Question about Insignia IS-DVD1001 DVD Recorder/VCR
Trying to record tape to dvd
Im trying to record an old baby video to a dvd. at first it seems to work, but when i take the dvd out and put it in another dvd player it says cannot read disk. If I put it in my computer it says no movie files found. Then i put it back in the insignia dvd player and its a blank disk. What should i do? am i not recording it correctly?
    President:
  • 788 Answers
After recording a DVD in a DVD recorder you will need to finalize the disk. You should be able to put it in the original recorder and at least be able to watch the video.
If you are able to watch the video while you are recording then you should be able to record what you are watching. If you cannot see the video when it is sourced through the DVD recorder, then you need to adjust the input.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up) If you cant rate this post with the highest rating, then please comment to this post and I will try to help you further.
Posted on Jun 23, 2009
Can I record multiple dvd's after I have recorded from one vhs tape
You might consider after making the first if your computer is capable of making fast copies with it.
Apr 24, 2012 | Zenith XBR413 DVD Recorder
How to switch from sp to lp mode when playing back?
Did you try setting the rec mode to SP in the playback menu?
a54f98a.jpg This is from the D250 manual.
Dec 18, 2007 | JVC GR-D250 Mini DV Digital Camcorder
For some reason I can no longer copy from my VHS tape to my DVD disk in my Toshiba DVR620KU DVD Video Recorder. I have tried some of the same tapes which had copied just fine in the past. I am using the...
How old is Toshiba DVR620KU recorder and how long it started this problem?
Does it playback previously recorded discs correctly?
Did you tried lens cleaning disc in recorder to clean optical lens?
These info will help me to suggest a solution.
Thanks.
Jul 22, 2011 | toshibadirect.com
I have an old Samsung VP-A30 video camera with loads of 8mm tapes, and would like to transfer to either TV/Video/PC. Unfortunately, there seems to be just one AV output source, which feels rather fragile,...
Hello Ron,
Well that is like you say an old camera, mind you 8mm is still far the best and safest way to store your valued films as it has kept the data on those tapes longer than any DVD ever did, remember unlike we thought 10 years ago a DVD only has around 8 to 10 years life span, we are finding CD & DVD productions that are over 8 years old just wont play any longer.
Kodak put a report on the net 7 years ago that they found even some quite costly DVD recorded media had gone blank and refused to play after a very short time in storage.
I think you ought to look around Ebay, find a nice HI8 digital camera, put your loved tapes in that, plug the new Firewire cable into the camera, and your PC and download your treasured items to another media like DVD.
Keep your 8mm tapes in a draw safe though because they will out-live all DVD recordings I can honestly say that.
David
May 24, 2010 | Samsung SC-A30 Camcorder
Sound playback problems
are those old videos recorded from the same camera? you might need a head cleaner for your camera. Try to play the tapes in different camera for comparison test. caution: make sure that the camera's mechanism does not destroy the tape or put a line or dent on the tape's edges. I suggest you convert those videos to digital format before it's too late.
Aug 10, 2009 | JVC GR-D870 Mini DV Camcorder
Playback Problem
open the recorder, 4 screws at each corner, wipe the playing head and the voice reccognition head, to the right of the playing head head with a baby wipe, you will be amiazed what **** comes off it. DON'T scrub it just wipe lightly, spin the playing head so it's clean. If you have a lint free cloth ( a glasses cleaning cloth you get in the case is brilliant) Try the tape (before you put it in make sure everything is DRY!) and your problem should be solved. It worked for me! and that came from a TV engineer
Jul 15, 2009 | Toshiba RD-XS25 DVD Recorder/HDD Recorder
Sony Hi-8 plays new recorded video buy not playback
Are they PAL or NTSC tapes ? They may not be compatible with your new equipment.
Jun 13, 2017 | Sony Handycam CCD-TRV40 Camcorder
Panasonic DMR-E55 Won't Let me Record my own VHS
Hi
This is probably caused by an irregular magnetic encoding pattern being generated by the tape itself. If the DVD recorder does not fully recognise the code, it may incorrectly interpret it as copy protected. If there is any tape flutter or there are tape edits, these can contribute to the problem. In addition to this magnetic imprinting can occur on old tapes that have been stored for a number of years without being spooled. basically wrong bits of the tape get magnetised. You can sometimes hear an echo on old tape recordings caused by imprinting.
You could try the following:
1) If available, try using a different video machine to play back and record from.
2) Whatever video machine you use, put your tape in, fully fast forward and rewind a couple of times, then try your recording again. This is particularly important if you haven't used the tape for some time.
3) If it fails again, check to see if it always fails at the same point.
4) If it does, try winding forward a little and then try to resume recording.
5) If you can record it means that a short section of tape is giving a spurious code to your dvd recorder and confusing it.
6) Use a re-recordable dvdrw to make a master. You won't keep wasting discs if the recording stops. You will also be able to produce another dvd from your master and edit it if your recording ends up in a number of segments.
7) Always use the highest quality setting possible when producing a master.
8) If all else fails, if you have a friend with another dvd recorder, maybe try that.
Have fun....
Jan 21, 2008 | Panasonic DMR-E55 DVD Recorder
Playback
most likely needs to have the heads cleaned, running that many tapes can clug your video heads. if this still does not work the take up tension might be a little low. you can fix this for free, but try having it cleaned 1st.
Sep 17, 2007 | Sony Handycam DCR-TRV460 Digital Camcorder
Recording of video in order to burn to DVD on a GSA 5169D
put tape on the hole on top of the tapes and you shoud be able to record. its tape on the top or pull the top off i cant remimber which one it is but this is the answer.
Feb 21, 2007 | LG GSA-2166D DVD RW Dual Layer Burner
Insignia IS-DVD1001 DVD Recorder/VCR Logo
149 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
