Question about CoffeeForLess.com Grindmaster Automatic Gourmet/Grocery Coffee Grinder Model 875
How do i adjust the blades/grinder on my Grindmaster Automatic Gourmet/Grocery Coffee Grinder Model 876
  • 549 Answers
I don't see a model 876, but there is an 875s. Here is the wesite for frindmaster and the 800 number or user manual for help. Coffee Grinders
Posted on May 15, 2014
Coffee grinder wont start
Its been a while since i worked on a grind master so have a little patience with me. First, if the breaker went then there might be something blocking the burr chamber like a rock or screw or other obstruction. Second I would check the micro switch for the bag holder if there is one on your model using an ohms meter.
Mar 16, 2012 | Grindmaster 875 Electric Burr Grinder
Blade will not spin
While I don't have this brand or model of grinder, (coffee beans, spices?), I use a small elec. grinder for grinding coffee beans and unless the grinder and cover or perfectly lined up and locked in place, it willnot grind, a safety feature. Check and make sure everything is lined up so it closed with all the lines in place and the grinder is also put into the lock position.
Aug 21, 2011 | Cuisinart Grind Central DCG-20N Electric...
Whatever the setting is at the grind is always fine. What can I do to re-calibrate the grinder?
Grind Adjustment Tools required: Large blade and medium Phillips head screwdrivers In order to adjust the grind, follow these steps (Refer to figure A): 1. Remove all coffee from the hopper. 2. Set selector knob to the finest setting (Espresso or Turkish) depending on the model. 3. Loosen both knob retainer screws in selector knob one turn only. 4. While pressing the bag switch, located behind the spout, press the START button so that the grinder will run during adjustment. 810 model - Press the ON or START button so that the grinder will run during adjustment. 5. With the grinder still running, turn the adjusting screw in the center of the selector knob slowly to the right until a slight clicking noise is heard. Immediately turn the adjusting screw to the left one grind setting. This is the finest grind obtainable. 6. Tighten both of the knob retainer screws. Once the ESPRESSO grind has been set (Turkish for Model 835, 875, 890), the other grind settings will automatically set correctly. 7. Press the STOP or OFF button. IMPORTANT: Always be sure the grinding burrs are not touching while the machine is running on the ESPRESSO/TURKISH setting. Otherwise serious damage to the motor may result. dr_buckhead.png
Nov 19, 2010 | Grindmaster 810 T Electric Burr Grinder
Just bought a used one, seems like the espresso grind is pretty course, is there an adjustment I can make?
To adjust this grinder turn the adjustment nob to the finest setting (ESPRESSO or TURKISH) Locate 2 small set screws on the adjusting nob. Loosen these screws (do not remove them) about one full turn. Start the grinder and, with it running, VERY SLOWLY and GRADUALLY, turn the CENTER adjustment screw clockwise until you begin to hear the burrs begin to touch (whirring sound). Back off the center screw about 1/16 of a turn, shut of grinder and re-tighten the set screws. Then try the grind on DRIP or there about for brewed coffee.
May 21, 2010 | Grindmaster 495 Electric Grinder
With the dial turned to "Turkish" I still get a very course grind. How to adjust/fix?
On the adjusting knob there are 2 set screws (outside of the center) and an adjustment screw (the one in the middle). First make sure the LARGE screws on the side of the SELECTOR plate are tight. Start with the selector on Turkish, with the grinder OFF loosen the set screws about one full turn each. Leaving the selector on Turkish turn the grinder on and gradually VERY SLOWLY turn the center screw clockwise. Eventually you will hear the burrs inside touching. After they touch back of the center screw about 1/8 of a turn. Tighten the SET SCREWS tight as they may allow the grinder to go out of adjustment if not tight. Test the grind with very little coffee and throw those grounds out. Then grind and brew! If these grinders are adjusted too fine you may have problems with the grinds not falling and may back up.
Apr 26, 2010 | Grindmaster 810 Electric Burr Grinder
How do i change the burrs on grindmaster 875
Remove the screws on the knob with the grind setting, that pulls out and gives you access to the burrs.
Jul 17, 2009 | Grindmaster 875 Electric Burr Grinder
Replace burrs?
here is solution how to to replace and order burs from producer. also you have diagram for opening and closing the grinder.
http://www.grindmaster.com/literature/operatorsmanual/GR-373-04%20115_250%20Manual.pdf
Jan 01, 2009 | Grindmaster 100 Electric Burr Grinder
Gm 875 parts
Any three-pole momentary switch with the correct rating would work. Try Radioshack or the like.
Good luck.
Dec 31, 2007 | Grindmaster 875 bulk coffee grinder
Coffee beans will not grind
Your machine will probably need service. The water will cause damage to the grinder burrs.  I can send you instruction on how to clean out the grinder on a Vienna if you provide me will your email address. You can email me at support@cerinicoffee.com.
You are not the first person to do this. These problems come in at least once a week.
Hope this helps.
Johnny
Oct 08, 2007 | Saeco Vienna De Luxe Espresso Machine
CoffeeForLess.com Grindmaster Automatic Gourmet/Grocery Coffee Grinder Model 875 Logo
93 people viewed this question
Top CoffeeForLess.com Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a CoffeeForLess.com Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
