Question about Poulan 46in Mulching Tractor Blade
Gas in oil after storage what to do to stop?
Poulan pxt16542
  • Poulan Master
  • 2,478 Answers
Change oil. Install a fuel shut-off in fuel line. Your fuel solenoid may be bad.
Posted on May 15, 2014
My blades will not disengage after turning off manual switch poulan model xt- pxt16542
The clutch solenoid seems to get stuck, cleaaning may be the solution.
Jun 25, 2015 | Poulan Garden
Have a poulan wild thing and the oil bar compartment has gas in it
I would drain the oil and gas or whatever is in it. I would also drain the 2 cycle mix from the gas tank and start with a fresh gas and oil mix and fresh bar oil. The mix for the Poulan Wildthing is a 40:1 mix.
You are definitely going to smell gas when using any chain saw.
Oct 28, 2014 | Poulan 18" Wild Thing Chainsaw
What is the ratio of gas to oil for a 35cc engine
Mix 3.2 ounces of Poulan 2-cycle air cooled engine oil to one gallon of fresh unleaded gasoline to obtain the recommended 40:1 fuel to oil ratio.
Over a period of time oil will separate from gasoline. To properly insure oil and gas mixture, I recommend thoroughly shaking your oil and gas mixture before refueling your unit.
If the saw is to be stored for longer than 30 days - drain the fuel tank, re-tighten the gas cap, and start the unit and let it run until it stops.
Jun 09, 2014 | Poulan Predator 35cc P3516pr Chainsaw...
My poulan pro chainsaw dies when I give it gas and I think the bar and chain oil is leaking out during storage.
try and run it with the muffler off the build up with carbon and restricted the exhaust flow as for the oil leak mine the screws became loose behind the clutch for the oil pump
Sep 17, 2012 | Poulan Pro 20-inch 2-cycle 50cc Gas...
How do you disconnect the govenor that doen't allow thw the tractor to cut in reverse. Model #PXT16542
should be a switch under the reverse lever. it pushes in when the mower is put in reverse disconnect it and you should be good.
Jul 09, 2011 | Poulan Garden
What is the oil to gas ratio on Poulan 3314
Poulan and Poulan Pro chainsaws with 2-cycle engines require a 40:1 gas-to-oil ratio, which corresponds to 3.2 ounces of oil per gallon of gasoline.
Jun 15, 2011 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Dont know what the oil gas mixture is suppose to consist of
Your manual (from Sears) states that your mix ratio is 40:1. You will need 3.2 ounces of Poulan "Pro" synthetic 2 stroke oil mixed in 1 U.S gallon of gas or you can mix 1.6 ounces of the oil in a half-gallon of gas. They suggest using the Poulan "Pro" brand synthetic oil. I do also. Synthetic oil significantly reduces wear, allows the machine to run cooler, and burns cleaner with less by-products and emissions. You can view a PDF file of your manual here:
http://www.managemylife.com/mmh/owner_manuals/133702/POULAN-Blower-Gas-1009868L?brand_name_search=952711923++
May 01, 2011 | Poulan Pro 25CC 2Cycle Gas Blower
What is the oil to gas mix? Paulan xt-200
Poulan motors usually use a 40:1 mix ratio.
That is 3.2 oz of 2-cycle oil to 1 Gallon (128 oz) of gas.
Be sure to not use gas with more than 10% Ethanol.
Jun 06, 2010 | Poulan/Weed Eater No. Te475 952711797 17"...
Bar oil leaking constantly. How do I fix it?
These saws are of the self oiling type there is no tip or bottle it consists of a tank and a channel the oil flows thru and on to the bar by gravity. There is a type of bar oil system on some saws that come with a button you push which In turn pumps oil onto the bar. But the poulan is not one of them. I have a 15 year old farm hand 20" bar and a two year old poulan wild thing 18" and both leave there oil in the case when sitting I beleive the fix would be drain it after use and clean up.
Mar 21, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan 46in Mulching Tractor Blade Logo
48 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
