Question about CoffeeForLess.com Grindmaster Automatic Gourmet/Grocery Coffee Grinder Model 875
Is there a link to the manual of the Grindmaster Automatic Gourmet/Grocery Coffee Grinder Model 876? I could not find it on google or anywhere
  • 552 Answers
You will find "download operator manual" to the right on this link page. Coffee Grinders
Posted on May 15, 2014
Why does no brewed coffee comes out? bypass preground does work
- coffee-channel is stuck.
check google for calibrating/cleaning your gaggia.
Aug 27, 2014 | Gaggia Titanium Espresso Machine
How do i adjust the blades/grinder on my Grindmaster Automatic Gourmet/Grocery Coffee Grinder Model 876
I don't see a model 876, but there is an 875s. Here is the wesite for frindmaster and the 800 number or user manual for help. Coffee Grinders
May 15, 2014 | CoffeeForLess.com Grindmaster Automatic...
Coffee grinder wont start
Its been a while since i worked on a grind master so have a little patience with me. First, if the breaker went then there might be something blocking the burr chamber like a rock or screw or other obstruction. Second I would check the micro switch for the bag holder if there is one on your model using an ohms meter.
Mar 16, 2012 | Grindmaster 875 Electric Burr Grinder
Whatever the setting is at the grind is always fine. What can I do to re-calibrate the grinder?
Grind Adjustment Tools required: Large blade and medium Phillips head screwdrivers In order to adjust the grind, follow these steps (Refer to figure A): 1. Remove all coffee from the hopper. 2. Set selector knob to the finest setting (Espresso or Turkish) depending on the model. 3. Loosen both knob retainer screws in selector knob one turn only. 4. While pressing the bag switch, located behind the spout, press the START button so that the grinder will run during adjustment. 810 model - Press the ON or START button so that the grinder will run during adjustment. 5. With the grinder still running, turn the adjusting screw in the center of the selector knob slowly to the right until a slight clicking noise is heard. Immediately turn the adjusting screw to the left one grind setting. This is the finest grind obtainable. 6. Tighten both of the knob retainer screws. Once the ESPRESSO grind has been set (Turkish for Model 835, 875, 890), the other grind settings will automatically set correctly. 7. Press the STOP or OFF button. IMPORTANT: Always be sure the grinding burrs are not touching while the machine is running on the ESPRESSO/TURKISH setting. Otherwise serious damage to the motor may result. dr_buckhead.png
Nov 19, 2010 | Grindmaster 810 T Electric Burr Grinder
Just bought a used one, seems like the espresso grind is pretty course, is there an adjustment I can make?
To adjust this grinder turn the adjustment nob to the finest setting (ESPRESSO or TURKISH) Locate 2 small set screws on the adjusting nob. Loosen these screws (do not remove them) about one full turn. Start the grinder and, with it running, VERY SLOWLY and GRADUALLY, turn the CENTER adjustment screw clockwise until you begin to hear the burrs begin to touch (whirring sound). Back off the center screw about 1/16 of a turn, shut of grinder and re-tighten the set screws. Then try the grind on DRIP or there about for brewed coffee.
May 21, 2010 | Grindmaster 495 Electric Grinder
I have a Hamilton Beach scovil gourmet center,
I need a replacement cutting blade for an old Hamilton Beach Gourmet Center and Meat Grinder. The model no. is...174W
Thanks, Rosanna
Sep 19, 2009 | Hamilton Beach Food Processors
How do i change the burrs on grindmaster 875
Remove the screws on the knob with the grind setting, that pulls out and gives you access to the burrs.
Jul 17, 2009 | Grindmaster 875 Electric Burr Grinder
Replacement part (exit chute)
I have not heard of a solution yet.... but I did download the manuals for the machine and have the parts numbers from different models which MIGHT be interchangeable.... I only paid $150 for the machine, so I am loath to spend too much more to solve my problem.
Might go on ebay...
May 13, 2009 | Grindmaster 810 Electric Burr Grinder
Replace burrs?
here is solution how to to replace and order burs from producer. also you have diagram for opening and closing the grinder.
http://www.grindmaster.com/literature/operatorsmanual/GR-373-04%20115_250%20Manual.pdf
Jan 01, 2009 | Grindmaster 100 Electric Burr Grinder
Gm 875 parts
Any three-pole momentary switch with the correct rating would work. Try Radioshack or the like.
Good luck.
Dec 31, 2007 | Grindmaster 875 bulk coffee grinder
CoffeeForLess.com Grindmaster Automatic Gourmet/Grocery Coffee Grinder Model 875 Logo
104 people viewed this question
Top CoffeeForLess.com Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a CoffeeForLess.com Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
