Question about Silentaire Technology Air Tools & Compressors
I have a 185d grimmerschmidt compressor when i put it uder a load the motor begians to shake or vibrate really bad what can this mean please help.
  • 32 Answers
SOURCE: Kenmore two way tumble action washing machine - shakes, vibrates very loud
sounds like you have a broken stantion on the back of the basket.you can confirm this by opening the door and trying to pull up on the stainless steel basket.if it pushes up and flops back down,that is what you have.if the mach is over 2yrs old,look in your manual under warranty.if it has a 10yr on stainless steel basket and lifetime on tub,you will only have to pay for labor on repair.if it only has 1yr on entire mach,est would be higher than the price of a new one.
Posted on Sep 28, 2008
  • 491 Answers
SOURCE: Car shakes really when I accelerate from any speed
i would check your motor mounts and transmission mount. sounds like one if them is going bad
Posted on Nov 16, 2008
SOURCE: 00 ford zx2 idles ruff in gear so bad it shakes
.how to set the timing on a 2000 ford sescort zx2 and why does it idle rought it a dual kam 2/0 timing belt broke and the engine was fixed in a shop but i dont think they know just how to set the timing right when im going up hill and the car shifts back the engine reves up to about 3000 rpms the engine sounds lick it is pinging real loud sounds like it not set right
Posted on Mar 15, 2009
rockitman187
  • 2559 Answers
SOURCE: steering wheel shakes and brakes vibrate badly when stoping
Sounds like the rotors are warped,Take to a brake shop and have them checked or replaced.
Posted on May 22, 2009
  • 142 Answers
SOURCE: vibration when riding idleing think maybe motor mount how do i chrck it
Check the engine mounts to the frame. these are isolated by rubber and you may have broken one gettin' on it at the light.
Posted on Jun 02, 2009
My magic chef model ctn1911gew is not working properly makes a clicking sound and is not cold at all and fan on bottom is not running. please help
Are we talking about the fan near the compressor? It is important to know if the compressor itself is running. If there is a loose connection to the compressor via the start/over load relay (normally attaches directly onto the compressor), or if the start/over load itself is bad the compressor will not run. It will click trying to turn on untill the over load gets hot Check to see if your compressor is really hot. Could be bad start/over load relay or bad compressor. Try unplugging your frig for say 30 min then, with your hand on top of a cool compressor, plug the frig back in and see if compressor smoothly vibrates for at least 5 min without becoming very hot or shutting off even though fan continues to run. The fact your fan is not running could itself be the problem. It is needed to keep the freon, and the compressor cooled.
Oct 12, 2013 | Refrigerators
Rangemaster sxs cream . Why is my fridge and freezer the same temp ???? If anybody could give me an answer or solution.
Jason,
MOST refrigerators get there cold from the freezer side and circulate it via a fan that's also normally inside the freezer. There are three motors normally in a refrigeration system. The inside Evaporator fan motor that circulates air across the evaporator coil inside the box, the Condenser fan motor near the compressor that cools the freon after compression, and the compressor itself. If you open the doors (and sometimes you may have to hold in the door switches) do you hear a fan running? If not you could have a couple things going on: 1. The fan(s) has failed. 2. The freezer Evap coil may of iced over and the fan too is frozen stopped. 3. Your condensing unit:(compressor, condenser fan, condenser coils) has a problem.
It is important to know if the compressor itself is running. If there is a loose connection to the compressor via the start/over load relay (normally attaches directly onto the compressor), or if the start/over load otself is bad the compressor will not run. Best way to tell is via gauges but I doubt your frig has ports. Check to see if your compressor is really hot. Could be bad start/over load relay or bad compressor. Try unplugging your frig for say 30 min then, with your hand on top of a cool compressor, plug the frig back in and see if compressor smoothly vibrates for at least 5 min without becoming very hot or shutting off even though fan continues to run. The fact your fan is running TYPICALLY means the thermostat is calling for lower temps and the fan/compressor kick in together.
Oct 11, 2013 | Refrigerators
Altima engine shaking
AC compressor put load on engine causing engine shake vibrate.but check make sure AC compressor mounting bolts tight and drive belt correct tension.now if AC compressor very old most time bad compressor cause more load on engine causing shaking real bad.
