Question about Poulan 38-Inch Steel Deck 15.5 HP Briggs & Stratton I/C Engine With 5 Speed
15.5 ohv briggs and stratton
After motor gets hot engine will only run in idle speed and i cannot engage belt drive to cut the grass and when i apply gas to motor it wants to die unless i go back to idle speed i am burning no oil but suspect head gasket might be bad.
  • 28 Answers
It could be "starving" for gas, not getting enough gas. Check the plug, if it is white then the engine is running to lean and will overheat. If this is the problem, then the carbertor will have to be adjusted, and or cleaned, or replaced.
Posted on Jun 24, 2009
17.5 hp ovh Briggs and Stratton engine hesitates after about a half hour of cutting grass then wants to shut down and what i did to prevent it from shutting down was play with the throttle and gradual
Could be dirt or water in the carb or perhaps something floating around in the exhaust.
Might be a blocked or almost blocked fuel tank vent...
Oct 09, 2017 | Measuring Tools & Sensors
Ok i have a problem with my Briggs & Stratton 16HP v-twin vanguard engine.When i start the engine and rev it up when i idles back down it sits there and rev's up and down then it straightens out and...
It appears that you have a slight mis-adjustment in the idle speed and idle mixture. To adjust setup, start with at least a half tank of fuel, and have engine at operating temperature (That is warm but not overly Hot). The Briggs & Stratton Website manuals section should show the locations of the adjusting screws if you are not sure of them.
To adjust idle speed set Throttle control to minimum and adjust screw on throttle butterfly to maintain a good idle speed. To adjust idle mixture, screw in idle mixture screw (Lean) until motor falters and then screw out (Rich) until it falters again. Correct setting is the halfway point of these two positions. You may have to re-adjust idle speed again and also the mixture to get best running.
If you are not comfortable doing this, take it to a B & S dealer.
Sep 21, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
I have a Briggs and STatton 24 OHV intek motor on a craftsman lawn tractor. I got it on sale and when I got home it ran rough. The fuel line had collapsed or was plugged with some white powder. I took off...
It sounds like the fuel mixture is running very Lean..There are usually two adjusting screw screws on the carburettor that control the mixture. A Larger one is for the Main Jet and a smaller one for the Idle Jet. There is also an adjusting screw on the throttle butterfly to control the idle speed.
To adjust setup, start with at least a half tank of fuel, and have engine at operating tempurature (That is warm but not overly Hot). As a starting point, loosen (anticlockwise) Main Jet screw about half a turn, to richen mixture,so that engine will run without choke. Run engine at full speed and adjust main jet for highest smooth speed without engine missing due to mixture being too lean or rich.
Allow engine to idle and the adjust Idle Jet Screw for smoothest idle. Idle Speed screw may have to be adjusted if idle speed is too high/low.
Sequence above may have to be repeated to get best running. If engine hesitates sometime when sudden load is applied but then picks up, try adjusting Main Jet by 1/8 to 1/4 turn richer until it handles the load without faltering.
Aug 22, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Poulan 38-Inch Steel Deck 15.5 HP Briggs & Stratton I/C Engine With 5 Speed Logo
653 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
roeb
Are you a Poulan Garden Expert? Answer questions, earn points and help others
