Question about Kenmore Elite HE4 Electric Dryer
My dryer works but won't heat up. The light bulb inside the dryer was burned out as well. What could my problem be?
  • 57 Answers
A thermostat or heater
Posted on Jun 23, 2009
Fix a burned out light bulb on dryer?
there should be a light bulb housing in the inside back of the dryer. most just need a screw driver to open in, just remember to unplug the dryer before do any kind of electrical work...that includes changing a light bulb. unscrew the housing, make sure not to lose any of the screws. with the correct light bulb, just replace the burnt out one with a new working one.
Dec 25, 2014 | Refrigerators
My Whirpool LGB6000KQ1 Dryer -- The drum won't stop turning when I open the door and the light doesn't come on either.....
You have a faulty door switch. Here is the replacement switch.
There is a video on that same parts page to show you how to replace it.
Feb 10, 2013 | Dryers
Admiral dryer super capacity dryer won't heat up and light doesn't stay on. It happened when we first brought it home years ago and the repair may said to reset some button but I don't kn
see this causes and fix it. God bless you
Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Thermal Fuse / Thermal Cut out
On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel or behind the front panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing or is sometimes round and made of metal and plastic.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse this is the most common reason for blowing the fuse. (You can't re-set this type of fuse.)
Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Sep 28, 2012 | Admiral Dryers
My dryer stopped spinning and it won't heat. it just makes a click sound inside the dryer.
Dear Sir:
See this possibles causes:
Power from the house
Test the main cables from your house, and the dryer for continuity see the diagram attached
Heating element
one heatings elements burn or open, test for continuity.
Thermal fuse
test the fuse for faulty or open, continuity and replace it
Wiring
test for wires burn or break, see for continuity.
God bless you
5_24_2012_10_33_43_am.gif5_24_2012_10_33_58_am.gif5_24_2012_10_34_21_am.gif5_24_2012_10_35_06_am.gif5_24_2012_10_35_28_am.gif
May 24, 2012 | Samsung Dryers
I replace the light bulb but it does not work although the dryer works fine. Is there a special bulb?
with the power unplugged, check the tab inside the bulb socket to be sure its not burned or damaged, also,, at times a new bulb is no good, If you have a multimeter,, put the selector to continuity ,, and place the black lead to the bulb base, and the red lead to the center point at the bottom of the bulb, if you get no reading, the bulb is no good, ( if you don't have a meter, screw it into another lamp, as long as your sure the dryer light socket is a 120v not a 220 volt
Jul 12, 2011 | Whirlpool GEW9250 Electric Dryer
Ge profile dryer drum turns but therte is no heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Oct 27, 2010 | GE Dryers
Whirlpool Dryer 3.5 years old has power but will not turn on. Not a breaker problem. has electricity. Drum turns by hand. No noise is heard.
we had a very similar problem on our DLE3777W LG clothes dryer. It would power up normally, all drying options and speed and heat selections behaved normally but when you tried to start the dryer the start button and the time remaining indicator would flash until the unit was turned off. Called LG and Best Buy and they could only tell us to contact a repair shop. But I realized that the light was burned out inside, so I replaced it myself to avoid being charged by the technician I was about to call. The burned out light bulb WAS the problem, as soon as it was replaced the dryer worked perfectly. I think I saved a couple of hundred dollars with a $4 light bulb. I would have been mad to have the technician show up and charge me $120 just to show up, then an hourly rate and then the bulb.
Jun 26, 2010 | Whirlpool WED5800S Electric Dryer
Dryer will not start
EJ
Jun 07, 2010 | LG DLE7177 Dryer
Heating element and/or replacement bulb
no light bulbs on its own line and routs through the door switch as for the heat check your temp select button or your thermostst in the control panel should be a tech sheet with specs but be sure to put it back when your done
Feb 11, 2009 | Kenmore 63942 Dryer
Won't start, just beeps - sounds like door switch problem others have had
The three short beeps could be part of the fault code. Check the owners manual and there are diagnostic sheets on the inside of the machine. I cannot find this fault code in my data base. What is the Model and Serial Number of your Dryer. Check the Power inside the machine at the power cord power connections. You should have 120V from both power terminals to the common terminal. There should be 240 Volts across the main power terminal. Another quest replaced the power cord. Hope to hear some good news soon.
InMrFixIt.
Aug 12, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
244 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