May 23, 2013 | Cars & Trucks
Whynter Portable Air Conditioner Model: ARC-14S. Problem: It sounded as if something fell inside the unit while it was operating (cooling) then it started to vibrate horribly. The vibration is only...
Hi,Whynter Portable Air Conditioner has many moving parts, and they all make noise and cause vibrations. Some of these parts are more likely to causing shaking and loud noises, and sometimes this signals a larger problem, something to watch and scrutinize. If serious enough, it calls for a repair.
Loose Parts
Loose parts cause the majority of shaking and vibration noises in your air conditioner. A few of the most common loose parts include the air compressor, the piston rods and even the fan or blower unit itself. These noises are clunking, clanking sounds that occur along with a vibrating action. The only method of repair is a complete compressor replacement, which is a repair only a certified air conditioner technician is qualified to make. The compressor is a fully sealed component, so individual parts in the compressor cannot be repaired.
Fan Blades
Fan blades cause noise, shaking and vibrations even when properly secured. If fan blades contact the exterior structure of the air conditioner due to a bent fan blade or broken and misaligned grate, a constant, repetitive noise and vibration results, which sounds like a ticking or banging from the interior of the air conditioner. Vibration in this case is limited but still present.
Mounting Brackets
When an air conditioner shakes, there is a problem with the mounting brackets. These brackets hold the air conditioner compressor steady as it operates. Normal vibrations and shaking would otherwise occur without these brackets. A loose mounting bracket causes the air conditioner to rock back and forth and creates a clanking sound. As the compressor starts up, this rocking and clanking sound begins, resulting in a very loud and fast vibration and noise. It also occurs when the unit shuts down.
Other Sounds and Vibrations
Sometimes air conditioners squeal, hiss, hum or screech. Each noise is often accompanied by a vibration. Humming sounds along with a vibration may indicate a bad capacitor, the electrical part responsible for starting the machine. Hissing sounds tend to indicate a pressure problem while screeching and squealing sounds are fairly common in window air conditioners and in central air conditioners. This sound is also a result of the compressor motor. It usually starts when the unit turns on and continues through its normal operating cycle. Vibrations always occur in the air conditioner due to moving parts and the compressor motor's operation.
Hope it helped..
Aug 18, 2011 | Whynter Portable Air Conditioner
Model will not stay on cuts off- shake machine, comes back on
Do you mean when you shake it, it starts up again? It is hard to say for sure, but it sounds like a main power wire is loose somewhere. Unplug the machine, take the lower cover plate off and check all the connections. There really isn't a part that works better when it gets shaken. Here is another possibility. If yoy mean that the machine shakes itself and then comes back on, it is probably a bad compressor. When a compressor goes bad, it has an automatic shut off switch to keep it from burning the wires out. If it shuts off it means the compressor is really hot because it is locked up. When it tries to restart, the compressor will shake sometimes when it kicks out again. If this is the case, its time for another ice machine. The cost to replace the compressor is almost what a new machine will cost.
Sep 07, 2010 | U-Line Icemaker
Vibration of Dryer
It may be off one of the guides. Or a balance problem. It may be a bit off balance. Now that you have a new bearing your machine is going to work better. It will spin faster because of the new bearing. When it spins faster you will get vibration. If it is not shaking badly, Try to load your washer balanced. If there are any more questions please feel free to ask. I will help you untill we have this thing solved. Please leave good feedback for me, it means a lot to me, and I will really help you all that I can...
Jul 20, 2009 | Dryers
Washer vibrating badly
Hi, Try these
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
pls rate my suggestion......
Jul 19, 2009 | LG Washing Machines
Engine vibration in drive or reverse
Wow..thats not good..first have motor mounts checked, maybe the tranny mount or possibly if ur car has it is the driveshaft bearings...good luck on the oil leak...maybe tranny fluid..make sure if ur losing fluid that ur checking them incl. the tranny fluid...u might find ur leak first of all by rechecking the oil cap where it is supposed to be ...same with all fluid caps.
Feb 27, 2009 | 1997 Acura TL Series
Air Tools & Compressors Logo
56 people viewed this question
Top Silentaire Technology Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Silentaire Technology Air Tool and Compressor Expert? Answer questions, earn points and help others
