Question about NorStar T7316E Corded Phone
When i get to Terminals and Sets it won't move
At terminals and sets I click the arrow and nothing happens
    New Friend:
  • 50 Answers
If your phone is still under warranty period then take to
the agents and get it solved
Posted on May 16, 2014
2 Suggested Answers
ynotphone
  • 192 Answers
SOURCE: Need to change the phone number assigned to a line
Hi Amy,
Ok ~ first to change the incoming line to a phone, goto the phone and do a:
-> FEATURE * 0,
-> Press the line that rings on that phone... (this will be the target line number ~ maybe somewhere in the 145-256 range)
-> now get into the system programming
-> go to LINE and type in the number you've seen on the display
-> enter and find TRUNK/LINE DATA
-> enter and hit next till you see PRIMESET and change that number to where you want that number to ring to. Hit next, after changing number and hit REL to get out of programming.
Now call the number to ensure it is calling to the correct extension.
Posted on Mar 20, 2009
Sony KV-36FS210 intermitted horizontal comes and goes nothing is coming up on self test. notice when tap lightly if facing tv on right side it stops. took back off just don't know what I'm looking for....
Sounds like a loose contact. Check all the solder terminals at the horizontal output as well as IC terminals, for any loose or dry solderings. Re-solder all the suspected solder terminals, by applying a little more solder, without making any solder-bridge short in between adjecent solder terminals.
Oct 11, 2013 | Sony FD Trinitron WEGA KV-36FS210 36" TV
I have a jaguar x type 2002 and now and again I try to start it nothing happens. All I here is some clicking but engine won't start. Happening more and more.
Sounds like a loose connection, check your battery terminals are tight. if you have to boost or jump start the car check your battery condition and alternator output. Check the terminal on the starter motor and solenoid. Finally check the starter
Dec 07, 2011 | 2002 Jaguar X-Type
How to install intermatic PB913N66
Open following link to identify timer:
http://waterheatertimer.org/pdf/Intermatic-PB800-PB900-timers.pdf
The timer has 4 terminal connections.
2 terminal connections are for the clock motor, and 2 terminals are switched just like ordinary light switch.
See how to connect terminal ends to electrical wire by crimping:
http://waterheatertimer.org/Terminals.html
Which 2 terminals are for clock, and which 2 are for switch?
Test across both sets of terminals using continuity tester or multimeter set to read ohms.
Then rotate override knob to next position, and repeat test on both sets of terminals.
The set of terminals that changed when override was rotated are the switch terminals.
The other set of terminals are the clock terminals.
Connect 120Volt Hot and neutral to the clock terminals. Turn on power and make sure clock dial rotates.
Next: the cable going to Load has 2 wires: Black and white.
Cut the black wire. Crimp terminal connections on each end. Connect each end of black wire to the switch terminals.
To set timer for on-off operation, open following link:
http://waterheatertimer.org/How-to-set-timers.html
Sep 25, 2011 | Hardware & Accessories
Norstar meridian 7208 won't ring.
Does it ring when you move it to a known ringing port? Is it programmed to ring (Terminals & Sets) Appear and Ring? Do you have Automatic Set Relocation turned on so the extension number stays with the phone?
There are a lot of features to check for ringing, including the volume of the set.
Carl
Sep 10, 2011 | NorStar M7208 Corded Phone
Trying to fix my Volvo S60 2002 model. It won't start but when I hook the jumper cables to the my battery i have all interior power. when i try to turn over the engine nothing happens except clicking....
Make sure you have a fully charged battery...clean the terminals real well.
Alternator only charges the battery when the correct engine rpm is attained.
A clicking noise could be the starter solenoid which is basically a relay / contactor but can block power from reaching the starter.
Worn brushes in the starter can also zap a battery's power.
Battery, starter and aloternator can be tested at most part stores.
From what you describe, I'd clean battery terminals and ensure battery is fully charged.
If clicking still happens, I'd move to the solenoid and starter.
Hope this helps...
Aug 28, 2011 | 2001 Volvo S60
I have 2 questions: 1. I need to move a M7310
The program your looking for is set relocation which is in system programming. Copying a sets features from one set to another (or multiple sets) is done under the terminals & sets heading after you put in the initial programmed sets Dn, the copy soft key should be on the left side.
Jan 27, 2010 | NorStar Meridian M7310 Phone
How to change number of rings before it goes to voice
This is in the station programming menu. login by **admin and the password. go to terminals and sets, enter your station. press the top right arrow to select go to capabilities and after fwd no answer you can select # of rings.
Nov 16, 2009 | NorStar M7310 Corded Phone
Are you able to move or change extensions?
First, move the telephone sets back to where they were.
Next, we'll have to change the system programming.
Programming2.gif is done on 7310, 7324 and 7316 type sets.
Enter programming2.gif by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming2.gif.
At the terminals&sets prompt, press the next key 7 times(bottom right arrow).
The display should say system programming.
Press the show key (top right arrow)
The display should say hunt groups
Press the next key 2 times(bottom right arrow) .
The display should say Featr Settings
Press the show key (top right arrow) .
The display say Backgrnd music2.gif.
press the next key 20 times (bottom right arrow)..
The display should say set relocation.
Press the chng key. change from N to Y.
Press the release key when finished
Move sets from their old locations to their new locations
Sep 28, 2009 | NorStar Meridian M7310 Phone
How do I programme my buttons and how do set up the phone for hands free use. The phones were moved and the technician set all the phones to the original settings so none of the phones have hands free...
Programming2.gif is done on 7310, 7324 and 7316 type sets.Enter programming2.gif by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you want to change to handsfree.
The display should say LINE ACCESS
Press the next key (bottom right arrow) .
The display should say CAPABILITIES.
The display say foward no answer.
press the next key 3 times (bottom right arrow)..
The display should say handsfree. Press the show key.(top right arrow) change from none to auto
Press the heading key (top left arrow) til the display says TERMINALS & SETS again.
enter in next extension to program.
repeat procedure.
Sep 01, 2009 | Nortel Meridian M7208 Corded Phone
Turned off my 2006 Escape & now it won't start.
battery failure ,it does happen,cleanbattery terminals pour boiling water over terminals if they are corroded loosen clamps by undoing nut wiggle clamps back and forthand and retighten if no lights then ,iwould suspect computor failure -------- youdoit.com
Jul 25, 2009 | 2005 Ford Escape
NorStar T7316E Corded Phone Logo
Top NorStar Lands Phones Experts
Oloyede Monsuru
Shehu Pro
Shehu Pro
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
