Question about Honeywell RTH3100C1002 Digital Heat/Cool Pump Thermostats
How do I fix Digital readout that does not show "cool" .
Will not change temp, will not show "cool". Blower works but cool does not come on.
Freezing & cooling problems.
change the thermostat
Aug 08, 2015 | Refrigerators
My Dometic digital thermostat wont go up past 32 degrees. What could be wrong?
indicates inside sensor defective or not communicating resulting in a/c being locked out.
Sep 16, 2014 | Dometic 3313192.000 White Single Zone LCD...
No heat coming from heat vents, blower works. i have change thermostat still no heat
Make sure the cooling system is full ... they can run with low coolant and not have it show on the temp gauge. Make sure the heater temp control actual opens the valve the controls the flow of coolant to the heater.
Sep 20, 2010 | 1994 Toyota Pickup
Freezer cold, fridge not cooling properly?
if its an electronic digital readout and it doesn't seem to change temps then your electronic control main board in the rear of the unit it needs to be replaced
Jul 02, 2010 | Whirlpool GS5SHAXN Side by Side...
Digital readout not readable
Try a new one. If it works, the scale is broken.
Jun 30, 2010 | Taylor Precision Products Taylor Precision...
Jet pump will not shutt off after I replaced heater relay. Tub is a hot springs landmark with an IQ2000 panel the year is also a 2000
it sounds like the pump relay may be stuck closed. Also check the temp readout, if it thinks the water is too hot it will try to cool the water by running the jets and sometimes the blower as well.
Dec 08, 2009 | RTO 2 Person Spa Hot Tub 8 Hydrotherapy...
No mileage showing digital readout thanks
It is registering, but the light is burned out. You can probably use a flashlight on it and see a faint glow of numbers, but you just need a new bulb. Your radio is probably only half lit on the readout, too. Common problem with Pontiac sunfires. Dashbulbs. Cheap fix, but time consuming.
Nov 17, 2009 | 2001 Pontiac Sunfire
My 5160 overheats during long hd operations (virus scans, backup etc). I have noticed that the fan is not kicking up to the top speed. diagnostics shows the fan dual speeds work as does the thermistor....
You can download a free software GUI fan control and set the fan speed to max all the time. this should keep your system running smooth and cool. You can even monitor it with a digital temp readout near the clock after you install this simple little program.
Here's the link: http://www.diefer.de/i8kfan/
good luck
tony
Jun 08, 2009 | Dell Inspiron 5160 Notebook
Honeywell RTH3100C1002 Digital Heat/Cool Pump Thermostats Logo
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
