 Gas Kitchen Range
The touch pad panel on stove is blank
on the ge range, you need an ERC its the main control for the oven. yes its costly. comes in a kit with a new wire harness
Nov 16, 2007 | GE Profile JGSP48 Gas Kitchen Range
Oven controller not functioning
9. The time of day does not display on my electronic oven control. If I push the CLOCK pad on the control panel the time will display for a few seconds and then it goes blank again.
  • On many ranges with electronic controls the time of day display can by turned off or on by holding the CLOCK keypad down for 15 seconds.
    Push and hold the CLOCK keypad. The time will appear for a few seconds, and then disappear and finally it will reappear and beep. Release the keypad and the time should continue to display. Follow this same procedure to turn the time display off.
http://www.frigidaire.com/support/FAQ-New_Electric_Smooth_Range.asp#9
Nov 04, 2007 | Frigidaire FEF336BC Electric Kitchen Range
Frigidaire FEF355 Electric Kitchen Range Logo
48 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
