What does wtd meaan - Computers & Internet
I have an engine code 23 on my R1 and it also doesnt seem to have as much power that i think it should have. Does anyone know what the engine code 23 means?
Error 23 meaans that the atmospheric sensor is faulty or the wiring associated with it may be faulty see your dealer to locate this sensor,they are about $100
May 30, 2011 | Yamaha NB 125E Motorcycles
The audio service is not running...what does it meaan? how will the audio works?
if you have windows xp then you can install the realtek software and if have windows 7 then your driver install automatically...if you already installed the realtek then first remove it and then reinstall it..@@
Apr 19, 2011 | Computers & Internet
Error code wtd-1800 when trying to download free trials
Error 1800 means that your registry is likely 96% damaged, this could be due to trojans from untrusted download files... I suggest you use a registry cleaner to erase the infected files... this will not effect your windows database.
Sincerely
rover620
Oct 02, 2010 | Computers & Internet
Last year i buy the ms office soft ware but now icantrun my
mshankar, what do you mean what can you do, if you meaan I bought it a year ago and never used it can i still install.
Answer is you sure can, put in cd , install it , activate it with your key
and you should be good to know. The life expandency for most software is 10 years. Only making an assumption this is your issue ,you did tell us much
Mel
Jun 08, 2010 | Microsoft Office Professional 2007 Full...
4x4 light is on in auto
It means that the car is in 4 wheel drive mode
Mar 24, 2010 | 2001 Mazda Tribute
Brandt wtd 1276k washing machine error d23.?
You need to reset the thermostat that's inside the washing machine, it's on the right side.
Check HERE for details and photos
Jan 08, 2010 | Brandt Washing Machines
My wtd yard machine will not start on first try.
Sounds like you have a bad conection on your solinoild(are your battery conection tight) does the engine turn over by hand ok.clean all your large wires and that the grounds too.I think you will find your problem by cleaning,
Sep 14, 2009 | Mtd 22" Yard Machine Push Mower
Hi, Mum has a wtd wanrite mtt model 548/12hp mower ride
Hi this sounds like there is a spot of dirt in tne fuel system
you will need to dismantle the carburettor which is quite straight forward (be careful not to lose any screws or gaskets
guive the carburettor a good rinse in neat petrol/gasoline and blow out any debris that may be there.
re assemble the carburettor and prime with fuel and you should then be ok.
One other thought if you have found that the motor runs fine without being on the grass (eg it doesn't cut out after a minute or two) then it could be that you have the cutting blades set too low for your first cut. To raise the blade adjust the height of the wheels. Always start cutting with a high setting especially if the lawn hasn't been cut for a while.
hope this helps
W
Jun 12, 2009 | Briggs & Stratton Garden
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
