Question about Kitchen Ranges
Kenmore slide-in electric range model # 79046769908. The oven won't heat after we cleaned it. Is there a reset somewhere?
  • 1 more comment
  • Eric Moldenhauer
    Eric Moldenhauer May 16, 2014
    Hi Tricia Noyes, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? did you plug it back in and turn on the breaker not saying this is the problem but many times people forget these little things and we can start troubleshooting it from there and yes there should be a reset somewhere find the schematics blueprint for location
  • Canberra1 May 17, 2014
    More info needed. One place to start is to whip out the heating element and check continuity with a multimeter.
    Problem Solver:
  • 7 Answers
There is very likely a THERMAL reset but likely its blatently very very unaccessible. If you have lights on on the control panel, I suspect it is the reset switch, especially since you recently performed a self clean.. The panel will light up even if this switch is OPEN (ie not allowing power to the elements) I have a kenmore self clean from 2005 and the attached file shows where it is located. In the attached PDF on the blow appart drawing it shows as ITEM 119. The last page shows the wiring diagram.
Not sure if yours is the same but some things like thermal switches cannot change too much, thank fully. Get an service technician to try to reset it and then have them test for continuity. If it cannot be reset then it is a replacement around $75 -$100.
Posted on May 22, 2014
jsrock516
  • 5911 Answers
SOURCE: BEEPING OVEN
The F1 and constant beeping is an error code indicating that your electronic control board (clock/timer) is defective. The fault cannot be reset and the control board must be replaced. This can be an expensive repair if your range is no longer covered by a warranty or service plan. The cost to buy a new control board can be in the neighborhood of about $200. Sorry...but I do hope this helps you.
Posted on May 12, 2007
  • 100 Answers
SOURCE: Dacor oven will no heat.
The reset button is located near (probably behind) the latch that locks your door during sef clean. The reset is located in the middle a thermostat that looks like a round disc the size of a quater and about 1/4 to a 1/2 inch high with two wires, one on each side, plugged into it. Usually with a long thin screwdriver and the power turned off you can reset it with out having to take anything, or at least very little parts, off.
Posted on Nov 03, 2007
SOURCE: Kenmore 790 Oven Locking mechanism problem
hold down the stop/clear button for 3+ seconds
Posted on May 25, 2009
SOURCE: my kenmore elite electric slide in range displayed error and F13 and the oven won't turn on
i phoned Sears about error code f13 on a gas range, and was told to unplug the range for 30 minutes. i think she meant 30 seconds - to reprogram the microchip. i unplugged it for 15 minutes or so, then reconnected, and it worked.
Posted on May 28, 2009
rylee_smith
  • 8619 Answers
SOURCE: F1 error message Kenmore Electric range model 790.95680301
Hi
F1 error means that you have either a bad ERC (clock) or a bad touch pad. To check these please follow these simple instructions:
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Posted on Aug 10, 2009
How can I get a user manual for my Kenmore Elite 30 inch Electric slide in range with ribbon radiant elements model number 46804
Kenmore Elite Electric Slide In Range 30 in. 41053 - Sears
www.kenmore.com/kenmore-elite-30inch-slide...electric-range...
Kenmore
Rating: 3 - ‎30 votes
The slide-in Kenmore Elite range 41053 has a true convection oven for faster pre. ...Kenmore Elite 30" Slide-In Electric Range w/ Convection - Stainless Steel ... Owners manual - English (Warranty) .... I called SEARS repair to look at my range and the repairman told me that this range has flaws with the oven fan and there is ...
Kenmore Elite 30" Double-Oven Slide-In Electric Range w
www.kenmore.com/kenmore-elite-30inch...slide...electric/p-02...
Kenmore
Rating: 3.5 - ‎30 votes
The exciting Kenmore Elite double-oven slide-in range 4111 offers all the feature. ... Versatile cooktop options include a 12-inch triple-ring element, a 9-inch Turbo Boil Flex™ element, and a ... Owners manual - English (Warranty) .... Ovens are both conventional or can be set to convection, my first bake was a cheese cake.
Nov 28, 2015 | Kenmore Kitchen Ranges
I need a manual kenmore slide in range electric 90152
I don't believe that is the actual model #. Pull out the drawer and look for a sticker on the frame of the stove. Also open the oven door and look for a sticker on the frame there. If its a Kenmore the sticker should have something similar to "970-", "956-", "110.", "646-". Take the full model number and Google it. If its a "970-" you should be able to find the manual here: http://b2b.frigidaire.com/support/manuals.asp
Apr 12, 2014 | Kenmore 90154 / 90152 Electric Kitchen...
Technition manual kenmore electric range model 911 9358810
With the power disconnected, check all connections.
You may want to purchase an electrical contact cleaner.
This will ensure that all contacts are clean and that you don't have a bad or faulty connection. Often with the older ovens with the heat, it drys out the wire and you may have a broken wire at the connection.
Nov 25, 2013 | Whirlpool Kitchen Ranges
The oven heating element won't turn off
I would thing if you called an appliance service store or retailer and gave them the make and model number of the stove they can sell you one and maybe install it if you need them to but I would thing it would be called the oven switch
Jul 24, 2012 | Kenmore 91112 / 91114 / 91117 Electric...
Between glass dirty on kenmore glass top range
the door must be removed from the oven and taken apart
Oct 23, 2011 | Kitchen Ranges
I was baking and heard a pop sound and saw a spark before the oven lost all power? What happened?
OOOPPs - not good , If you saw or heard a pop noise + spark then something blew or shorted.
If the 'loss' was quiet then a fuse or circuit breaker can blow without noise or sparks.
This oven has 4 Heating elements (2 on Grill) 2 inside oven , as you were baking it sounds like a heating element.
As this is a US model I'm assuming you are close to a SEARS somewhere, because they advertise parts made for Kenmore -- try this link http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Evaporative-coil-Parts/Model-867813350/0582/1610510/00007536/00001
Ray
Jan 19, 2011 | Kenmore 94210 / 94211 / 94212 / 94214 /...
Kitchen Ranges Logo
57 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
